Safest way to shift gears
Is there a safest way to shift gears with wearing these down? I notice the teeth on the cassette are wearing down.
Quoted: 680 Post(s)
Liked 948 Times
well it sounds ike you need a new drive train and your chain is really worn. just let up on the pressure when you shift. keep your chain lubed and check it for wear.
Likes For fooferdoggie:
The method of shifting of gears is not material to the life of the cassette, IMHO. Ease up on the pedal pressure just before and during the shift IF shifting to a lower gear. Keep your chain lubed and free of grit for best results. Of course, if you have difficulty shifting, that may indicate a deficiency in your methodology. I like to shift before I need to shift, when shifting to a lower gear. That applies to both pavement and gravel riding. 1x or 2x.
Likes For DeadGrandpa:
Quoted: 1438 Post(s)
Liked 1,092 Times
Those "chipped off" teeth are shaped that way to ease shifting. If you look carefully you will see that they are periodically located around the cogs and are associated with the stamped/machined shifting ramps on the sides of the cogs.
Likes For dsbrantjr:
Quoted: 2026 Post(s)
Liked 1,096 Times
It's better to shift in advance rather than waiting for pedaling to get very difficult before you do. If you do get stuck in a too high gear, momentarily easing up on the pedals will make shifting easier and less likely to cause damage.
OP: That photo of the cog teeth you posted shows perfectly normal and intentional tooth shape. Those teeth are shaped that way on purpose as shifting aids and nothing is chipped or broken.
Expired Member
Quoted: 3665 Post(s)
Liked 5,420 Times
That's a very clean cassette and chain, good job!
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Your drivetrain is brand new, it's not chipped or damaged in anyway. Plan ahead, don't shift at really low cadence while pedaling hard. Look at some YT videos about how to lube your chain. The rag is the most important part.
Likes For cxwrench:
Yes and no. If you wipe and lube your chain at reasonable intervals, depending on your weight, strength and terrane, replacing your cassette and chain every 5,000 to 10,000 miles is sufficient. If you change your chain more frequently, the cassette may be good for two or three chains before it starts to skip. As for chainrings, they last a LOT longer than a chain or cassette. 25,000 to 50,000 miles is common on a set of chainrings.
This is the best way to maintain your drive train for long life. Chain care, wear and skipping by Jobst Brandt (sheldonbrown.com)
