Old Suntour drivetrain shifts poorly
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
Hi Bikers,
I am working on a shifting problem with my wife's beater bike, a 1990 Raleigh Assault mountain bike. It is correctly named, because it assaults its rider. But anyway...
It's a 3x6 Suntour drivetrain. It is 6sp indexed, and I haven't been able to get the rear to shift smoothly from low to high gear. The chain skips from 3 cog to 1 cog, and sometimes from 6 to 4 too. I changed the cable and housing, and thought that the shift lever was worn and skipping the gears, but that didn't solve the problem. It shifts correctly from high to low.
Now I wonder if the rear derailler spring might be worn out, or if it's the freewheel, which appears to be a 14-28. I could replace both, but am loathe to put any more money into this heap than I must. It's the bike my wife likes to ride when she's afraid it might be stolen. I should be so lucky.
The RD has a claw mount. If I need to replace the derailler, is it likely that I could mount a non-claw derailler onto the existing claw?
Thanks for your help.
Quoted: 6196 Post(s)
Liked 4,810 Times
You know the chain is not worn out? Some of the rear cogs might be worn out to.
If it's the DR spring, then maybe a good cleaning and lubing with something light will temporarily fix the issue and maybe show that is what the issue is. No other bike laying around you could do a temporary DR swap to see?
Much said is unseen.. pictures would be quite useful..
I've been using friction shifting on my 3 by 6 drive trains for 30+ years now ...
Quoted: 257 Post(s)
Liked 252 Times
Quoted: 1438 Post(s)
Liked 1,092 Times
Attempt to isolate the issue. Try shifting by pulling on the exposed shift cable to see if the derailleur shifts smoothly. If it shifts OK start looking at the shifter and the cable coming off of it. If not, then try pushing the derailleur by hand (watch your fingers!). When you replaced the cable and housing did you replace the whole housing run, including the loop at the derailleur, which tends to accumulate rust and grit?
It sounds like claw might be bent. If its the kind with a normal derailleur mounting, it can be aligned with a hanger alignment tool.
Quoted: 1944 Post(s)
Liked 2,164 Times
IIRC, Suntour thumb shifters had a friction mode. But I doubt that is an issue as the shift lever would move if it is was slipping.
As with others, chain, cogs, RD could be the culprit. Shifting from high to low is done by pulling the cable, low to high is done by RD spring. With a new cable and housing, there should not be any binding, but you might want to make sure it is sliding freely.
John
John
SE Wis
Quoted: 2747 Post(s)
Liked 3,398 Times
Suntour Technical Bulletin #21 "Accushift Problem Solving" in 31 Pages
cassette freehubs are where the action is , now..
IGH are even easier to use all the gear ratio sequences are in a row.
Maeda group & Suntour, as a brand, went away .. decades ago.
the name has re appeared but just making suspension forks for OEM factory builds..
Bikes: 3 road steelys, 3 alu, 1 mtb, 1cx
Quoted: 20 Post(s)
Liked 22 Times
The older suntour accushift rear derailleurs were very sensitive to cable
anchoring position. Since you mentioned chainging the cable and housing
on the rear mech, the cable anchoring point is worth looking at as a
double check.
double check.
Really Old Senior Member
Hi Bikers,
IF it skips 2 when going to a smaller cog (physically), it indicates excessive friction in the cable/housing. You are relying on RDER spring tension to make the shift. Shifting the "other" direction is simply brute force, pulling the cable.
Unless this is a Low Normal RDER.
Quoted: 257 Post(s)
Liked 252 Times
I did replace the entire cable run with Jagwire housing and a good Shimano cable. I find that I CAN get the chain to shift from 3 to 2 if I pull the exposed cable, or put my thumb on the derailler body. But both the old shifter and the new skip right over 2.
Quoted: 257 Post(s)
Liked 252 Times
Which do YOU call "low". The same as the rest of us?
Quoted: 257 Post(s)
Liked 252 Times
Quoted: 257 Post(s)
Liked 252 Times
In checking out some of the tips I have received, I noticed that the teeth on the upper pull are very worn, and were coated with gunk. I cleaned it off, and adjusted the B tension, and got it to work (that is, shift from 3 to 2, not skipping over 2) but it's inconsistent.
As I am reluctant to dump too much money into this bike, I will try @Iride01's suggestion of a thorough derailler cleaning, maybe I'll get lucky.
Liked 4,810 Times
You said your chain is "well worn". If so, then maybe it can't engage the cogs correctly. That can be your shifting issue. And if you've run a worn chain for long, then some of the rear sprockets and chain wheels might be worn too which will also affect how it shifts. So anything else you do might just be a very temporary fix.
Quoted: 257 Post(s)
Liked 252 Times
Quoted: 4208 Post(s)
Liked 3,874 Times
A SunTour equipped bike this old could very well have a replacement freewheel that is Shimano and not ST compatible. There's a reason why ST left the market, add 30 years of age and you have an old system that didn't work best even when perfectly speced. Andy
AndrewRStewart
AndrewRStewart
Quoted: 257 Post(s)
Liked 252 Times
Sometimes I wish I was perfectly spaced.
Quoted: 4560 Post(s)
Liked 2,802 Times
My only bike with Suntour Accushift components is an '89 Centurion Ironman with Suntour GPX 7-speed group. It was tricky getting satisfactory index shifting but switching from the original Suntour chain and freewheel to KMC Z72 chains and SunRace freewheels did the trick. The SunRace MFR30 (13-25) MFM30 (13-28) chromed freewheels are very good and work equally well with Suntour and Shimano groups.
However I haven't tried any 6-speed stuff so I don't know which SunRace freewheel might be comparable.
If you're still using the original Suntour chain, replace it with a decent KMC chain. The Z72 has been renamed, no idea what the current name is. But any compatible chain will be an improvement. I was surprised by how crudely made the original Suntour chain was. Most of the Suntour group was fine but the chain was junk.
Likes For fietsbob:
Quoted: 257 Post(s)
Liked 252 Times
M
Likes For BCDrums:
Liked 2,802 Times
My LBS still allows in store shopping, with limits to two or three customers at a time. I visit about once a month just to buy something and show a little support. I usually buy a couple of tubes, maybe some snacks or electrolytes, chain lube, whatever consumable doodads they carry. Occasionally the LBS sells sample demo products, which are labeled "not for retail sale," but I buy 'em because it's usually half price or cheaper and presumably a high profit item for the shop. Seems fair. I got some great deals on mini pumps, gloves, handlebar wrap, etc., buying samples marked not for retail, after the promotional period was over or the product was discontinued. Hopefully the shop made some money. I got a good deal.
Most of my bike purchases this year have been online, usually stuff the LBS doesn't stock anyway. For example, the LBS carries some high end Continental tires but not the cheap Ultra Sport II and mid-priced GP Classic skinwalls I like.
Likes For canklecat:
