Where can I find those little rubber shim strips?
bill nyecycles
Quoted: 788 Post(s)
Liked 349 Times
You know the ones that come extra with a bike light mount or maybe a GPS mount. They’re the really thin ones that are kinda grippy on one side. I don’t know exactly what they’re called and searching rubber shim didn’t seem to help me.
anyone know?
anyone know?
Quoted: 4171 Post(s)
Liked 3,789 Times
Accessory bracket shims. Try a LBS and they will likely have a bucket full. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 303 Post(s)
Liked 136 Times
As above, or google on bicycle plastic shim strips for mounts for some options. If you have been around the block
a few times you will have a bunch of these from prior computer/rear light/bar light or other accessories laying around,
so you could check with fellow cyclists.
bill nyecycles
Quoted: 788 Post(s)
Liked 349 Times
I used to have a bunch but I think they went out with the debris after Hurricane Harvey flooding. Haven’t bought anything that uses them since I guess!
Likes For Gresp15C:
Quoted: 667 Post(s)
Liked 529 Times
I was going to say, they are called innertubes
This this
For years I've kept a couple of knackered tubes hanging on a nail on the garage wall for easy snipping off a bit if needed.
Monkey Boy
Bikes: '22 Surly Straggler, '15 Breezer Downtown EX, '19 Motobecane Record (fixie)
Quoted: 76 Post(s)
Liked 89 Times
ha... great minds think alike... plenty of rubber shims after changing just 1 flat! :-)
Artist | Musician | Bass Player
Life is what happens to you while you're busy making other plans. (o.o)
bill nyecycles
Quoted: 788 Post(s)
Liked 349 Times
I don't get many flats but I wish I had kept some dead tubes now. Will try to remember that next time I get a flat.
But, is there no place to find the strips by themselves besides asking a bike shop to part with a few?
Hard to even find pics of these things but found a few
Quoted: 1062 Post(s)
Liked 665 Times
I use old innertubes for a variety of things, including the aforementioned shims, as bungee straps, and around the pieces of chain that I use for locking up my bikes. It's a wonder material.
Quoted: 560 Post(s)
Liked 546 Times
Quoted: 114 Post(s)
Liked 118 Times
In addition to inner tubes, I buy rubber or vinyl tubing at the local hardware store by the foot. For example, you could buy a foot of 1" diameter, thin wall vinyl tubing. You can cut the tubing to length, then slit/trim the tubing to fit the required diameter. The cut tubing has a natural curl, so it tends to self-wrap. A foot maybe costs $1 at most, and it will last a long time! In fact, I have a handful of short pieces of tubing of varying diameter and wall thicknesses in my garage. Like innertubes, they do come in handy for all sorts or things around the house.
Likes For MudPie:
Quoted: 7287 Post(s)
Liked 2,361 Times
I have a roll of self-fusing silicone tape. Once you clamp it, it won't come off unless you cut it. Getting the thickness right is a little tricky, so better to cut it too small and add to it than to start out too thick. I've really fallen in love with this stuff, because my shims stay where I put them.
