Looking for a wheelset upgrade
Day Rider
Bikes: Specialized Roubaix
Quoted: 15 Post(s)
Performance Wheel for heavy rider
Looking for a better wheel for my Roubaix SL4 Expert. Currently running DT axis 4.0. I am riding about 125 miles a week in mixed flat and rolling hills. Trouble is I weigh around 235 and I am having a hard time finding something that may support me. I have thought about having something made up but would prefer to have a factory warranty. My preference is for a non aero rim but would really like to have everyones input.
Does anything exist that is <1600gand still durable in this class? My budget is between $1000 - $2000. My most recent 20 mile ride had a 17.1. No land-speed record but i was really pleased. Thanks.
Bikes: Specialized Sirrus Comp
I have the same exact bike (in the black/grey/blue) combo and the same weight. I went custom. Chris King R45 hubs, Velocity DeepVs. Bombproof.
Bikes: Domane Project One, 6 series, Ui2
Quoted: 10 Post(s)
Shimano C24 Dura Ace. Just got a set of the 9000 tubeless ready. Under 1500 grams, very stiff, no weight limit and a 3 year warranty.
got the climbing bug
Bikes: one for everything
Quoted: 632 Post(s)
Liked 913 Times
with that budget I'd get a set of Mavic Carbone SL $1200 and a set of Spinergy PBO xAERO lites $450. Don't forget 2 cassettes, or use the old one + new one.
Rule #10 // It never gets easier, you just go faster.
SuperGimp
Why on earth would you spend $1,000 to $2,000 for non-aero rims? I'm assuming you mean "carbon" when you say "aero" because 30mm aluminum rims aren't really aero.
Boyd will make you a nice set of carbon rims for well under your 2k limit and from all the comments on the road board, he'll support you too. Personally, I'd rather have some guy protecting his good name than some corporate warranty. Having said that, I have a set of Easton EA 90 SL wheels that have been very solid for me from 245 down to 215 and they're under your weight requirement too (1500+ g or so). I also have a set of wheels that weigh in at about 1900 g and frankly, I'm not sure I can tell the difference, even on mountain roads.
What are you trying to achieve with new wheels? Bling? Light weight for mountains? Durability?
Congrats on your speed record by the way.
Quoted: 10 Post(s)
No flexing or creaking that I can notice, I've only got about 500 miles thus far. They're replacing a set of Fulcrum Racing 1s, they were good wheels but I broke 2 spokes in a year of riding and the spokes are hard to find and $15 each! The C24s are much stiffer.
SuperGimp
Bikes: Specialized Roubaix - Soma Double Cross Disc - Pivot Mach 429SL - Canfield Brothers Yelli Screamy - Specialized Carve SL - Trek Farley 7 - GT Dyno VFR
I am in the same boat. I currently ride some low spoke count Alex wheels and consider myself lucky I haven't broken anything yet. The stock wheels (Mavic CXP22) are heavy and slow so I put the Alex wheels on from another bike. I am still a noob, but ignorance was bliss. Now I worry every time I ride that bike. I've been gathering quotes for custom since it is hard to find "standard" wheels rated for fatties. I want something alloy and deep, so my search would not help you much. I have a much lower budget too.
Quoted: 632 Post(s)
Liked 913 Times
^^ budget wheel build, I'd do something like Ultegra hubs, Kinlin XR300, DT double butted spokes w/ brass nipples for about $250
I like the newer 23-25mm wide rims for their greater air capacity and potential handling properties. I love the looks and strength of deep 40+ section rims like the H Plus Son 42s on my commuter. Weight is not as much of a concern for me.
For the OP, contact www.psimet.com he will give you recommendations and a competitive price.
Quoted: 632 Post(s)
Liked 913 Times
the velocity A23s are nice rims. The idea behind the wider rim isn't for more air, it's actually to run less air and get a more tubular tire feel through the bike and handling. My buddy has those A23s on king hubs and they ride super smooth around 85psi front and 90 rears on 23c tires
A square going nowhere
Bikes: CAAD 8 & CAAD 10
I was riding Easton EA50's but they tend to flex a bit, especially since I've put some weight back on. Right now I'm riding on DT Swiss RR585, 32 spoke 3 cross laced to 105 hubs. I'm really happy with them. Super stiff wheels. Got them for about $350.
As a 115kg clyde, I really don't concern myself with sub 1500grm wheels. Such wheels, if I owned them, would be event day only wheels. The most important characteristic to me for day to day riding/training wheels is that they remain true and are reasonably maintenance free. Subsequently I'm currently running DT Swiss 585's laced to Ultegra hubs and am extremely happy with that combo.
