Go Back  Bike Forums > Bike Forums > Framebuilders
Show us your builds
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
Show us your builds
Old 11-16-10, 10:49 PM
  #101
hellojoben
hellojoben's Avatar
Bikes: '83 Specialized Sequoia (crashed and retired), '85 Specialized Allez SE, '86 Specialized Stumpjumper, 2016 Ritchey Road Logic
Quoted: 25 Post(s)
Liked 19 Times in 5 Posts
wow. I have so much respect for the framebuilders out there.
If any of you guys are in need of an apprentice and live in Los Angeles let me know!
hhaah
hellojoben is offline
Old 11-21-10, 07:18 PM
  #102
stanridgespeed
Bikes: Too many to list
BB30!!
bb30 by stanridgespeed bicycles, on Flickr
stanridgespeed is offline
Old 11-22-10, 04:57 AM
  #103
ultraman6970
Guys have a question, after you guys have brazed, basically each brazing point needs to be put in some like ACID to clean all the impurities off the steel. Some people uses battery acid but doubt thats green at all, what you guys use**********?? There is something non toxic that can be used at home for example?
ultraman6970 is offline
Old 11-22-10, 05:28 PM
  #104
Six jours
Liked 13 Times in 13 Posts
I use a special solution made up of two parts hydrogen to one part oxygen. It's generally thought to be benign to humans, but in very large quantities it has been linked to numerous human deaths, so caution is justified. I find it especially helpful to use the solution while it is in a relatively excited state, so if you can find a way to add energy to the compound, flux removal will be hastened.
If you're unable to find a source for the compound, hot tap water may work too.
HTH!
Six jours is offline
Old 12-06-10, 06:45 PM
  #105
mudboy
mudboy's Avatar
Bikes: Ruckelshaus Randonneur, Specialized Allez (early 90's, steel), Ruckelshaus Path Bomber currently being built
650b wheeled path bomber, sloping top tube, 73 parallel, 425mm stays.
mudboy is offline
Old 12-06-10, 08:01 PM
  #106
stanridgespeed
Build sequence on Flickr
dec6.10 by stanridgespeed bicycles, on Flickr
dec6.8 by stanridgespeed bicycles, on Flickr
Hey guys im documenting a build for a client. the build starts at DEC3. Any questions? Dont hesitate to ask!
Old 12-06-10, 08:20 PM
  #107
Allen
Liked 10 Times in 9 Posts
Adam, may I ask you to start a thread on this build?
Even if it's just a sequence of images. Good stuff.
Cheers,
--A
Allen is offline
Old 12-20-10, 02:04 PM
  #108
IRONCROFT
wow there's some beautiful stuff posted up on here,
here's my fledgling first effort
58cm square
Columbus Zona tubing
brazed with 55% silver rods using using a rothenberger superfire 2 MAPP torch
one coat rattle can black paint job
1 low res by adam.haycroft, on Flickr
2 low res by adam.haycroft, on Flickr
3 low res by adam.haycroft, on Flickr
4 low res by adam.haycroft, on Flickr
5 low res by adam.haycroft, on Flickr
IRONCROFT is offline
Old 01-02-11, 06:22 PM
  #109
bikecopXXX
Bikes: steel ones
ironcroft, that looks pretty nice. how does it ride? did you use a jig?
bikecopXXX is offline
Old 01-02-11, 07:37 PM
  #110
mudboy
mudboy's Avatar
Man, my second build is turning out to be more error-filled than my first. Of course, I'm doing almost all of the work on my own, but still...
* Need to go back and re-braze 2 bottle bosses because of gaps
* Gap in the top of the seat lug needs to be filled
* Gaps in 2 places on the top head tube lug need to be filled
* Mis-measured when I cut the chainstays, bringing them in to 417mm instead of the originally designed 425mm. Still have clearance, but still.
* Fit the brake bridge with 132.5mm dummy axles in place (I have a jig that fits on the dummy axle to locate the bridge), when the spacing is going to be 135mm. So, it's either put the bridge 2mm or so higher up on the stays, or get another and re-do. Still gives me plenty of brake adjustment, but still...
* Hit one fork blade (1.1mm) with the file the wrong way, leaving a slight divot
* Used too-thin sheet steel (21ga, I think) for my semi-wrap seatstay caps, so they're slightly distorted.
* The double eyelet fork ends didn't fit in the blade raker, so I had to cut one off of each.
* The headtube cable stops kept the frame from fitting properly in my mentors home-built jig, so I had to cut them off.
On the plus side, this is going to be a pretty utilitarian frame for riding to the store and riding around the neighborhood with my kids, so none of these issues are really critical, but still, my first frame went so well that I had some pretty high hopes for number 2. Also, I'm really going to be the only person who's going to notice any of these issues, but still...
Pete
mudboy is offline
Old 01-02-11, 07:38 PM
  #111
stanridgespeed
Cheers,
--A
Allen, In the swing of things again after the holiday season! I sure will do it if you'd like. I'm constructing the fork tomorrow.
Old 01-02-11, 07:44 PM
  #112
stanridgespeed
hey mud! Whats up bud. Don't get discouraged. Why did you drill a hole in the TT above? Heat escape? It may be easier if you drill it in the ST under the lug junction..save a bit of time ya know..
Old 01-02-11, 07:49 PM
  #113
mudboy
mudboy's Avatar
Yeah, it's a vent hole, I'll put a drop of silver on it once I get the cable stops on. Next time around I'll probably drill a small hole in the headtube where it intersects with the top tube, unless the seat tube is a better choice.
mudboy is offline
Old 01-14-11, 06:34 PM
  #114
stanridgespeed
THE HIGHSTREET PURSUIT by stanridgespeed bicycles, on Flickr
Old 01-15-11, 06:52 PM
  #115
Six jours
I'd be afraid that the seat would slide my customer into the steerer tube, possibly catching on one of his facial piercings.
Old 01-15-11, 07:25 PM
  #116
IRONCROFT
I’m still chuckling a bit from six jours comment,
I love this bike I think you should build a combined stem and aero handle bar for it,
What tube set is this?
Did you have to form the clearance cut-out for the back wheel in the seat tube or do the tubes come like that?
Old 01-22-11, 08:40 PM
  #117
scbvideoboy
scbvideoboy's Avatar
Something a little different...my homebuilt FWD tadpole recumbent trike. On this prototype the front and rear frame sections made out of 4130 cromoly and the center part is aluminum. I did all the fabricating and machining including the internal differential.
Two powdercoats colors and some chrome as well. The next "production" trike will be all aluminum with selected areas for chroming and more!
Dave aka scbvideoboy
scbvideoboy is offline
Old 01-22-11, 10:31 PM
  #118
Allen
That's seriously impressive.
Allen is offline
Old 01-23-11, 06:33 PM
  #119
Six jours
The upper picture makes my brain hurt. And right in the middle of the most complex machine this side of the Large Hadron Collider sits a Super Record derailleur!
Old 01-23-11, 07:41 PM
  #120
mudboy
mudboy's Avatar
Wow, that's awesome. Almost awesome enough to make me consider riding a 'bent. Almost.
Finished frame 2 this week. It was a bit of an experiment in design, I wanted to build a 650b shopping/gravel path bike, but I also wanted to be able to run 700c wheels if I didn't like 650b. Geometry ended up at 73 parallel (though the seat tube looks slacker due to the sloping TT), 45mm rake for something like 56mm trail, 68mm BB drop (frame 1 was 75mm), and 417mm chainstays. They were supposed to be 425mm but I f*cked up. Anyway, pics with wheels and headset installed:
650x42mm:
700x28:
Of course, I'd need to use different brake calipers when I do the wheel swap, but I have the SRAM Apex calipers that came with my new group, and I bought a set of Tektro long reach for use with 650b.
I trimmed the seat tube, shaped the seat lug, and cut the slot over the weekend. I've got some minor cleanup to do with cloth and file, and then it's off to Fresh Frame for a coat of gunmetal grey metallic paint.
Complete album.
Pete
mudboy is offline
Old 01-23-11, 11:58 PM
  #121
rodar y rodar
weirdo
Liked 3 Times in 3 Posts
Haha! I bet your brain doesn`t hurt as much as his did while he was trying to sort things out! I semi followed his build on BROL, so I know it was definitely a challenge.
Good job, SCV- I`m glad you finally get to reap the fruits of your efforts!
rodar y rodar is offline
Old 01-24-11, 07:28 AM
  #122
bikecopXXX
Bikes: steel ones
that's a trick trike, scbvideoboy. does the rear wheel have suspension also? is there a sliding spline somewhere in that drive shaft to handle suspension movement? i couldn't spot it. nice work.
Old 01-24-11, 07:29 AM
  #123
scbvideoboy
Thanks guys!
Is that a good thing?
The 7 sp freewheel is NOS so I used stuff lying around. The "NEW" trike will have a Shimano cassette freehub mounted on the diff. Looking forward to Dura Ace 8/9 sp setups!
Under the rubber boot next to freewheel, sliding ball coupler...similar to the inside of a inboard CV joint on a FWD car.
Dave aka Scbvideos
Old 02-04-11, 02:46 PM
  #124
zjrog
Bikes: 1986 KHS Fiero, 1989 Trek 950, 1990 Trek 7000, 1991 Gary Fisher Hoo Koo E Koo, 1992 Trek 1400, 1997 Cannondale CAD2 R300, 1998 Cannondale CAD2 R200, 2002 Marin San Rafael, 2006 Cannondale CAAD8 R1000, 2010 Performance Access XCL9R
Quoted: 284 Post(s)
Liked 385 Times in 207 Posts
HTH!
Yes, DihydrogenMonoxide... Use carefully.
zjrog is offline
Old 02-04-11, 06:50 PM
  #125
Six jours
As far as I'm concerned, it's a great thing!
