How well do the older glued carbon tubes into aluminum lugs frames ride?
Likes For WizardOfBoz:
Quoted: 4210 Post(s)
Liked 3,879 Times
Last winter I got SS reinforced toes. I will never completely be without some steel, even when I'm in the ground. Andy
AndrewRStewart
AndrewRStewart
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Hey! We can start a whole new thread arguing about materials of toe construction! Titanium! Stainless! Ceramic!
Quoted: 1529 Post(s)
Liked 718 Times
I had a Giant CFR1 back in the day, size 57. Weighed 900g, bit of a noodle, taught me to spin. The top end of the seat tube broke its bond with the seat cluster, but it didn't seem to make a difference.
Titanium wrist here.
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
The bikes rode fine, but there were too issues, first off they weren't any lighter than a high end steel bike back when those lugged CF bikes came out; the other issue was that some of the companies had problems with the first 3 to 4 years where the epoxy holding the AL lug to the CF tube would not hold well; so you have to be careful if you're buying one used.
Quoted: 5 Post(s)
This is my road bike: an Opera Leonardo, from the early 2000s (the bb is stamped 00). Carbon main tubes and wishbone chainstays with alu lugs, chainstays and head tube.
It's a small frame (49cm), I've only seen one other like this, and I'm very happy with the comfort and acceleration. So far so good with longevity!
Likes For radioarno:
Quoted: 2333 Post(s)
Liked 2,097 Times
I had a Vitus Carbonne 9 with full Campy C Record Gen 1 Panto in about 1985 or maybe early 1986. GL330 rims. Good tubulars. Aluminum FW, 13-21. Cinelli 66-42. 1R stem. 18 pounds if I remember. It was a very comfortable ride especially long rides. The fork was aluminum, I think. The glue lasted about 5 years. The seatpost broke on a ride and I got hurt pretty good. I stripped off the Campy and thru the frame into a dumpster.
Quoted: 3376 Post(s)
Liked 5,523 Times
When I was in college, (late 1980's to early 1990's), Cherry Bicycles, (Lafayette IN), had a carbon-tube/aluminum-lug frame hanging on the wall. The downtube was pulled out of the bottom-bracket lug. The story was the bike's owner was riding it down a fast hill, hit a railroad crossing, and suddenly the top tube was the sole connection between the two halves of the bike.
I don't recall the brand of the frame.
Liked 2,097 Times
Oh, I bought a Kestral 200 EMS next with first gen Dura Ace STI. 1992?? About the same weight as the Vitus but much, much stiffer and actually a pretty decent criterium bike. I did a bunch of double centuries, brevets, and PBP on it. Probably used 19 mm clinchers on it. It did not have the comfort nor the same comfortable all day geometry as the Vitus. I still have it but never ride it.
Quoted: 1944 Post(s)
Liked 2,164 Times
Even though this is a zombie thread, I’m in the process of overhauling and early 90’s Specialized Allez Epic; 7 speed 105. Our son traded for it a number of years ago, and it was time to get everything tuned up and greased for him to ride in a month when he comes out.
It is way too big for me so that might have some influence, but it has to be one of the harshest bikes I’ve ridden. And this is from someone with 35 years on Cannondales. I don’t know if it is the aluminum fork, my Cannondales have steel, or ???, but it is just not that much fun to ride.
John
John
Liked 3,879 Times
John
John
AndrewRStewart
AndrewRStewart
Liked 2,164 Times
The original Wolbers are too far out and I understand the rear wheel had been tweaked and with 25’s it was a bit too harsh. I had a pretty much unused Alex set that I swapped out from my wife’s bike after a couple rides. We both hated those wheels and being aero, they give a harsher ride. I’m going to see if I can squeeze 28’s on them to cut some of the edge.
John
Quoted: 2489 Post(s)
Liked 2,958 Times
An engineer/bike racer who has done a series of videos aimed at demystifying bicycle technology has one where he presented a pie chart displaying the relative contributions of various factors to shock absorption.
Tires took up almost 2/3 of the pie chart. Seatposts, surprisingly, were the next most significant factor (although the fact that he was measuring a current high-end road bike with a long seatpost probably skewed that conclusion).
Beyond those two, the other factors were shown to contribute to comfort in dwindling amounts, with choice of frame material representing a comparatively tiny sliver.
That definitely corroborates my experience of riding racing bikes over the last 55 years or so. All my bikes with my preferred wheelbase (just under 98 mm for a 54-cm frame size), including aluminum, steel, and carbon bikes, ride the same with respect to comfort. But my bikes with a shorter or longer wheelbase (e.g., my track bike with sprint geometry and a wheelbase under 96 mm and my sport touring bike with a wheelbase of 105 mm) ride very differently.
To put it another way, same wheelbase, different frame materials: no difference; different wheelbases, same or different frame materials: big difference.
Liked 3,879 Times
I also suspect the fit between the two vastly different sized bikes accounts for some of the ability to handle the road's undulations/bumps. Had I known the fuller story my reply would have been more detailed. Like Click and Clack would have said, John is guilty of withholding information Of course this is pretty much the standard on this, and many, forums. Andy
AndrewRStewart
AndrewRStewart
Liked 2,164 Times
In my initial post I did state that the Allez Epic was way too big for me, but I didn’t give specific sizes. I have ridden my brothers Soma San Marcos, which is also big, (I think 57 or 58), so not as much as the Allez, but it rides like a dream.
I’m not an engineer. My impression over the years was a smaller frame with a shorter wheelbase was generally more rigid.
In the end, a 126mm dropout lugged carbon frame is probably close to the bottom of the collectibility food chain that it is of little consequence. I wasn’t trying to debate, it was just an observation.
John
John
Liked 2,164 Times
I wanted to follow-up with a tire change and more miles. The 25c tires on the Allez Epic actually measured less than 21mm inflated to 100psi. I swapped them out for some other 25c’s that measured a little over 23mm inflated.
When I finished the bearing maintenance, STI conversion, RD, cassette, chain and brakes, I took it out on a real ride with the wider tires.
In all honesty it is not harsher than my Cannondale. But it is a stiff frame and you do feel the bumps. The large frame might contribute to it, but I still think the aluminum fork doesn’t dampen things enough.
John
John
Liked 2,164 Times
Final update. Swapped out the horrible Alex wheels for a set of Open Pro’s with 105 5700 hubs. Same tires now measure a little under 25mm.
Bike does ride nicer. It is stiff, but not as harsh as with old wheels and skinny tires.
John
John
Quoted: 5 Post(s)
John
John
andrewcd
Classic & Vintage
22
10-26-18 01:52 AM
ModeratedUser04122018
Bicycle Mechanics
16
08-30-10 10:20 AM
eddiepliers
Road Cycling
6
05-30-10 06:53 AM
