Origin8 PRO Pulsion SINGLE Hub rebuild
Knotty Guy
Looking for diagram to rebuild a Origin8 PRO Pulsion SINGLE Hub. I feel a little rougness in the bearing on one side of the hub and want to take a look to see if it needs a new bearing.
Can not seem to find out how to dissassemble the hub. Mine look like this. There is little set screw on each side.
https://www.origin-8.com/images/new_400/37273.jpg
Guest
Posts: n/a
Quoted: Post(s)
thats a sealed bearing hub. The caps on the end should be a press fit over the axle, and the bearings are seated in the hub shell via press fit too.
theres not much 'rebuilding' that you need to do- just slide off the end caps, push the axle through one end and remove the sealed cartridge bearings. Sealed bearings are widely available through the LBS or any bearing house or industrial supply catalogue. Every sealed bearing has a model number on the seal.
Knotty Guy
Thanks for your reply.
I knew they were sealed bearings, I was just trying to figure out how to get to them. Do I losen one set screw and tap the axle out? I did not want to force anything until I knew more.
Is it possible to shorten the covers by 2mm with or without the use of a lathe?
I have had my Viscount hubs apart, where I just had to tap the axle out from one side (which removed the axle and one bearing). Then install the axle sans bearing and tapped out the other bearing.
Tom
Tom
GONE~
https://projekto-b.blogspot.com/2008/...-bearings.html
That article is helpful to learn how to replace cartridge bearings.
Knotty Guy
The one in the blog is how I dissassembled my Viscount hub. The Origin8 single does not have any exposed nuts. There is a long bell shaped cover on each end with a little nub of an axle sticking past the cover. Cover has a set screw (which I assume helps retain the cover). Axle can take quick release skewers or bolts screwed in from the ends.
I did not know if the bell shapped covers were screwed into the hub in any way, or are they just held onto the axle by friction (i.e. press) fit.
Tom
Tom
Knotty Guy
I completely removed the set screws and they do not seem to do any retaining. Heck, they were not really even very tight. I wonder if they are there as a backup just in case the press fit ever became loose.
Tom
Tom
TallRider
Bicycle Mechanics
7
02-16-17 11:23 PM
OldRoadman
Bicycle Mechanics
4
06-14-11 09:53 PM
