Newbaums cloth tape tips/tricks?
Le Crocodile
Quoted: 370 Post(s)
Liked 787 Times
Any taping tips when using the Newbaums cloth tape? I have never wrapped with the Newbaums (non padded) cloth before.
2 layers?
Top to bottom?
Bottom to top?
Any special wrap pattern?
Special tips to wrap around levers as there are no hoods.
Etc.
Last thing to wrap up the Bottecchia project!
2 layers?
Top to bottom?
Bottom to top?
Etc.
Likes For Erzulis Boat:
Likes For WT160:
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
It's easy to use, quality product. One layer, but I guess you know it won't be as cushy as modern tapes. Bottom to top is most durable but BITD it wasn't unusual to wrap top to bottom. You may have to experiment around the levers but IIRC the length is relatively generous.
Likes For shelbyfv:
Quoted: 1143 Post(s)
Liked 1,753 Times
Yes, very basic. I do end to center, I wrap toward the out, on the straits tape overlaps about 1/3, 1/2 lap inside the curves never lapping 3 layers maybe 3mm lap on the outer curves, a couple of tabs for gaps at the levers. I keep taught throughout, then cut a long taper at the end.
I finish with a grip tape, I think it's an electrical silicone/cloth tape. Similar to hockey stick tape I think.
Likes For Mr. 66:
Quoted: 804 Post(s)
Liked 2,986 Times
cloth wrap.
keep an eye out for gaps and remember it won't stretch like conventional wrap.took me about 3 times longer- patience is key.back in the day it maybe have been applied top to bottom if your going for originality.
Likes For '02 nrs:
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 175 Times
If you do two or more layers, don't waste the Newbaum's on the first layers. Get some hockey tape if you want to build up the thickness, and then do the Newbaum's as the last layer.
I do bottom-to-top, but good arguments can be made for either.
If you do bottom-to-top and need to finish off the wrap with electrical tape, go to the hardware store and get the best 3M tape they have. The cheap stuff has crappy adhesive that doesn't hold, and also melts and oozes out, making a mess. The good 3M tape comes in five or six different colors, too.
Likes For arex:
Quoted: 1641 Post(s)
Liked 831 Times
The adhesive on Newbaum tapes is pretty strong and can mess up the tape if you try pulling it off while doing the wrap to adjust overlap because it will severely stretch out the cloth weave and distort the tape's width. So be very careful you get your overlaps right when wrapping your handlebar as you only have one shot to get it right.
Likes For Chombi1:
Quoted: 1106 Post(s)
Liked 1,328 Times
Likes For oneclick:
Edumacator
Quoted: 2441 Post(s)
Liked 3,135 Times
Might be an interesting experiment.
Likes For jdawginsc:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
Shellac after wrapping and it won't matter whether you start at the top or the bottom.
Here's a real honest to goodness French setup that might help in your situation. These bars were from an eBay France purchase. I use it to display some bells.
Came with the handlebar bag
Likes For gugie:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
All of this... And I wrap top to bottom for the reason that my boomers were wrapped that way. I'd love to do the shellac like Gugie described, but for the sake of originality I've never owned a vintage bike worthy of that treatment.
Likes For Chuck M:
Quoted: 1372 Post(s)
Liked 1,752 Times
I never wet tape but it has been suggested that doing so helps. None the less, this is what I manage to achieve with cloth tape, which I find to be hard to wrap with. Anyway...
The problem comes when one tries to wrap, cleanly, around the brake lever mounts. I avoid this problem by positioning the mounts exactly where they are the most comfortable for me. I actually test ride the bike to ensure the lever location is where I want. Then, I secure the mount strap in place with PVC tape. I also use a bit of silicone seal to properly position the housing and make starting the mountain bold easier. Much easier.
The basics of wrapping are simple. Decide if you want to start from middle to end or visa versa. With cloth tape, I wrap from middle to end, these days. As a rule, the cloth is thin enough to allow me to tuck it inside the handlebar end, whether I use bar ends...
Or end caps...
Or end caps...
Likes For randyjawa:
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,480 Times
What solvents/techniques work for removing the sticky residue that is left behind when removing Newbaums that has been on the bars for a long time and many miles?
Brent
Brent
"I have a tendency to meander sometimes." B.G.
Quoted: 5888 Post(s)
Liked 3,471 Times
Good looking job. Do you run an old inner tube along the handlebar and tape over it?
Liked 3,471 Times
I'm getting ready to tape a bike with Newbaum's. I may use this stuff underneath:
https://www.amazon.com/Fizik-Bar-Fou...%2C112&sr=8-32
I've used it before with cork tape. It's not bad stuff and will provide some extra cush where it's needed. I do find Velox Tressostar tape easier to work with than Newbaum's.
Quoted: 804 Post(s)
Liked 2,986 Times
Quoted: 838 Post(s)
Liked 1,082 Times
Its the only tape I use. I got top to bottom have never wet it. I overlap about 1/4 as I wrap, maybe a little more. If you're going to double wrap then just spring for their padded cloth tape which is just a little thicker, but I don't love the look of that. Don't forget to cut a small piece off to cover there area where the hoods sit.
Likes For polymorphself:
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
https://grepp.cc/collections/cloth-handlebar-tapes
I wanted cloth but didn’t want unpadded tape so I got some of this. The tape is cloth and padded but uses little silicone dots to hold it in place. It provides about as much padding a Brooks leather but with a bit more grip when dry.
Bikes: 1980's Viner Track Bike, Litespeed M1
Quoted: 43 Post(s)
Liked 107 Times
I wrapped bottom to top and used no tape to finish it off. It is a track bike with no brake levers so it was pretty easy.
Likes For EJM73:
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 165 Post(s)
Liked 267 Times
I like to finish off all my bar tape (as well as on former customers’ bikes back when I worked at a shop) using waxed leather working lace. Heavy waxed bookbinders thread works as well. The waxed thread for leather working is extremely strong and will hold through all kinds of weather, it looks really nice when done correctly as well.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
I wrap with either of these two tapes (bottom to top, in-out):
Newbaum's
- No figure 8
- Cut a small cover for the lever clamp
- No finishing tape
- Cut the end at the top straight across
- End under the bar.
Fizik Classic
- Toss clamp covers in the trash
- Figure 8 over the lever
- Cut end diagonally at bar sleeve
- Finish with 9mm wide strip of Fizik finishing tape.
Newbaum's
- No figure 8
- No finishing tape
Fizik Classic
Likes For SurferRosa:
Liked 5,802 Times
Pretty sure Brent can't buy 90% alcohol easily in California anymore.
But why is it necessary to remove residue?
Likes For gugie:
Liked 5,802 Times
Not necessarily answering the OP's question, but here's how i do it (with or without the jazz music in the background).
Quoted: 177 Post(s)
Liked 313 Times
The paper backing over the adhesive strip can be bothersome and if you should drop the roll while wrapping, it all unwinds. This is not a problem with Tressostar tape since there is no paper backing, but your color choices are limited..
Now I tear off 12 - 15" of the paper backing and re-roll just enough so the roll won't unwind should I drop it. That way I can focus on getting the wrap the way I want.
72+76 Super Course, 74 P-10+ 79 Tandem Paramounts, 84 Raleigh Alyeska, 84 Voyageur SP, 85 Miyata Sport 10 mixte and a queue
