SRAM Red Blackbox jockey replacement help
Location: Creede CO in summer & Okeechobee, FL or TX Gulf Coast in winter
Bikes: Zenetto Stealth road bike & Sundeal M7 MTN bike
Quoted: 90 Post(s)
Having a problem finding lower cost 11 tooth 10 speed jockey wheels that will work. $100 plus or minus a set is not in my budget. Ordered two sets so far and both about 45mm - one claimed to be 41 which is close to what I think I need based on measuring well worn old wheel. In lowest gear links make contact between pulley and sprocket with the 45mm. This has been a most frustrating project. Lots of low cost ones avail - but virtually no one lists wheel dia or will answer if questioned.
Pretty sure the orig part number is 00.7518.014.000.
Quoted: 836 Post(s)
Liked 1,059 Times
Do these look like what you need? https://tacx.com/products/jockey-whe...ilter-collapse Standard or Stainless bearings are all you need. Can usually be had/ordered at your local bike shop or shop around online. Tacx makes good quality jockey wheels and are what I have used when needing replacements. Plus they use pretty much maintenance free sealed bearings. What's not to like?
Quoted: 90 Post(s)
That is what I needed - thank you.
Quoted: 836 Post(s)
Liked 1,059 Times
Ordered two sets so far and both about 45mm - one claimed to be 41 which is close to what I think I need based on measuring well worn old wheel. In lowest gear links make contact between pulley and sprocket with the 45mm. This has been a most frustrating project. Lots of low cost ones avail - but virtually no one lists wheel dia or will answer if questioned..
Quoted: 90 Post(s)
OP Here: On the road again with 41mm pulleys. Took three orders to get it right. Thanks to all.
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 319 Post(s)
couldn't you just use rival or force jockey wheels for like 10 bucks , or even shimano ones ? i still prefer the red mechs weight even if i have to swap out for the lower quality wheels , i always find red stuff on the cheap ...
Quoted: 90 Post(s)
If I knew what I was doing when I started looking - it would have been simple. At my age it is unlikely I will wear this set out.
Quoted: 90 Post(s)
Just re-read your post and completely skipped what might be the solution to your issue. You need to try the B-Screw adjustment on the rear derailleur to create distance between the jockey wheel and cassette sprockets. If you're unsure about making this adjustment just search YouTube or ?? for "SRAM B-Screw Adjustment" . Very easy fix.
ljsense
Bicycle Mechanics
8
09-20-19 03:11 PM
CoMotionRider
Bicycle Mechanics
6
08-07-15 03:11 PM
