Long vs. Short Pull Brake Levers
Biking Viking.
Is there any way to tell whether a brake lever is short or long pull just by looking at it?
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
Look at the center-to-center distance between where the lever pivots and where the cable anchor pivots.
I just pulled a couple levers from the parts bin and they were approximately 40mm and 24mm for long-pull and short-pull, respectively.
Likes For JiveTurkey:
Yup, you need at least to hold them in your hand, and work them
and measure them physically.
Biking Viking.
Ok. Thanks.
I ask because I occasionally volunteer in a co-op-esque non-profit. We have a lot of people come in and mix and match spare parts to fix up their bikes. Most have no idea there are long and short pull. I want to be able to ensure they choose a lever with the proper pull before installing it.
Since I am able to measure the levers, having a sense of center-to-center difference between long and short is helpful. Thanks for the advice.
If your parts are labeled when you get them, it might not be a bad idea to put this info on the label. Something like "For Cantilever, road caliper" or "For V-brake, linear brake". Etc. Also remember, some levers can operate both.
Quoted: 2026 Post(s)
Liked 1,096 Times
I just measured two sets of 10-speed Campy Ergo, a set each of 8-speed and 9-speed Shimano STIs and a Tektro R-200, all road caliper/cantilever levers and their lever pivot to cable anchor distance was ~18 mm center-to-center on all of them.
I also measured a set of Tektro RL-520 V-brake levers and the lever to cable anchor center-to-center distance was 32 mm or almost twice as much.
So, any lever that measures more than say, 25 mm is probably intended for V-brakes.
While we're asking, can anyone give me the c-c pivot distance on the new Shimano 5700/6700/7900 series of levers?
Likes For HillRider:
Real Men Ride Ordinaries
Quoted: 17 Post(s)
If you take a close look, a lot of cheaper flat bar levers for both long and short pull are made from the same mold (cast?) and the only difference is where the cable is anchored. A lot of them will have a subtle V or C next to the cable anchor that can be a good indicator.
Likes to Ride Far
I've also measured the distance on several different levers. There was a lot of variability between different levers, but my general conclusion was that the cut-off was at about 30mm - longer than that is for V-brakes (or cable-actuated mountain disc brakes) and shorter than that is for everything else.
I came a cross an 90's Nishiki road bike which has shimano 60 brake levers and dia-compe center-pull brakes.
I have a hard time adjusting the brakes and realized that the levers and brake might not be compatible...
Does anybody know how much cable pull the levers should produce in order for them to work with centerpull brakes?
Thanks!
Thanks!
Quoted: 540 Post(s)
Liked 416 Times
Brake lever pivot to hammer should be under 33mm and ideally more like 22mm.
33mm pivot levers are in the middle so they can be used for both cantilevers and v-brakes.
Also, the barke levers are Shimano 600 for drop bars. One zero was missing in my previous post.
Quoted: 4412 Post(s)
Liked 1,566 Times
Thanks!
Thanks!
Ah, that explains so much, I googled quite much being sure something was off..
So, then I guess it just comes down to my adjustments skills, unwanted flex in the lever and brakes and possible contamination in pads and on rims. Ill try a new pair of pads.
Thank you.
Thank you.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
Cantilever, Side pull, and Center pull brakes are all (typically) Short pull.
Road Disc calipers and "Shorty V-brakes"are also Short pull.
Long pull brakes require about a 35mm Measurement, Pivot to pivot, at the lever.
V-Brakes and MTB Disc brakes use a Long Pull lever.
"Mid pull" levers are about 30mm, measured at the pivot points... and don't work very well for either short or long pull brakes.
there are too many variable factors to measure actual cable pull lengths generated by the levers... just measure the pivot-to-pivot distances of the levers.
@ 25mm is short pull... @ 35mm is long pull.
I have measured HUNDREDS of bike levers in my business... possibly THOUSANDS of them. The specifications i've listed always work.
leob1
Bicycle Mechanics
10
06-20-12 01:51 PM
TurbineBlade
Bicycle Mechanics
6
08-05-10 06:28 PM
