Wheels
Old 03-13-20, 01:14 PM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 649 Post(s)
Liked 292 Times in 215 Posts
Originally Posted by Russ Roth
I have seen the studies where this is true comparing 23 vs 25 and 28 though most seemed to find that while 28 had an advantage the difference in resistance between a 28 and 25 wasn't as great as the difference between 23 and 25 and was becoming a case of diminishing returns. I've yet to see one that claims a 32 or 35 has a smaller contact patch then a 23 or 28 and I suspect that's for a reason. I assume that once you get past a certain point the sidewall has to be stiffer tomaintain the shape of the larger casing and weight eliminates any advantage in any situation. Even for light tires the difference between 23 and 25 can be several ounces per tire.
Wouldn't have thought it would be that big a difference but it seems it might be.
makes sense.
Anyhow, the 'rolling resistance' is a small part of the equation - a tiny fraction of the resistance of pushing your body through the air at 30 km/h.
Wilfred Laurier is offline
Old 03-13-20, 10:35 PM
Oso Polar
Bikes: Trek 3500, Jamis Renegade Escapade
Quoted: 176 Post(s)
Liked 51 Times in 43 Posts
Originally Posted by Wilfred Laurier
This is not true. 'Rolling resistance', the energy lost to tire casing flex as you ride, is less for wider tires, if comparing otherwise identical tires.
It is not exactly true. It is less for wider tires AT THE SAME PRESSURE but wider tires AT THE SAME PRESSURE will not be any more comfortable, and if you reduce the pressure then your rolling resistance benefit is lost - unlike tire weight penalty.
Oso Polar is offline
Old 03-15-20, 09:21 AM
Kedge
Quoted: 8 Post(s)
Well the weather looks like it may cooperate so back on the bike,I did order a set of mavic ksyrium sl off ebay should get them this week,I checked out some brake post extenders,I will make photo once I get it together,thanks all for the advice,I used all of it,I could not have done this on my own,thanks
Kedge is offline
Old 05-30-20, 03:25 PM
ClydeClydeson
Quoted: 581 Post(s)
Liked 921 Times in 518 Posts
Sorry to dig up a zombie thread, but you are mistaken.
Wider tires at the same pressure as narrower tires will deflect more easily because of the larger volume of air inside the tire, so will be marginally more comfortable.
And since wider tires at the same pressure have less rolling resistance than tires that are narrower but otherwise identical, you can lower the pressure and get the same rolling resistance as the narrower tires and have noticeably more comfortable ride.
Please not that I am not saying wider tires are necessarily faster, but that they have less rolling resistance, which is a small component of the overall drag you must overcome when riding, especially when speeds go up. The aerodynamic resistance of the fatter tire cutting through the air will probably claw back any advantages of lower rolling resistance if you are riding over 30km/hr or so. You still get the additional comfort and traction and pinch-flat and rim damage protection, but the bike will be a bit slower.
ClydeClydeson is offline
Likes For ClydeClydeson:
Old 05-30-20, 06:55 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
559 - 40 tires should be just right for commuting (26x1.5") a tire that is "fast" will trade away puncture resistance..
your velocity mending a puncture will be Zero..
fietsbob is offline
Likes For fietsbob:
Old 05-31-20, 11:17 AM
Ironfish653
Dirty Heathen
Ironfish653's Avatar
Quoted: 889 Post(s)
Liked 906 Times in 534 Posts
I actually prefer a high-volume tire, like 1.95-2.1” on my commuter bike, especially since that kind of riding typically involves lots of surface transitions. Based on RWGPS data, my primary commuter, a 26” former XC racer, gave up only 0.5 mph moving average to the 700c (28 and 32mm) road bikes, despite having a max speed 2-3mph lower; the bigger tires meant that I didn’t have to slow down as much.
Ironfish653 is offline
Likes For Ironfish653:
Old 05-31-20, 11:44 AM
Oneder
Bikes: Wahoo of Theseus, others
Quoted: 428 Post(s)
Liked 67 Times in 46 Posts
I agree you just have to find the tires that are made for good speed on 26 inch wheels. I replaced my road tires with super heavy duty flat resistant knobbies and now I really regret that lol
Oneder is offline
Old 06-04-20, 10:00 AM
Oso Polar
Quoted: 176 Post(s)
Nope, you are. You can easily confirm that you are wrong yourself - take two tires of a very different size, say, 28 mm tire and 42 mm tire (of a similar "supple" type), pump both to the same pressure, say, 60 psi. Now, squeeze tires with your own fingers. Which tire will be much softer (="deflect more easily")? The ride feel will reflect this - 28 mm at 60 psi will probably feel too soft (or just right - depending on your + bike weight), 42 mm at 60 psi will result in anextremely harsh ride - unless you are seriously overweight. To get a softer ride from wider tires they must be run at lower pressure.
Old 06-04-20, 10:07 AM
Oso Polar
Quoted: 176 Post(s)
I have Continental Sport Contact II on my bike with 26 inch wheels, they seem to be pretty fast. AFAIK they are not manufactured anymore and were replaced by Contact Speed (https://www.continental-tires.com/bi.../contact-speed). Looks exactly the same on photos.
Old 06-11-20, 09:55 PM
Millhouse56
Millhouse56's Avatar
28 inch tires. Is there such a thing?
A woman wanted to buy my Raleigh Sport but her husband said no, he wanted something with 28 inch tires. Do they exist?
Millhouse56 is offline
