Question about 1st gear
I know nothing about gear ratios, etc., but I've noticed that on my 7-speed there's a huge difference between 1st and 2nd gears, while gears 2 through 7 seem to progress quite gradually. On visual inspection it certainly looks way huge compared to the other gears. Is this a normal feature of multi-speed bikes?
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
You may have a "mega-range" freewheel. They are less common than more evenly spaced gears. They are usually used by people planning to go up some very steep hills, or for touring with cargo. Gears can be fairly easily changed if you want a different range.... You just need to make sure you get the right type for your specific bike.
Quoted: 1572 Post(s)
Liked 643 Times
Count the teeth on each cog and report back to us.
Yea, that is the basics t# on crank turns t#on wheel in a simple math ratio
example 40:20. is [reducing to simplest fraction] 2:1. front goes around once wheel rotates twice.
Bikes don't actually have a first gear, second gear etc. progression the way cars do. You don't necessarily start in your lowest gear and go through all the others on your way to the top. Try starting in the second- or even third-largest cog, shifting where you need to from there and save the largest cog for hill-climbing. Someday you'll be glad you have it.
