What do I need to upgrade to di2
Hey what’s up everyone
im thinking of upgrade my bike to Di2. It currently has ultegra 8000 setup. I know I can keep the brakes.
my question is as follows.
is there an upgrade kit? Or would I have to piece it together? If I have to piece it together, what exactly do I need?
thank you
thank you
Every bike is diff so you are going to have to measure each wire. I used the discount OEM packages but the supply chain has changed. That and a 1/4" drill bit. I have retrofitted two bikes and it was money well spent.
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 389 Post(s)
Liked 325 Times
The first kit on this list is likely what you need:
Texas Cyclesport Shimano Ultegra R8050 Rim Di2 Groups-Upgrade Kits
I.e., shifters, front and rear derailleur, battery, cables, junction box. I personally don't think it's cost effective to upgrade to Di2, but that's just me.
Quoted: 6196 Post(s)
Liked 4,810 Times
I have Ultegra Di2 also. And though I like it, I don't think it enough bang for the buck spent just to swap from the equivalent cable pulled stuff you already have.
IMO, my 105 5800 group on my old bike was a more responsive shifting group. Shifting wise I actually miss it. Especially when it comes time to shift off the big ring. It just doesn't happen as fast as I'd like it to and it messes up my cadence briefly. I've even gone in with eTube and set it to shift as fast as is possible and when it drops to the smaller ring.
Though all in all, I like electronic shifting and it will likely be on the next bike I get as well. Several things lead me to favor it.
And Di2 won't make you faster.
- Once it's set, it's set. It doesn't come out of adjustment unless you bang up the DR. With cable pulled, I was having to "tune" it up at least once a year to keep everything shifting perfectly.
- Wires and hydraulic lines lend themselves better to running through the frame. So you can have a clean look easier on your bike. It's also easier to keep clean. I now just wipe my bike off with a moist towelette after a ride. Before I ignored cleaning my bike because of the cables being in the way.
- I can get info on my Garmin as to what gears I'm in and my Di2 battery charge and a few other gee-whiz numbers. But you have to get the additional wi-fi option. Maybe the 12 speed stuff has that included.
Likes For Iride01:
my other bike has Di2 on it. My favorite feature of it is the set it and pretty much forget it. Not much tweaking afterwards.
Likes For Lolo03:
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,533 Times
You have to take the glass half full view.. I was looking at eg. Cervelo Caledonias on Excel's website. The Ultegra Di2 edition seems pretty much identical to the non Di2 Ultegra version. Cost difference is $1500. An upgrade kit for $1200 doesn't seem bad in that light, as you can probably sell your little bits that you're swapping out for something. OTOH, it is a sunk cost if you built up the bike yourself and you would have been better off just getting Di2 from the get-go.
Likes For Sy Reene:
Quoted: 824 Post(s)
Liked 1,659 Times
One of the main reasons I went with Di2 when building my current bike is because I couldn't find an Ultegra group set, and ended up getting the crankset and brakes individually. When it came to finding derailleurs, there were no front derailleurs to be found. Every site I searched had the dreaded BACKORDER next to them. I really didn't want to go Di2, but now that I have, I'm happy it turned out that way.
Likes For Bald Paul:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Liked 4,810 Times
yeah I could always sell the other parts.
Advocatus Diaboli
Liked 1,533 Times
Quoted: 696 Post(s)
Liked 910 Times
Before you begin you will need $1000-$1200.
Likes For Lolo03:
Bikes: two blacks, a blue and a white.
Quoted: 445 Post(s)
Liked 847 Times
You really gotta want that project, not the result, but the project itself. About a bazillion (someone will check that) posts around here from folks in the midst of a conversion with some head-scratcher problem that's blocking their progress. I do love Di2, so I get the vision, but unless that bike is the perfect fit and a frame you want to ride forever, I'd be looking to swap into a new ride instead of risking a "three times longer" project. Unless the project itself is part of the goal here.
Quoted: 3242 Post(s)
Liked 2,086 Times
You can re-use the Ultegra crank and b-bracket. And assuming you stay with rim brakes, you can use those. That means you need:
- Shifters
- F derailer
- R derailer
- Battery
- A junction
- B junction
- the BT transceiver if you want (useful)
- 6 - 7 E- tube cables
About $1100.
My 4 year old Di2 bike shifts much better than my 2 year old 105 bike and has needed no maintenance. I liked Di2 so much I put a 1X XT group on my mt. bike where I like it even better. Was it worh the $900 I paid when I got it on sale - Yes, it's a good system, I would not get a new carbon road bike without Di2.
EDIT: Not sure if ANY of this stuff is available......
- Shifters
- F derailer
- R derailer
- Battery
- A junction
- B junction
About $1100.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
Endurace CF SL 8 Disc | CANYON US
Endurace CF SL 8 Disc Di2 | CANYON US
Liked 4,810 Times
However, for each of us that had a great experience with it, there are probably those that had a lousy experience. A lot probably depends on the bike it was put on and how well it all lined up and was adjusted. I kept mine borderline perfect. It completed shifts up or down virtually as fast as I could push the levers.
However don't let that dissuade you from Di2 or even cable pulled Ultegra with hydraulic brakes. Ultegra is lighter than 105 by quite a bit.
And with Di2, I really like the full syncro shifting. I never have to worry or remember whether I have to shift the front too or not. And if you have the d-fly unit, you get a message at the top of your Garmin that lets you know the next shift will be a chainring shift.
Liked 1,471 Times
Yeah, surprised me to. I've heard some that claim their 105 5800 shifted much better than the version of 105 that replaced it that they also had experience with.
I don't use a Garmin (or any bike computer unit), but I see that the D-Fly also has an iPhone app.
Quoted: 229 Post(s)
Liked 327 Times
Despite not thinking it's a good value as an upgrade, Di2 is pretty cool. Unnecessary, but pretty cool. Once you get it adjusted properly it'll take approximately one ride for you to think it's meeting (perhaps exceeding) your expectations and that regardless of its cost at least it does what it's supposed to.
Likes For guachi:
