Theft deterrence - ball bearing in Allen head bolt
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
If you were going to place a ball bearing in an Allen head bolt for theft deterrence, would you secure it with superglue, solder, or do something entirely different? This would be in a quill stem expander bolt, for example. Assume you might want to remove it yearly or less often, for maintenance.
incazzare.
I do it with hot glue. It's a surprising hassle to remove. I usually need a hair dryer and a magnet.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Passista
Quoted: 868 Post(s)
Liked 721 Times
A ball bearing is very smooth, so it's hard for the glue to hold. I'd use a bit of alu stock and epoxy.
Quoted: 392 Post(s)
Liked 49 Times
Epoxy sounds permanent?
Quoted: 75 Post(s)
No, not epoxy.
Clean the bearing and the allen head with some acetone and allow to dry. Put a single drop of Super Glue gel or other brand of cyanoacrylate adhesive in the hole and push the bearing into place and hold for 15-30 seconds being careful not to glue your finger to the bolt. It will be an absolute PITA to try to get the bearing out of the hole even with a knife tip or similar tool. When it comes time to remove the bearing, put a few drops of acetone into the hole around the bearing and wait a minute, then lift the ball out with a magnet or pry it out with a knife tip or other pointed implement.
Likes For GravelMN:
Likes For Torchy McFlux:
Quoted: 5793 Post(s)
Liked 2,584 Times
Drop in a close fitting ball, then melt in some candle wax to hold it there, and clean it up smooth. It's easy enough to dislodge with a small pick, and the wax is soft enough to get pushed out of the way by the Allen key. Yes, a thief could defeat it pretty easily, but you're betting he's to lazy to bother for a stem and bars, and will move on to something nicer.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Superglue and acetone to remove. It'll leave no messy residue and its very easy to install.
Quoted: 7350 Post(s)
Liked 2,475 Times
Larry, the owner of Larry's Freewheeling in NYC, just drops solder into the allen key. It requires a big soldering iron to heat the bolt up enough to melt the solder.
Bikes: Trek 970, Surly LHT,Gunnar Roadie, Santa Cruz Heckler, Trek Domane
All clever ideas. Thanks to the OP for the question. I'll try a few on a bike I leave parked at BART. That place will stress test any theft deterrence strategy.
Bikes: Burley Duet [of some unknown year] (the guinea pig); 2001 Ventana ECDM (the project); And always one less than I think I really need.
I'm +1 on the ball bearing and wax. Often times I think the best theft deterrents simply have the appearance of difficulty.
What about swapping the bolts in question for Torqx bits or something else less common? Dirtbag willing to steal may be less likely to carry an odd/less common tool. Maybe for something like a stem a mix-match of bolt designs?
Knock on formica I grew up in [and now live in] an area where this stuff wasn't an issue (that or nobody really wanted the gems I rode)
Likes For LastKraftWagen:
Bikes: '17 Access Old Turnpike Gravel bike, '14 Trek 1.1, '13 Cannondale CAAD 10, '98 CAD 2, R300
Quoted: 1571 Post(s)
Liked 12 Times
But some thief's know and actively look for quality bicycles that can bring quick cash. They know what to do to defeat any attempt to harden the target bicycle. Whether they take your bicycle or someone else's may be little more than the luck of the draw.
Liked 2,584 Times
One thing to keep in mind when "foolproofing" your bike is that you don't want to get carried away and screw yourself. Whatever you do has to be easily circumvented or you'll be facing a very difficult repair one day.
I can't count the times I've run into folks walking because they got a flat and couldn't open their thief proof wheel locks.
FB
Chain-L site
FB
Chain-L site
Fahrradfahrer
Bikes: n+1
One more for the ball bearing and wax, although they are all pretty good ideas (not too sure about the epoxy though). The Solder idea is good. I might give that a try next time I decide to worry about it.
Likes For garage sale GT:
Likes For asmac:
Passista
Quoted: 868 Post(s)
Liked 721 Times
Why not epoxy? It wouldn't be too difficult to drill the aluminum filling the recess once a year, as the OP needs.
Si Senior
Bikes: Too Numerous (not)
Quoted: 23 Post(s)
Liked 10 Times
One danger: if thief can't get what he wants with whatever simple tools he has, --he might resort to much greater damage. I had a friend who, years ago, used to use razor blades as washers when mounting eight-tracks in his cars. One day he found his car (eight track still in place and blood all over the dash and seat) totally trashed. Dash board and interior had been kicked or hammered and the outside of his car was stomped or hammered also. Eight-track was fine, though.
Likes For dbg:
No, not epoxy.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
It's a 2014 thread. But maybe someone knows about dried superglue and acetone. Loctite says it will work. https://www.loctiteproducts.com/en/k...uper-glue.html
I like the hot melt glue idea. Is a hair dryer hot enough to melt the glue? I'm guessing it is. It might be tricky to get all the residue out of the bolt. Maybe some Q-tips after heating the bolt with the hair dryer?
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...the current stats on bike theft suggest that e-bikes get stolen three times as often as a normal, pedal powered bike. So I lock up next to an e-bike when I can. So far, it's working.
I know it used to be popular to do the ball bearing/super glue thing on seat post clamps. But I never tried it. I always assumed enough acetone would remove just about any adhesive except epoxy.
I used acetone to dissolve acrylic pellets for hardening felt. Given time, it will work.
Liked 2,979 Times
if I can, I'll swap the standard hardware out for "security" head hardware. It will not deter the determined, but it may buy the rightful owner some catch time.
-Oh Hey!
-Oh Hey!
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 212 Post(s)
Liked 356 Times
Small vice grips and that cap screw is coming right out.
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
