What is the correct nomenclature for this type of stem wedge nut?
Bikes: too many
Quoted: 411 Post(s)
Liked 234 Times
So... what is the bestest nomenclature/description for a conical shaped stem wedge nut like this one shown (see red arrow)? I'm having difficulties explaining or describing it. Anyone know where to purchase such a thing? Thanks...
Edumacator
Quoted: 2441 Post(s)
Liked 3,136 Times
Expander bolt cone?
Likes For jdawginsc:
Edumacator
Liked 3,136 Times
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
Also says it's for 22.2 stem, but it would work equally well on a 22.0 (French) or 21.1 (0.833" American style) stem, so the 22.2 is pointless and a little misleading.
I call it stem quill expander cone, but I'm open to any other terms that get the idea across (unless you call it a wedge, grrr...)
Mark B
Likes For bulgie:
Edumacator
Liked 3,136 Times
Funny, seller calls it alu, but I'll bet a dollar it is steel. He calls it a wedge, but I reserve that word for the other type of quill. You know, the ones that are wedge-shaped?
Mark B
Mark B
On the other hand, an aluminum cone seems like a recipe for stuck-age.
Dave
Quoted: 3811 Post(s)
Liked 6,716 Times
conical wedge?
Likes For nlerner:
Quoted: 2588 Post(s)
Liked 4,824 Times
Cinelli did produce both steel and alloy expanders, as well as stem bolts (I agree with @bulgie that the one in the photo looks steel).
Pic stolen from current Ebay auction:
DD
Likes For Drillium Dude:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 922 Times
Not sure about "correct", but -
conical expander nut for bicycle quill stem
- does pretty well on Duck Duck Go. Still gets a lot of wedges, though.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
Wedge vs expander
Likes For SurferRosa:
IMO any of those names beats hell out of "metal right circular conic frustum with central threaded hole."
Quoted: 3514 Post(s)
Liked 2,927 Times
Shimano calls it an expander cone.
Likes For smd4:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Didn't, actually. Constructed that technical description using terms mostly from solid geometry:
frustum - portion of a solid between two parallel planes
right frustum - right pyramid or cone truncated by planes perpendicular to its axis
circular - specifies conic vice pyramidal (probably could have omitted either "circular" or "conical", but using both ensures the reader understands it's round vice polygonal)
metal, central threaded hole - descriptive and reasonably self-explanatory (though I probably should have specified that the central threaded hole was centered on the right frustum's axis)
Bikes: 1991 Centurion Oxygen, 1997 Centurion Invincible, 1995+- Fondriest Wind, 1982 Grand Master Nissan Pro 2000, 1992 Olmo Racing (The racing part of the name HAS to be a joke).
Quoted: 34 Post(s)
Liked 30 Times
Why would an aluminum cone cause a stuck stem?. As far as I can see, the only thing it will be in contact with is the inner part of the stem, which I assume to be aluminium. So aluminum to aluminum contact. If I was worried by this (I´ve never thought about it before this post), I´d say steel cone to steel stems, and aluminum cones to aluminum stems.
Likes For P!N20:
Quoted: 1609 Post(s)
Liked 2,216 Times
doohicky
Likes For SJX426:
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3205 Post(s)
Liked 1,845 Times
Sorry to go off topic briefly, but this interests me. And it's still about stems. My 84 Schwinn LeTour Luxe has a smaller than normal stem. I had always thought it was 0.833. Can anyone confirm this? I have only an analog caliper, and am in the process of making arrangements for Lasik eye surgery (I can't see for ****, even with glasses). TIA
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 641 Times
Perhaps an unusual location for anti-seize compound?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Liked 2,927 Times
Edumacator
Liked 3,136 Times
Over torquing causing the stem tines to dig into the soft expander cone, is what I was thinking.
Liked 2,927 Times
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
I was going to suggest "dinglehopper," it's not complicated enough to be a turboencabulator
It's not a standard fastener, I think. I did look and saw some fasteners that are conical but the function was like a regular nut and the reason was tamper resistant - you couldn't get a vise grips to hang onto it
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Liked 4,824 Times
Exactly! We want it to 'seize' to a certain extent in that location - if it's loosey-goosey, a trip to the emergency room looms...
DD
DD
Quill - The hollow stem-like main shaft of a feather.
A quill-shaped stem and expander can be used on a bicycle.
Conical - resembling a cone especially in shape
A conical expander can also be used on a stem on a bicycle, though a conical expander is actually a truncated cone.
Likes For Bad Lag:
Bikes: too many
Quoted: 411 Post(s)
Liked 234 Times
