Front derailler shifting
I'm wondering if my front derailler is slightly out of adjustment or if something else needs needs to be replaced like cables. It is difficult to shift from the small ring 34T to big ring 46T when in low rear cassette gears (first three gears or so). But FD shifts fine when rear is in higher gears (5-10). What I end up doing is to shift the rear to higher gears then shift the FD. It basically works but just a bit annoying. My components are Sram Apex 2x. Hoping to hear my FD sucks so I can go out and get a newer Force or at least a Rival.
What do you think?
What do you think?
Lever end working easily, indexed? they do gum up with age ..
pull clean & re grease the die drawn cable , yet?
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
What do you think?
What do you think?
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,203 Times
What do you think?
What do you think?
Stuart Black
Stuart Black
