Proper Winter Tire Pressure
I ride a hybrid 12 miles to and from work. The trails are pretty icy right now here in Minnesota and last night I bit it pretty hard. My rear tire just swept out from under me and down I went. When I was explaining this to my friend he asked me what my psi was at. I usually keep my tires properly inflated. The max psi on my tires is 75 so I guesstimate that it was between 65 and 75 psi.
He suggested that I should deflate my tires for better traction. I understand the mechanics of this but I'm already commuting an hour and 20 minutes in the winter (slower than my summer time of one hour). So I hesitate to take air out of my tires and reduce my speed even more.
I don't currently have winter tires. I have 700x32 tires. They're the stock tires that came with the bike. I know I should upgrade but there's a laundry list of things that need to happen before I can spend money on winter tires. So for now, I'd like to just work with what I have.
Any suggestions? Do other more experienced riders deflate their tires? If so, by how much? I've been riding since July. This is my first winter. Any advice would be greatly appreciated.
Yeah, it's icy part of the way, snowy part of the way and the last leg I can ride on cleared roads (about 2 mi). So I'm just not sure there's a solution. I don't want to be riding on pavement with studded tires, right? I think I'll just have to be careful and be ok with an occasional spill.
I put my studded tires on in December, take them off in March, and never think about them. The good ones have tungsten carbide studs that wear at the same rate as the rubber and consequently last for three or more seasons. I don't dink around with pressures. I pump them up every two weeks and that's it.
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 160 Post(s)
Liked 134 Times
If you're riding on ice without good traction your speed will be reduced by caution or injury. Might as well get studded tires: yes, you will be a little slower, but at least you can keep going. I rode one winter without studs, and I'd never do it again. I fell about once a week.
Quoted: 1074 Post(s)
Liked 295 Times
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
95% of my riding with studded tires ends up being on dry pavement. They're there as insurance for the icy patches. The better studded tires have carbide-tipped studs, which can go for years and years without wearing down.
Quoted: 2609 Post(s)
Liked 1,945 Times
If you think your tires are at 65 psi, they might well be 50 psi actual (check with a tire gauge!). I'd hesitate to take 700Cx32 tires much lower because of the risk of pinch flats. If you think your commute is long, try fixing a snakebite flat in the middle of it!
Quoted: 5227 Post(s)
Liked 3,598 Times
Liked 2,571 Times
I'm in the planning stages of a new front wheel with a wider rim for more flotational goodness.
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 191 Times
