Sirrus Sport 2011 - Rear wheel issues
I'm no expert, but I prefer to ride a hybrid with wider tires and greater tread (and perhaps a suspension fork) when I know I will be encountering pot holes. The Sirrus Sport should be able to handle wider wheels with tread. Good luck with the upgrade on a nice bicycle.
Quoted: 1581 Post(s)
Liked 1,193 Times
OP, given your weight, your desire to load the bike, and the road conditions you describe, I'd simply go ahead (I'm assuming you're otherwise happy with the bike) and order up a set of handbuilt touring wheels.
This need not be overly expensive at all. You'd want a good touring rim, 36 hole (front and rear), built onto good hubs (e.g. Shimano 105 or better [or equivalent]). I'd also run 32c tires (lots around, e.g. Panaracer Pasela, Shwalbe Marathon Supreme, Vittoria Randonneur, etc.).
Doing that would be well worth the cost, and assuming a good wheel build you should not have any further problems. Check out, just for example, the information here:
https://www.peterwhitecycles.com/wheels.asp
Bikes: Canyon Roadlite AL
Liked 11 Times
stevage
59
02-01-13 10:35 PM
kk27
10
08-08-10 07:48 PM