However, if one were to inform me I was being given two sets of free wheels (one training, one event day) and that budgets were not a consideration, my builds would look something like this:
Everyday wheels: Cycleops Powertap or Chris King R45 rear hub, Chris King R45 front hub, HED Belgium C2 rims or if they would do them for me a custom drilled set of Zipp 101's, the HED rims would get laced with a pretty typical double butted combo of spokes and brass nipples. If Zipp drilliumed the 101's for me, well, then I suppose I would have to have some bladed spokes on those, but, probably still brass nipples.
Event day wheels: Hmmmm, hub choices remain the same. But, the rims would probably be some moderate depth carbon clinchers from either Zipp or Enve.
The everday wheels could easily be built up within your budget. If having a lighter bike is going to motivate you to ride it more often, Great. Get some of the cheaper, deeper carbon clinchers. But, if you're like me, I've realized the most important thing to increasing my performance is riding and training as much as possible and that requires a durable bike that is ready to ride every day. And that leads me to wheels that provide me with the minimum of headaches.
Birth Certificate, Passport, Marriage License Driver's License and Residency Permit all say I'm a Fred. I guess there's no denying it.
Day Rider
Quoted: 15 Post(s)
I think i am going to get a Boyd Cycling Vitesse clincher with 24/28 spoke to carry the weight. Anybody have any experience with these?
Thinking about wheels like those. Boyd rates them to 240lbs. Given your budget, you could also consider Zipp 101's. Which have even fewer spokes and less weight, but, which they rate to 250lbs. Just a thought.
With regard to tires: At your weight I would certainly opt for the 25s. I can't imagine avoiding pinch flats on the 23s unless you pump them beyond their recommeded max pressure. I would even go 28mm if there is clearance for them on your frame and fork.
Bikes: Firefly custom Road, Ira Ryan custom road bike, Ira Ryan custom fixed gear
Quoted: 9 Post(s)
Well, the budget should allow plenty of options.
I'd choose rim, hub, spokes and builder. For me -- Ambrosio FCS 28s (amazing, crazy hard to find in the USA -- deep Vs, much higher quality than Velocity). King r45s (flashy, make a fabulous noise, very expensive and durable) and Sapim C-Xray spokes (bladed) 3x 32. And a local builder you can actually talk to.
Other options -- hubs: White Industries is worth a look, as is Dura-Ace. On rims, DT RR585 (I have a pair).
Your budget is more than enough.
SuperGimp
mr reality - loads of people on the road forum (aka the 41) seem to enjoy the vitesse wheels. Apparently they changed the design this year for the better too.
Somehow, putting triple butted spokes on as light a rim as the A23 doesn't sound balanced to me. Initially I thought, "perhaps triple butted would be warranted on a Synergy/OC". But, then I went and looked at the specs and the Synergys aren't that much heavier and they are more of a box section, lacking the shallow V of the A23s. So, perhaps you're on to something with this combo. I can understand your concerns at #310 . Just feel as though, if you're an aggressive enough rider to be unweighting spoke elbows enough to warrant the 13ga./2.3 elbows you should probably also be on a more durable rim. If these aren't going on a cross bike and you're not that aggressive, you're absolutely correct. They should hold up. At least with regard to the spokes they're probably overkill.
I'm tempted to put 23c on the A23 just to see the difference the wider tire profile makes, and maybe I'll do it briefly, but I agree that 25c (maybe even 28c) are probably the smart choice for the long term.
I like what Adrien is saying about picking a builder and components vs a factory built wheel. For the stated budget there is no reason a really good builder couldn't be employed. My experience has been that I can far better tension balance a wheel than any I've seen come from a factory. The industry standard is +/-20% , mine is +/-<5%.
With regard to durability, I strongly believe that even and appropriately high tension are a huge, if not the largest, contributor.
If I were going to push the boundaries of weight and spoke count for a heavy rider, I would most certainly want to ensure that the spokes were as evenly tensioned as possible.
Quoted: 632 Post(s)
Liked 913 Times
zipp 101 are stupidly priced for alum 30mm rims and still not lighter then most of the market share.
Certainly can't disagree. However, they are somewhat unique in their shape. The whole toroidial deal, for whatever that's worth. Heck, with the OP's budget and the fact that he's not necassrily insterested in aero, he could be looking at Ksyrium SL's as well as a bunch of other reasonably light factory wheels.
