Trying to work out wattage and what a standard road bike requires
Quoted: 680 Post(s)
Liked 949 Times
Ok I just got a new display on my Ebike that lets me see what wattage I am imputing compared to what the bike is providing. I only had a short ride and I was only feeling so so and just got my bike back from the dealer from the upgrade. tomorrow morning will be better as a test. as I get healthier I use less and less assistance. I am stuck between the next to lowest level going too fast with it but the lowest is a bit too low to maintain my speed. I think it is 100% verses 25% I want to keep track of how much power I am putting out and my heart rate. my bike is heavy 53 pounds and 1.5" tires so at the lowest level of assist hard for me right now to maintain 22mph. I am wondering how much wattage does it take to keep a road bike at 20 mph if someone weighs 250. that would be pretty close to me and my bike weight . at least now I will have a better idea of how many calories I am using. here is my first ride. I will hook up my HRM tomorrow and really get a better idea.
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
You went 6.68 miles averaging 15.6 MPH and burned up 189 cals. The cals seems low for the speed/distance/weight. It seems it should be closer to 48 cals/mile. Just my $2 worth.
Quoted: 2952 Post(s)
Liked 3,106 Times
I’m not sure what the question is. Are you asking how much power it takes to do 20mph on a standard road bike? I’m assuming no wind and flat ground, right?
Looking at some Strava segments where I averaged 20mph, I would say 225 +/- 10w. This is on a Tarmac with 25mm training wheels and tires. Note that weight of the rider doesn’t make much difference on a steady interval on a flat road, so yours might be a little higher but not by much.
Likes For caloso:
Liked 3,106 Times
Non omnino gravis
Quoted: 680 Post(s)
Liked 949 Times
according to the bike I did 30% of the work. I will ride better today and get a better idea. this is my commuter bike so its s all city riding so lots f starts and stops. I have one way I can go to work where I can get a lot more even riding in the 9.5 miles of my commute. This s a e bike with a mid drive. the harder you push the more the motor helps to some extent. I am working to use as little assist as I can and still manage the 30+ miles I ride a day every day. my usual average through town is about 17.5 mph and on the bike path 18 to 19 mph if I push it. Now I can really knowhow much I work compared to the bike.
I may be riding bit much I get 20 to 240 miles a week and a minimum of 30 miles a day. the bike as flat bars and I am at about 60 degrees so a fair amount f wind resistance when you cruise at 22+mph.
Quoted: 680 Post(s)
Liked 949 Times
Quoted: 590 Post(s)
Liked 445 Times
Power meter pedals, or a crank arm power meter, will empirically answer the OP's question.
This calculator estimates 230 watts is the answer to the question Bike Calculator
Quoted: 680 Post(s)
Liked 949 Times
Quoted: 590 Post(s)
Liked 445 Times
For comparison, the calculator shows that simply changing position from the hoods to the drops gains you 37 watts, or 1.5 mph. Aero is everything, once you're above 17 mph.
Likes For Riveting:
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
I designed the product inspection test skid for Fallbrook's e-bike IGH combo electronic cadence control unit years back. When we went to commission it in Austin, they had us ride e-bikes to lunch with their stuff on it.
The % assist you could ask for to me seemed to work really really well. Like, it wasn't like a 4-position selector switch. It really felt like it had a good working range of assist.
I would investigate why your bike is having trouble with the granularity of the assist level it is providing. That could really improve your user experience and data you're looking for.
But, for road bike, I'd say that wattage of over 200w on flat for 20mph would be probably on a pretty non-aero setup on standard tires. I ride a pretty aggressive setup road bike and I do rides that average 20mph with 60 feet per mile elevation on only about 205w or so AP. Then again, my Stages power meter is probably junk.
Quoted: 6195 Post(s)
Liked 4,810 Times
A regular bike that weighs 40 pounds or a regular bike that weighs 17 pounds?
Maybe what you should look at is what other riders do on similar routes with non electric bikes. That will be the wattage that is needed to move them over that route at their combined weight of bike, equipment and their own weight.
It already sounds as if you can figure out what wattage you are putting into a particular route separate from what the bike gave you. So if you are wanting to compare your effort to another cyclist without an E-bike, then you have the number you need.............. I'd think!
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Likes For rubiksoval:
Liked 3,106 Times
I don't know how ebikes work but it seems to me that if it has a torque sensor built into the crankset so it can figure out how much boost to give, then it can certainly figure out how much power the rider is putting into the system. 135w sounds reasonable.
Liked 3,106 Times
I have less aero gear (base model Allez with stock wheels) and on recent rides I did outdoors in a flat area near my parents' home, some segments of 20mph had me putting out 225-241w (I weigh about 160ish), and it seems like around 200w keeps me around 19mph, but that's just a really quick glance at a few segments that average %0 gradient over the course of a few days. Maybe I should get a hold of some more aero wheels and see what I could do with those lol
Likes For hubcyclist:
Quoted: 680 Post(s)
Liked 949 Times
I goofed up and erased my ride this morning I guess or it only syncs once a day don't know for sure. . but I was doing about 190 or so watts and it was not too hard to do I could maintain it. 225 was not bad but I could not go the whole ride like that.
ok here is my morning ride a little slower then usual but not too bad. Now I can see how much power i can put out. I just realized it does nto include my average heart rate. How does heart rate effect calories. looks like my garmin is only 50 calories off but it does not get the wattage output.
Quoted: 680 Post(s)
Liked 949 Times
Quoted: 680 Post(s)
Liked 949 Times
That looks like it's within the ballpark of the data that rubiksoval, burnthesheep, and I all gave.
I got the e bike so I could ride at all and slowly I am working harder and harder. I watch way too many people on their fat tire e bikes hardly peddling at all. I want to get exercise and I am proud I can ride 30+ miles a day.
Bikes: bikes
Liked 1,429 Times
yes mine works with a torque sensor so the more power you put in the more the motor kicks in till you start going faster my wattage starts to increase a fair amount above 22mph. now my speed on the same assist level on flats has creeped up to around 24. usual;y the nI hit 22 and could hold it with not much effort I would drop down a assist level. but thats too big of a drop now for me to maintain . but I will get there. now the nI have a good bike path and need to get to work I may crank up the assist a notch and cruise at 26mph. now I will be able to see the wattage on that.
If you want to work hard, get a bike without pedal assist. At those speeds, you're a danger to everyone, yourself included.
This is the problem with e-bikes for some people. They write checks that the riders' don't have the skills to cash and the common sense to use appropriately.
Quoted: 680 Post(s)
Liked 949 Times
Using pedal assist to go 26 mph is ridiculous, ESPECIALLY on a bike path.
I work as hard as my body will let me. since nov I ride 20+ miles a day and since the last three months its been 30+ miles a day. 220 to 240 miles a week. since nov I have put 5200 miles on my commute bike and 1600 on the tandem in 3 months. I think that's pretty dam good.
Bikes: bikes
Liked 1,429 Times
I only do it when the path is clear. at 6:30 in the morning it usually is. I have had roadies follow me. and sometimes pass me.its wide paved path. I don't take chances. but I I don't usually need to go that fast. and riding without power does not give you more of a workout unless you can put more power into the ride then you normally can. I put as much effort in as I can so riding without power would not be be a better workout it would just be slower. if I ride without power I cant do 20 maybe I can do 15. I commute 25 miles a day going faster saves a lot of time. Yes I keep it safe I don't don't do crazy things.
Obviously you can think that's good if you want. I think it's a farce and a danger.
Liked 3,106 Times
And I totally agree with RS about riding an electric bike on a shared path.
Likes For caloso:
