Blackburn Floor Pump Repair
Quoted: 502 Post(s)
Liked 466 Times
My long trusty Blackburn TP-4 Trakpump Pro has a non-operating check valve. I’ve disassembled every connection that will come apart, but can’t get at that check valve, which I suspect is within the barrel. I can separate the barrel from the base and gauge assembly, but it appears to need a special tool to go farther. Any ideas on how to repair?
Quoted: 4210 Post(s)
Liked 3,875 Times
The base of pump lives a hard life with the moisture and lack of frequent venting. I've seen more then a few with badly corroded bits down there. Good luck. Andy
The fix would constitute replacing the pump... But Blackburn's modern [floor] pumps are a pale imitation of their older models, even from only a few years ago.
As for the OP, post a pic that you have of the disassembly so far--almost every pump I've seen is held together with a foot nut on the bottom.
Quoted: 83 Post(s)
Liked 64 Times
Had the same issue. Blackburn has a lifetime warranty. Call them. They'll take care of you and stand behind their warranty without question. This is why I like Blackburn.
Quoted: 502 Post(s)
Liked 466 Times
Yup. Wrote Blackburn describing this problem; no records or receipt from when I bought this pump (at least 20 years ago). They’re sending me a new pump. Pretty amazing warranty support.
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,098 Times
That’s amazing. My 15 year old Blackburn died recently; replaced it with a Silca. Maybe I’ll send them a note with pics of the “pump in pieces” I tried to repair.
Blackburn Trakpump sport TPS 2 --rebuild parts not available
Have non-working Blackburn trakpump sport TPS 2. Parts to rebuild not available any longer. 1/8/2024
More:
Disassembled, probably the plunger. Read threads below. Found spare parts catalog from Blackburn, nothing listed for Trakpump models.
Called spare parts number 800-7765677 on spare parts web site.
Explained problem with pump, asked about spare parts. There are none. Explained I have no warranty documentation, person said failure covered under lifetime warranty and that a replacement would be sent.
More:
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,996 Times
More:
More:
