Totally Tubular
#1851
Shifting gears a bit, but still on the tubular tire topic... I purchased a pair of used Dugast cyclocross tubulars at the last Brazen Dropouts swap meet. One tire had some issues with the sewing of the casing (tearing). I got around to fixing that the other day and am now thinking about mounting them on some bike (most likely whatever they will fit). Unfortunately, they have a new-to-me glue reside of some sort. It kind of looks like snot from a bad cold and has the consistency of that adhesive used to affix gift cards at the checkout counter to the cardboard backing - very rubbery, doesn't stick to your fingers. What is it? Is it tubular tape residue or some other type of tubular (or other) glue? Should I attempt to remove all/most of it before gluing the tire to the rim with Vittoria Mastik One? Is it possible something Dugast applied to their tires (I suspect not)?
#1852
Quoted: 1814 Post(s)
Liked 923 Times
Yes, tubular tape residue. Folks pretty much only have good things to say about it. so your situation must not be a problem.
#1853
Bikes: many
Quoted: 1444 Post(s)
Liked 1,394 Times
Thanks. Maybe its superior adhesion explains all the places on both tires where the base tape was separated from the casing. Perhaps even the torn stitches?
#1854
Bikes: 1981 Bianchi Specialissima, 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1, 1950 Hetchins, 194X James Fothergill, 1971 Paramount P15, 1973 Paramount P12, 1963 Legnano
Quoted: 278 Post(s)
Liked 954 Times
I just became the proud owner of some Scheeren hoops built on some nice high flange Campy hubs. I was looking for tubular recommendations for these wheels. My other wheels are a lot narrower so I didn't know if they caused any limitations. From a first look, I think 25's and possibly 28's would fit the bike.
#1855
Okay, I managed to read the entire thread (all the way back to 2005) and did not see any reference to Park Tool's set of instructions on mounting tubulars:
https://www.parktool.com/blog/repair-...-gluing-sew-up
They recommend 1 coat on the tire which they do before the rim. Followed by three (and possibly more) coats on the rim, 24 hours of drying time after the first and second coats. The tire goes on after the third coat is partially dry (60 seconds to a few minutes) and then dries for 24 hours after the tire is installed.
#1856
Quoted: 1951 Post(s)
Liked 2,012 Times
One coat is enough on some tires but others have a base tape that will suck up that first coat and beg for more.
#1857
Bikes: many
Liked 1,394 Times
I think the wide variation in people's approach to gluing tubular tires suggests that there is no one right answer, and that it will be context-dependent (different tires, rooms, used v new, width, etc). On most of my setups (all for the road) I've successfully used one coat on rim and tire, but on my latest setup (wider cx tires, but still on road rims), I wound up with two on each after a mishap on my first ride.
#1859
Liked 923 Times
There hasn't been much input here lately, so here's my latest tire mount.
You may notice:
- concave, dirty brake tracks
- glue strings
- glue on sidewall
- dirty 10 speed cassette
- almost vintage wheel
These file tread tires work pretty well for all around (CX bike)- OK on the street, fine on dirt short of mud, and I seem to have a supply of used ones, so when one gave it up, there was another to take it's place.
Moderate scraping of rim edges with a carving gouge to remove dirty & oxidized glue & remove a few lumps, rub with scotch pad, coat tire & rim with Mastik from a can with brush that lives inside the can, let dry.
Subsequent day coat rim, let dry a few minutes, mount tire, inflate to 45psi, press tire into floor all around, done.
You may notice:
- glue strings
- glue on sidewall
#1860
Quoted: 834 Post(s)
Liked 2,126 Times
I have some Dugast Pipistrello cross tubs with a similar thread--albeit with different shaped and lower profile nubs on the edge. I agree that it's a good multi-surface tread. I find Vittoria road tubs wear out a little quicker than other tires--a tradeoff for a nice, grippy feel. I wonder how those will fair with some road use.
Btw, I've found Brasso (metal polish) to be a good glue remover. Safe on chrome & aluminum. It can leave a bit of a film which should be cleaned of rims afterward. (I think I may have mentioned this once before, but it would have been many pages ago.)
I like the creative use of the hose rack for those tires.
#1861
Quoted: 189 Post(s)
Liked 473 Times
FWIW I just received 4 of the Servizio Corse tubulars from Yellow Jersey for a total of $78.67. Im happy with them out of the box. They wont be ridden more than a couple hundred miles a year. Here they are mounted, but not glued.
#1862
Quoted: 2338 Post(s)
Liked 2,827 Times
your bike space is way to nicely organized
#1865
Bikes: 2005 Seven Odonata (DuraAce /Reynolds),1983 Trek 950 (Mavic/Suntour/Regina), 1986 Stumpjumper Shimano/Suntour/Regina), 1986 MASI 3V, (Campy/Mavic/Regina) 1995 Schwinn LeTour (Suntour/Wienmann/Phil/Shimano/Regina): All Brooks Saddles
Quoted: 25 Post(s)
You talking about that red stuff with which you had to tear off the tire and re-glue every season. That's OK if you have a mechanic. I say good riddance to that stuff. Vittoria Mastic was a god-send. In years of racing, the only time I've ever had to remount a tire, is when it's worn out or flat. And getting em off, even after several years is almost impossible. Although, I do check em before a criterium or road race with technical downhills.
#1866
Bikes: many
Liked 1,394 Times
The Race C Evo3 (26mm) is also on sale, $69.99 per pair. Their site says MSRP is $140/pair. I grabbed a pair to try out.
#1867
Quoted: 1163 Post(s)
Liked 442 Times
#1868
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,836 Times
Asking for you to help me watch Specialized.com
Hey folks -
Please help me watch the Spesh website for any coming sales they have on their top tubulars.
Looking at Allrounder 24mm for the vintage DeRosa, where I prefer a black sidewall.
Hell o th North = maybe, if the reduced price is attractive, but I got a bunch of VeloFlex 27s.
edit= cyclocross now reduced, 33mm with a couple of knobby patterns.
After running these, it made me a believer.
#1869
Quoted: 1608 Post(s)
Liked 2,216 Times
If you want a fast light tire - Vittoria Corsa Speed G2.0 Tubular Road Tire Twin Pack | ProBikeKit.com
Little heavier and maybe fast enough - Vittoria Corsa G2.0 Tubular Road Tire Twin Pack | ProBikeKit.com
#1870
Veteran, Pacifist
Liked 4,836 Times
#1871
Liked 2,216 Times
BBBBBBBut they don't have the Corsa 2.0 in 23 with tan sidewalls!
#1872
Veteran, Pacifist
Liked 4,836 Times
Patience is one's friend in the tubular tire purchasing cycle of financial affordability.
Hence my help request on the Spesh tubular.
I'm running many brands and the narrower Spesh (24mm) was one of the best, worthy of another purchase years later.
#1873
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
Watch eBay. From time to time I come across really good deals. Like Specialized Hell of the North tubulars and/or clinchers for about half price. Also picked up four new Veloflex Vlaanderen for about $30 a tire. Some people try these and decide they don't like them. Or their priorities change.
#1874
Liked 2,827 Times
DiabloScott Pave..... back???? https://www.merlincycles.com/vittori...00c-92388.html
#1875
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
I've got a gift card coming next week - hopefully these'll still be there.
I was afraid I might have to learn to like brown walls and linear tread.
Black / Green Pave CG 111 28" Tubular 30mm $43.75
