Can't put a 2x on this frame??
Building the newest All City Macho King ACE. But... Wait minute here... Did I really overlook that a 2x drivetrain can't be installed on this frame? There are no cable stops on the downtube. The outgoing model had a FD cable stop on the back of the seat tube.
The drivetrain I have for this bike is 2x. Is there a solution?
Non omnino gravis
I'm with you, but I want to occasionally do things like climb Mt Lemmon or whatever. Also, don't want to buy a new cassette and have a non functioning left shifter.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
That cassette is huge. Just run a 46 tooth front ring and leave it 1x.
Non omnino gravis
I regularly do big climbing days on my 1X bike, with a 44T in the front. Honestly, 44-32 is enough for 90% of rides, 44-36 gets another 5%, and the rest is met with 44-42. I often go several rides in a row without using the 42T.
For the left shifter: dropper post. My dropper is sitting in a drawer, waiting for the day I luck into a Rival HRD left shifter, as I currently have a Rival 1, and got tired of the bolt-on dropper lever.
Quoted: 186 Post(s)
Liked 234 Times
Sorry, I accidentally refered to Herman's picture. I still think you would be best with 1x. When I had an 11-32 cassette on my Cross Check I never took it off the 46 tooth ring except for loaded touring.
A.) New chainring, bolts, cassette and be left with a non-functional left shifter and not enough gear range in 10 percent of situations.
B.) Sell this frame and buy a different one that's 2x compatible.
Update for future reference. So it is looking like I can route the shifters using full length housing. This is something I've never done before, and I won't have a barrel adjuster for the FD unless I install an in line one. But, it looks like the braze ons on the down tube are made in such a way that you can route 3 housings and zip tie them all in. And, at the bottom of my FD there is a stop for a ferrule.
Quoted: 336 Post(s)
Liked 309 Times
Do you have a threaded hole at the bottom of the BB shell?
You can buy a cable guide with a housing stop:
https://www.universalcycles.com/shop...&category=1613
I'll check when I get home. Just bought a ton of housing and some clamp on guides that accomodate full housing for the bb shell. Some threads on FD adjustment w/o a barrel adjuster suggest it's not necessary to have a barrel for the FD.
Quoted: 1324 Post(s)
Liked 927 Times
What diameter is your seat tube? Is it too big a diameter to accept clamp-on cable guides?
Cheers
Cheers
Quoted: 336 Post(s)
Liked 309 Times
You shouldn't need clamp on guides. All-City and QBP are pretty good about using "3 sided" housing braze-ons where they think that versatility is needed. I have them on an older Macho Man, a Salsa El Mariachi, and a Surly Troll.
Quoted: 336 Post(s)
Liked 309 Times
Thanks. This would work perfectly for the FD. I am going to attempt the routing with full housing all the way to the cable stop on the FD and see how that works. If something doesn't work about it this is a perfect solution, for the FD at least. RD will still get a full run of housing all the way to the barrel adjuster on the RD.
That's going to be a great looking bike. Nice choice.
Are you wanting Shimano 2x11? New toggle style derailleurs can run housing the full length to the derailleur without a stop. https://si.shimano.com/pdfs/dm/DM-RAFD001-04-ENG.pdf pg 16. These also have integrated cable tension adjustment and don't need a barrel adjustor.
Bikes: Voodoo Hoodoo, Linus Libertine
Quoted: 106 Post(s)
Liked 15 Times
Full length housings for all 4 cables.
Likes For hermanchauw:
In any case, I wouldn't use a single chainring on a road bike unless I lived in a mostly flat area, mainly because 1x means either small gear range or huge jumps between gears (which are a PITA in a road bike if you want to go moderately fast as you can't find an ideal cadence).
Non omnino gravis
Just because you can't doesn't mean it's impossible. That 1X bike has been to Onyx Summit (+8,000ft in 40 miles)twice and Forest Falls (4,500ft in 20 miles) too many times to count.
The tried and tired "huge jumps in gears" shout of the anti-1X... meh. I have maybe 25k miles, perhaps 650k feet climbed on 1X.
But I also don't believe there's some sort of magic sweet-spot cadence that I have to pedal at for every ride. Try riding a singlespeed sometime.
Constant tinkerer
Professional riders have been seen riding compact chainrings during "La Vuelta" coupled with a 32 cassette, and most of what they climb is not that steep. I assume you're stronger than them!
BTW, on my commute I regularly do one of such steep climbs (so have lots of GPS records of it). I started with a 34-26, then 34/28 and finally 34/32. Guess what? The 34/32 is not only easier on you and doesn't leave you and your knees knackered at the top, it's also way faster.
Non omnino gravis
Likes For DrIsotope:
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
