2019 Salsa Marrakesh.
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
Curved vs straight fork argument will become moot after a major US bike maker produces a drop-bar version of Euro aluminum frame/suspension fork bikes. For same weight as trad steel one gets better handling/comfort/safety. Suspension fork also allows one to use narrower faster tires. Susp fork can be adjusted for rider weight while hard forks are an inherent compromise.
It sounds like bikes from the 90s by Schwinn and Cannondale. The '98 SchwinnCircuit had a RockShox Ruby fork.
is this what you mean?
Quoted: 671 Post(s)
Liked 49 Times
Bikes: 92 Bridgestone xo-2 Turner Sultan
Quoted: 47 Post(s)
I think this tread drifted a bit, but can someone comment about the overall performance of the bike other than the saddle and front fork.
One dimensional ? Heavy ?
The Marrakesh is great as a dedicated all-road touring bike. I don't know if one-dimensional is an apt description, but it's probably not a good option as an all-arounder because it's pretty heavy and isn't very nimble. The sliding drop-out enable a variable wheel-base, so it can be made more nimble. The bottom-bracket is low like most dedicated touring bikes. This makes it more stable while loaded, though there isn't much clearance.
The Marrakesh would probably be one of my top considerations if I only wanted a dedicated touring bike, but there are other touring bikes that work better as all-around bikes like the Kona Sutra.
10+ # x2 in the front panniers dampens things significantly,
as the mass resists moving with every bump..
several have been arriving at the coast after trans continental tours
Maxway does good work building for QBP and other brand importers,
to their design needs.. , in quantity..
Quoted: 671 Post(s)
Liked 49 Times
I've only ridden a cheapo non-adjustable susp fork which bobs a bit climbing off-saddle but it's not too bothersome on the short rides I use that bike for. For touring one could always use the lockout for long climbs.
Quoted: 3460 Post(s)
Liked 1,466 Times
This is the touring forum.
My touring bikes with curved forks have very stiff forks that I am sure offer almost no cushioning. But my vintage Columbus Tubing bike or my (much newer) rando bike that have lighter weight forks with a small radius bend at the base of the fork blade I am sure offer much more cushioning. For clarification here, I am only comparing rim brake forks made of steel, thus it is closer to an apples to apples comparison.
Plus of course, touring bikes usually have fatter lower pressure tires.
Thus, the discussion of shock absorption of a front fork really needs to factor in if the bike is designed for loaded touring or light weight unladen road riding with skinny tires.
Bikes: Surly Disc Trucker, 1977 Motobecane Super Mirage
Quoted: 34 Post(s)
I was at a friend's house the other day, and his roommate had a Salsa Marrakesh. I was checking it out, and I noticed it had removable plates bolted onto the frame for the dropouts and derailleur hanger. I'm kicking myself for buying a Disc Trucker now because it makes me paranoid to think that a trashed derailleur hanger could be the end of my $2000 bike. I researched a little bit before I bought it, but everything I read said there was no such thing as a steel frame with a replaceable derailleur hanger, so I bit the bullet. It's a shame because the 2016 black and gold Marrakesh is such a beautiful bike (or did they add the alternator drops later?)
Liked 1,466 Times
I have several steel bikes, one Aluminum bike and one Titanium bike. The only bikes I have with replaceable hangers are the Aluminum and Titanium ones. I have never seen a steel bike with a replaceable hanger unless it was one that had replaceable dropouts that could be changed for other purposes, like a derailleur dropout that could be removed to install an internally geared hub dropout, etc.
There are plenty of steel bikes with replaceable hangers. My Advocate Sand County has one. I’ve seen others, and I’m sure there are many that I haven’t seen. In any case, I don’t really see a mangled hanger on a touring bike as a likely issue. As mentioned, if it gets bent slightly, they can be bent back. The only thing I that would really screw one up is if you ruined the threads, but that’s a pretty big hole with decent threads, so that’s unlikely too.
Sunshine
Liked 7,490 Times
also, there are ways around a broken hanger.
but the odds of breaking a steel hanger are so minimal it isnt even worth using as a consideration between bikes.
Quoted: 671 Post(s)
Liked 49 Times
