Riding in cold
I'm wearing 2+ layers of clothing on my legs when it's that cold. Pushing against that resistance is definitely noticeable. Also, my nose runs when it's cold and my snot-rocket position is not as aero, so there's that.
Likes For tntyz:
I think I know nothing.
Quoted: 233 Post(s)
Liked 290 Times
Last winter I rode outside 2 or 3 times total. I really do not like the cold.
I have been telling myself since Spring that I wouldn't ride outside this year once the temp dropped into the 40s. Just ride on a trainer and be content. However I'm going ahead and don't know why but I'm putting together a insulated set of kit to try to get out at least once a week as long as the roads don't have ice or snow and it's not colder than 20 deg F. Just need a pair of gloves to complete my kit. I do have a pair of those toe covers and they work ok when you place a hot pack in them.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I am convinced that there are physiological reasons also. At least for some of us (me). Capillaries constricted, muscles are tight, lungs don't work as well, extra work to keep warm, maybe some endocrine differences. Maybe lower light levels psych me out. But I'm certain that I'm just physically slower when it's colder.
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 762 Post(s)
Liked 555 Times
plus the faster you ride, the more the wind chill. I will intentionally ride slower sometimes
Likes For Flip Flop Rider:
Likes For y0x8:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2571 Post(s)
Liked 5,602 Times
I ride in winter as long as no ice and wind is not bad. Today did my usual 50 mile loop temperature was 33 degrees but not much wind. I wear gore Tex jacket. Normally in warmer temps I can do this an average 17 mph even tired. I get 18-19mph often.
Today I only could manage 16.5 and was not bad out as such, but feet will start getting numb. I got in a just beat more than normal and sleepy when done. Anyone else have this in cold weather seems to be a consistent thing with myself.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
A couple of thoughts. You could have been low on calories which made you feel fatigued. A better thought is that you were suffering from mild hypothermia. Sleepiness and lethargy are classic symptoms. As a downhill skier for many years, I can attest to the effects of cold on performance as well as outbreaks of yawning in the middle of the day. You may want to try bundling up more, focusing on your head and neck and buying those ferrous oxide toe warmers skiers use. If that fails, you might want to talk to your doctor.
Tried rising during winter and never did it again. I placed some heat pads that re so popular in japan or korea and placed it all over my body and that helped but it just lasted for 20 minutes. So maybe you could also purchase those heat pads from japan just not sure where to get it here in the states.
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times
The coldest temp at which I will ride intentionally is 40 F - and it needs to be sunny and not stupid-windy.
If I paid for a charity or organized ride, or made a promise to someone I would absolutely be there, then I might go colder, but it hasn't happened yet.
I will take 90 degrees with 30-40% humidity over 30-40 degrees ANY day.
aka Phil Jungels
I don't mind cold; and yes, I do get slowed down by it!
But I don't do ice or snow, since my visit to the ER for stitches in my face!
Quoted: 399 Post(s)
Liked 185 Times
No ice for me I did that one time and to the dr for 3 screws in my left hip. I was lucky not a displaced fracture healed pretty fast and some have to have hip replacement if does not heal right.
Quoted: 659 Post(s)
Liked 595 Times
So far, our temps at my evening ride time is around 30deg. When temps drop to 20 or lower, that requires a different (more bulky) level of clothing. Why is it so tiring? Some of my comments reinforce what others have added.
-My bike (vintage Trek Antelope 830) weighs 27#
-Tires have crazy rolling resistance
-snow adds to the rolling resistance
-I wear jeans and longjohns (yes, you read right) double resistance
-overall bulk of clothing adds pounds of ride weight
What’s the result? A good stiff workout in half the distance in the same time, basically. Yes, it is humbling and very similar to doing a ride in constant headwind every ride. In the spring when I throw a leg over my Cannondale Criterium for a vibrant road course, it all pays off.
Grupetto Bob
Liked 5,602 Times
You guys are a hearty lot. For road biking, I’m out at below 40*. Commuted for three years down to the 20s and that was enough. If it snows I’ll get on my mtn bike and head out for an hour or two, and that’s plenty of work/fun.
Hats off to all y’all.
Likes For rsbob:
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times
Ok, so I have gloves, have lots of layers to pile on, have fleece long johns that I can wear under wind pants, have a wet dry running cap I can wear under my helmet, all the things I would wear to cross country ski but what do I do to protect my face? I went out on the weekend for a really short ride and the temperatures weren't too bad (just above freezing) and it wasn't that windy but because I was moving I could really feel it on my face. This is something I don't worry about cross country skiing (don't go that fast) but could be a game changer on whether to go out riding.
Likes For y0x8:
Two things:
1. You acclimate and get used to it. You fell cold the first time at 30F. Then the next time it’s not so bad. By spring, you get hot at 30. The first time it’s -20F I go out skiing all day and after that everything is easy. Same applies to cycling vis a vis acclimating.
2. Buffs or something similar. I have a whole drawer full of them. I use them starting at 40F and for the rest of the winter.
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,829 Times
I don’t take a bike ride in snow or ice, tho I can take a short little jaunt on my mtn bike.
Feet have always been my prob below 45*f.
Took the matter in hand this year.
Should keep the wet and road silt at bay, too.
In th mail today.
In th mail today.
Likes For Wildwood:
Ups!
Likes For y0x8:
Grupetto Bob
Liked 5,602 Times
One thing about winter riding in the countryside; I feel less safe. The roads are usually wet and shaded with leaves or downed branches. Visibility sucks with the sun so low on the horizon and feel more vulnerable to blinded drivers. don’t like riding below 40*. Am just a big wimpy whiner.
BUT, when it snows, I happily jump on my mtn bike because it is trails only.
I am a new rider but I am in deep. I haven't missed a single day since early March of this year. I ride 20 miles a day and I am really addicted and get antsy about noon if I haven't ridden yet. It doesn't get real cold out here in the Pacific Northwest but what it does do is rain tons and tons and the temperature gets to the high 30's. So you end up with cold soaked feet and sometimes they are so numb , they hurt and you have to warm them up slowly in a tub of water when you are done.
Also I haven't run into ice yet but it's a definite possibility. What do you do then? I suspect I will walk.
I am a new rider but I am in deep. I haven't missed a single day since early March of this year. I ride 20 miles a day and I am really addicted and get antsy about noon if I haven't ridden yet. It doesn't get real cold out here in the Pacific Northwest but what it does do is rain tons and tons and lately the temperature drops to the high 30's. At times it's a pleasant feeling as long as you have a tight nylon jacket on but unfortunately there isn't much you can do for your shoes. Unless you want to wear ridiculous 5 pound mountain climbing boots, you will always end up with cold soaked feet and sometimes they are so numb , they hurt and you have to warm them up slowly in a tub of warm water when you are done.
Plays in traffic
Bikes: 1996 Litespeed Classic, 2006 Trek Portland, 2013 Ribble Winter/Audax, 2016 Giant Talon 4
Quoted: 76 Post(s)
Liked 14 Times
Possibly not worth it in the PNW. Depends on how much snow and ice you get, and how determined you are to get out in it.
My first year could be summarized about the same as yours, and I planned to walk the winter. Then the LBS turned me on to studs. No walking, 15 winters later.
Studded snow tires. I run these--45NRTH Studded Commuter Tires. The Gravdals on my Portland, and the Kahvas on my Talon.
Thank goodness I discovered Bicycling. For me, walking was not enjoyable.
Likes For 5 mph:
