Can I preserve this frame without repainting?
Hi all
I am in the process of cleaning up this bike and I would like your advice on the frame. The whole bike was rusty in places but it has cleaned up OK. I have a couple of spare wheels I can put on and a freewheel I can make do with for now. I want to clean up the rust on the frame but I can't repaint it at the moment (or ever as I have no idea how!). Is there a way to protect it once I clean it up?
I will at some point sort out the wheels and freewheel properly so I could maybe do something ore substantial at a later date. I do love the bike and I actually like the colour so I want to stop it deteriorating any more.
Thank you as always for any help.
Gill
The rust is spotted all over but especially under the top tube.
Some parts are relatively rust free
Gill
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
Op,
Google oxalic acid bath, Bikeforums and see what others have done to clean the rust from their bicycles. After cleaning if you want you could then use a clear coat spray to seal the frame and protect the paint...of course you may want to treat the interior of the tubes etc.
In my estimation, it may not be worth all of the effort...I might just use a good paste wax on the exterior and enjoy riding the bike, the tubing on this frame is thick enough to outlast the owner.
JM2C's, Ben
JM2C's, Ben
Likes For xiaoman1:
Thank you!
Gill
I would use a rustconverter on the rust spots (Rust-Oleum or here in Europe Brunox is well-known). It seals the surface and chemically reacts with the rust to make the rust primed and ready to paint over.
First remove all loose paint, chips and loose rust and degrease the area, apply rust converter for 2 layers, then use a touch up pencil in the closest matching colour you can find. If it's a metallic paint then it's best to seal with a clear coat (also available in touch up pencils). You can always wet sand the first layer of paint with 800 or 1000 grit to get a better finish.
Quoted: 753 Post(s)
Liked 737 Times
I've been meaning to give Ospho a try to stop the rust, and then paste wax over the converted rust.
Quoted: 1372 Post(s)
Liked 1,752 Times
Some of us who collect and ride vintage road bicycles have come to appreciate a bicycle's patina of age. Sure, it is just great to have a freshly painted steed and that is great if the frame chrome and components match the freshness. So, option one is to forget paint, touch up any bare metal on the frame with paint or nail polish and then ride the bike. If you wish, you can paint it anytime but first, it is wise to ride the bike and make sure that no frame work is required.
I painted this old Peugeot with Rustoleum and a paint brush, believe it or not...
And this old Legnano, though sorely in need of paint, has been with me for a long time. I have come to appreciate the appearance and it is not deteriorating in any way, as nearly as I can tell. I might paint it someday but not today...
Quoted: 811 Post(s)
Liked 1,024 Times
Nice bike. I like the racks, fenders, lights and cantilever calipers. Thanks for the pictures Gillparis . A lot of our members use nail polish to touch up the chipped spot. The best method would be to remove the surface rust first, then apply the nail polish. I use paint that is intended for models, Testors brand to be specific. I have to mix several colors together to get to the right color. Some attempts are better than others with this method, but a color match that is close, looks better than rust spots.
The other suggestion is to just wax it with an auto wax. It will keep it looking better than it does now and prevent it from getting worse.
Keep the pictures coming as you progress though the paint and wheels.
Disraeli Gears
+1 on oxalic acid bath and wax. If you don't care to completely disassemble the bike and give the entire frame a 2-day bath in OA, then just clean it up and wax it.
Quoted: 355 Post(s)
Liked 345 Times
If you have access to a product like Evaporust here in the US, it is a very good slow rust remover. Search for some of the threads on how to use Evaporust like products and how to build a temporary shallow "pool" that uses the minimum of fluid while getting the most frame exposure. After that, a good rinse and cleaning, followed by some framesaver if needed.
Italvega and Torpado Enthusiast
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times
I recently did some work on an old 80's Peugeot and used Krud Kutter rust removal on the small rust spots and then filled in with Testors paint. The colours weren't an exact match but not noticeable unless you look closely.
Quoted: 472 Post(s)
Liked 1,028 Times
I rehabilitated an 84 Fuji TS III last winter. Many rust spots but all surface stuff from wear n tear. I used an OA bath for most of it and navel jelly on the seat tube and HT. I then applied boiled linseed oil (aka BLO) to the whole thing, numerous thin coats on the larger areas of open steel (ex: rear dropouts where wheel removal had scratched away the paint). It's a "clear coat" but may add a wee bit of yellow/amber tint. I cannot see it. I'm a fair weather rider so this bike has not seen rain yet but I've seen BLO protect hand tools and garden tools well.
It used to be a common treatment of steel prior to advancements in petroleum based paints. Still useful for old farts on their black smith vices, pry bars, sledge hammers and obsolete steel safety bicycles.
Thank you all. Whilst I would love to soak it I live in a flat with a small child and I don't have the room on the balcony (plus I already stained the tiles once so that will be a nice fine when we move!). So I will work my way over it cleaning it as best I can then use some rust converter for the rest. The chrome is all in good condition. I will post photos as I go but it may be some time as I can only do bits at a time - it just took me three weeks to do the rest of it .
I am impressed by the painting jobs on show here 😊.
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 685 Post(s)
Liked 370 Times
I have had good luck with “Navel Jelly” which is stronger and nastier than evapo-rust but you can dab it on with a cotton swap, wait an hour, and wipe it off. You can do a little at a time, and it’s effective. I would use it on that balcony, you don’t want to breath it in.
Once you’ve spot cleaned the rust, you can paint a little clear nail varnish on the metal, and coat with a good paste wax.
Thanks all! Tomorrow is my day to do this so I will let you know how I get on.
Anyway it looks much better and has to be in a better situation than it was! It is still in pieces but I will put a photo when it is back together.
Thank you!
