Tubeless on road bikes??
#176
Quoted: 1279 Post(s)
Liked 1,393 Times
The more efficient solution to small puncture flats is to use tires that have more flat resistance. Such as via. tread thickness and armor layers. Using irresponsibly lightweight tires and then depending on some messy slime to (temporarily) plug up holes is a suboptimal solution. Plus with the more robust normal clincher tires you don't have to deal with the mess, the special (expensive) tires with stiff (less compliant) sidewalls and the difficulty getting the beads to to seal etc.
Hey, I had tubeless on a recent gen Ultegra wheelset. Tires were impossible to install and remove without our shop-grade metal tire levers. Needed an air compressor to get any tires to seat. I tried, but it just wasn't worth the hassle.
Besides, if I need lightweight performance road gear, I'd be on tubulars. Strong, no pinch flats, and with 20cc of sealant injected, pretty much impenetrable to flats. Plus you save at least 100g per wheel, mainly in the rim.
#177
Quoted: 4416 Post(s)
Liked 4,872 Times
OK so now your criticism seems more reasonable. I also had a set of tubeless at the start that were near impossible to fit and it almost put me off for life. They were GP5000TLs. Since then I have used 3 types of high quality tubeless on 3 different wheelsets (IRCs and GP5000TR) and they are pretty easy to fit and I did two tyre swaps including new sealant in less than 10 minutes last week. I've never used a compressor in my life.
#178
Liked 1,393 Times
yeah, same. no metal tire levers, no special skills or hand strength. ±1850g weight for front and rear (disk brake) wheels including the tires, sealant, valves, rim tape.
#179
Quoted: 6972 Post(s)
Liked 10,970 Times
Man, you're confusing me.
Likes For Koyote:
#180
Quoted: 3956 Post(s)
Liked 7,308 Times
The loudest proponent of "rotating mass is critically important" is advocating for heavier tires. I'd say it's ironic, but that would be too generous.
Likes For tomato coupe:
#181
Yeah so my experience with modern tubeless has been that it just works. I have tubeless on two bikes (fatbike and road bike) and if I don't actually pull them off the rim they can be inflated with a hand pump after a adding sealant (or water in my case, since the sealant I use is water soluble and can be refreshed with water).
After I swap tires I use a track pump and soapy water to lift the tires on the rim. Usually takes a pump or two to get air tightness. The soapy water isn't always necessary, but it helps so much and takes so little effort that I just use it regardless.
Compressors were needed when tubeless standards were still all over the place and people (including myself) used tape to build up traditional rims shapes which would actually support a tubeless tire. But those days are long gone. The issue one might have these days is a tire / rim combo that's so tight that a tire is difficult to take off the rim. But that's really rare.
Likes For elcruxio:
#182
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,648 Times
After too many years of roadside, or trail-side, flat repair, I went tubeless. Zero flats in 3 years on the mtb - where I would have at least 5 a season. On the road bike only 1 sidewall cut which required a tube and boot and a roofing nail (which I was able to ride home on/with in the tire - which lost 5 lbs pressure which I plugged and rode 2000 miles with) in 4 years and 20,000+ miles. On my old tubed road bikes, I would fix at least 6-8 flats per year. The results speak for themselves, but to each their own.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
#183
Grupetto Bob
Liked 5,648 Times
The issue I need advice is regarding my wife’s Specialized Como e-bike. The bike is a portly 50 lbs, which is too heavy for her to change a tire. Besides, it requires special tools to remove the rear wheel. Removing the tires requires someone with Herculean strength or a vice to place the tire into. Since It appears Slime is a ‘no bueno” , so is there any well regarded sealant that can be used on a tubed bike?
She had a flat this last summer and had to call me to bring the car to rescue her and the bike. (She does have CO2 and an inflator which works for a slow leak, but that was not the case)
#184
Quoted: 682 Post(s)
Liked 453 Times
Can her wheels not take proper tubeless tyres? They tend to only need removing in 99% of cases back home/in a workshop.
but Orange Seal reckon their stuff works in tubes.
Likes For choddo:
#185
Liked 2,979 Times
-Oh Hey!
-Oh Hey!
Likes For Troul:
#186
Grupetto Bob
Liked 5,648 Times
Will have to see if they have tubeless in that size. They look like truck tires - but when they are supporting a 50lb bike plus rider, they have to be industrial.
Likes For choddo:
#188
Liked 4,872 Times
I have seen plenty of fat bike tubeless kits around, so I’m sure it can be done. It would make sense if you can.
Likes For PeteHski:
#189
Hey !
I tried my wheels to run tubeless and in fact it worked (Roval CLX32 rim brake - 2018-19 I think, I can't find manual for them, but I think they are not tubeless).
But, what was most annoying, that tubeless tape doesn't stick to carbon surface ! (I clean it few times with IPA).
and also when I remove tires, they are slighly glued to the tape, so when I remove the tire, the tape gets removed too :/
(tape is correct width - touching the sides)
How do you deal with that problem ?
#190
Quoted: 682 Post(s)
Liked 453 Times
Hey !
Like this
https://youtu.be/9Zr8rgP7MO4?si=4qYas3GrEHOE0xCI
#191
Not all rim tapes are alike and they must be the correct width to completely cover the ledge on both sides. Scotch 8898 is often recommended, but widths are limited. My BTLOS wheels have no spoke access holes and require no rim tape. I sold Zipp 303s wheels to get rid of rim tape.
Any rim tape without adhesive would obviously not work for tubeless.
