MTB to gravel/adventure sanity check
Desert Flatlander
Bikes: 2001 Trek Alpha 1000, Micargi Tahiti NX3 'The Iron Horse', and many other cheap resale and family bikes.
Hey team,
I recently found out about gravel bikes and discovered that I want one or something to do. lol I have a road bike and a FS MTB. Both of them are relics, as is the soon to be victim of this thread. I have an old Trek Alpha 4300 MTB. I stripped it down and painted it last year. I've used it to cruise around the neighborhood with my daughter. I had it running good with it's crumby old derailleurs and some old trigger shifters. When I got the thing it was missing a wheel, brakes, handle bars, seat post, and seat. So I put it all together and that was fun. Recently I decided to take the old trigger shifters off of it and swap them onto my daughter's Trek MTB. So now it doesn't have any shifters or brake levers.
So I could grab some cheap shifters for it but I'm compelled to set it up for drop bars instead. Tonight I pulled it off the wall and compared it's size and geometry to my road bike. For comparison sake the Alpha 1000 is 52cm and the Alpha 4300 is 16". Overall they look very similar. Same wheel base. Crank is a tiny bit higher on the MTB. The seat and head tube are leaning back a tiny bit on the MTB compared to the road bike. They look parallel on both bikes. The top tubes are the same length.
So I plan to proceed with this madness (dumbness?). Obviously spending very much (any) money on it isn't a good idea. So I put together a list of parts that I think I'll need and it looks like it's going to run about $120. I guess I have a couple of questions and I'd like to know ahead of time if this list of things will work together. So without further adieu here's the list:
I've looked around and haven't found any info on the Micronew brifters but I really don't want bar end shifters and I don't want to spend a ton. So here we are.
I've kind of jumped into this and committed because I bought the Tektro ORYX yesterday. Does anyone know for sure if they will fit over regular MTB tires? I may still need adapters for them. I got them used and they are supposed to come with a lot of parts so I'll see if they come with the guides to set them up on this bike.
Next area of concern that I haven't fully worked out in my mind is the front derailleur. Apparently, from my research, the MTB FD won't work with the road brifters. So I guess I'll grab a cheap road FD that is made for a 3x setup. Maybe with a little luck I could find an Ultegra for $10 like I did for my Alpha 1000 when the Sora decided to fall apart. Can anyone confirm if this will or won't work with the MTB FD?
OK, here is what you really wanted when you opened this thread. Some pics. Pics or it didn't happen.
- Ebay Micronew 3x7 brifters
- ebay cheap wide and compact drop bars
- a stem that will work with the bars (I don't think I have any because of the newer bar standard)
- Tektro ORYX cantilever brakes
What are you doing for bar tape? Old inner tubes can work, but otherwise, budget for something.
If this is a bike that will be getting used on decent-distance rides, and especially if they're away from civilization, you'll likely want to install another bottle cage. (And have a kit for repairing flats and whatnot.)
If you're insisting on indexed shifting, you'll have to play the compatibility game in some form or another.
As always, this is relevant:
https://www.bikeforums.net/classic-v...nversions.html
Behold my avatar:
Bikes: 2019 Gorilla Monsoon, 2013 Surly Krampus, Brompton folder
Quoted: 6941 Post(s)
Liked 444 Times
If it was me, my number one concern would be that old susp fork.
I much prefer rigid for gravel type riding, rather than lugging around this heavy bobbing old anchor.
But thats me.
But thats me.
Are you willing to "merge" the road and mountain bike? Basically, put the brifters, derailleurs, cranks, and bars from the road bike on the mountain bike. Hard to tell from the pics if any of that will actually work, but if you're looking for a project it might be a fun experiment.
Desert Flatlander
Probably new cables and housing for both brakes and shifters.
I definitely plan on new cables, housing, and tape. I have all of that laying around here so I didn't really call it out.
I know it's against conventional wisdom but I carry a 3 liter water bag and keep all the repair stuff in it. I've got it setup so I can switch between road and MTB quickly.
The shifter and derailleur aren't really made for each other. Sometimes things will "just work", so you could always try hooking the current FD to the new shifter if you want, and then getting a road derailleur if it doesn't work out.
I'm keeping my eyes open for a rigid fork. This one isn't the most terrible of fake suspension forks but it does suck. lol
I picked up the Microshift 3x7 STI type shifters for a Trek 520 that uses a Deore DX front derailleur (bottom pull). On the stand it is working, but the front seems to have an extra click which I still need to troubleshoot. I am still waiting for brake cables before I can finish this bike. I also have an old Mongoose MTB I may convert, but it depends on how I like them on the 520. That build is a ways off though.
I think MicroNew is a clone of Micorshift. I ended up going with Microshift hoping it would be more reliable.
When I discovered that thread, it erased the rest of my day.
A trim setting makes sense. I don't have a lot of experience with STI shifters. My sora set doesn't have a trim setting with it's 2x9.
Desert Flatlander
OK, update on this thing.
Ordered some bar tape and some MTB diameter track bars. I have a few MTB stems so I should be able to figure out something for them. The ORYX canti brakes arrived. They came with a few things but neither of the guides for centering the cable. Shouldn't be hard to find those. I have to check my cable inventory. I think I only have one cable of one type and I don't remember which type.
I kept thinking about the brifters and didn't like the uncertainty that went with the brand and whether they would work with the FD. So I went to a store that I found on craigslist that carriers cheap used parts. I picked up some old levers to run the canti brakes with on the drop bars. I really don't know much about these parts. They had a ton of vintage stuff that was probably binned to build Fixies. I selected some DiaComps just because I liked the holes on them. lol (I'll feel dumb if they won't run these brakes.) Then I found some nappy old thumb shifters. They reminded me of my '93 Haro Escape so I decided that for <$10 I'd figure out how to make them work. I was thinking I could mount them under the bars in the center for a relatively traditional setup. Maybe I could mount them on the ends like bar end shifters that you click instead of flipping. Maybe I'll find some other idea. They suite the quality and budget of this build quite well.
So here are some pics. I know that's what you came for.
dirtroadcycling.ca
Bikes: 2016 Giant Revolt, 1985 Miyata Two Ten, 1987 Steve Bauer Chinook, 2005 Giant Rainier
Quoted: 22 Post(s)
May I ask why you want to switch to drop bars? Just throwing this out there as an alternative based on personal experience. Pick up a solid fork. Keep the flat bar, add bar ends for an additional hand position...and avoid all the road brifter/MTB derailleur issues; just pick up a set of MTB shifters and you are good to go.
Maybe it is just me, but I don't see drop bars as a requirement for a good gravel rig. I rode this one approx 2000km on gravel and dirt last year, including D2R2.
Desert Flatlander
Should I slap a cheap steel fork on this thing? I've noticed that ebay has steel forks for far less than aluminum? Does it really matter at all on this low end bike?
Drop bars seemed to make sense. I guess I'll find out. At this point I'll have equipment to set it up either way. I wish I had the crazy bars that came on my '93 Haro Escape. They were one piece but wrapped all the way up where they hand a top hand position that was almost flat. With the top hand positions and the small frame it felt like you could go up anything on that bike.
Trout!
Bikes: Fuji Absolute of unknown age, Framed Gravier
the Surly fork above is designed to replace suspension forks, it's a bit longer than a standard steel fork i believe, you may want to go that route if you're replacing a suspension fork. i believe they make them with canti mounts.
dirtroadcycling.ca
Quoted: 22 Post(s)
Good to see that you have access to a shop that can provide lots of reasonably priced components for this build. Definitely makes it much more feasible to experiment with various drivetrain components to make thins work with the drop bars.
Behold my avatar:
Liked 444 Times
I found it not so easy to find a good quality steel fork for 26" with canti mounts that matches any particular axle to crown height.
I lucked into just the right $10 used Surly for at the local resale store for my Litespeed conversion.
BigJW
96
05-02-18 02:12 AM
bobotech
Bicycle Mechanics
31
02-02-13 11:10 AM
