Paint removal from chrome safely
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 981 Post(s)
Liked 631 Times
I have a fork here, chrome under the paint; I want to do an all-chrome fork. I am using paint stripper but it's slow going. Mostly, the issue is removing the "goo" comprising drying stripper and the paint. I do not want to damage the chrome -- I have a package of ScotchBrite pads here, is that safe to use without scratching the chrome? I presume they will "laid up" quickly and I'll use several before it's all done.
Then I want to polish it up... I have Blue Magic here, but also the electric buffer and using red rouge, which works nicely on aluminum but is it "chrome-friendly"?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
+10000 on this, pads and steel wool no matter how fine will scratch the chrome. When I use paint stripper on chrome I normally do not let the stripper "dry". Now that you have loosened the paint up so it is gooey, apply another coat, and when it bubbles again wipe it off immediately....it will glide off the chrome.
Best, Ben
Voltaire
Voltaire
Quoted: 981 Post(s)
Liked 631 Times
Tiger,
Best, Ben
Best, Ben
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
If you're stripping a chromovelato fork, or the original translucent acrylic enamel over chroming, be aware that the chrome plating underneath is likely to be rough, and may not polish up well. Paint doesn't stick to chrome well because of the invisible oxide layer, so manufacturers using the chromovelato technique used a less polished chrome finish to help paint adhesion.It's also likely to be much thinner than chroming intended for the final finish.
Strong Walker
I do use steel wool sometimes on chrome for rust spots that resist the chrome polish, but one has to be careful and buff it up afterwards again which is a pain.
Liked 2,180 Times
yes reapply the stripper and wipe don't scrape..... RU using airplane stripper?
Voltaire
Voltaire
2-Wheeled Fool
Liked 677 Times
Use a plastic putty knife or a paint stirrer stick. Neither of those will hurt the chrome. Wipe up what is left over with paper towels and set the used-up towels out to dry in the open air. When dry dispose of in the trash.
Quoted: 3464 Post(s)
Liked 2,828 Times
Liked 2,180 Times
I am glad I still have some cans in the shop.
Ben
Voltaire
Voltaire
Bikes: '72 Raleigh Super Course; '90 Cannondale ST1000; '98/99 Cannondale T700; 2002 Cannondale CAAD5 R700; 2022 Cannondale Topstone 2L
Quoted: 166 Post(s)
Liked 348 Times
I'd think acetone or paint thinner (wear gloves) should be able to clean up any of the residual gunk left over from the stripper and finish off any small areas of leftover paint. Use a rag. Follow that up using a rag slightly damp with water to clean off whichever you used.
Quoted: 981 Post(s)
Liked 631 Times
I use a wooden spatula for that, a plastic one will also do (chrome is quite hard). Actually, paint has a very hard job sticking to chrome so maybe your paint stripper isn't the strongest - there are huge differences even between the typical hardwares hop available non-aircraft grade stuff. I do use steel wool sometimes on chrome for rust spots that resist the chrome polish, but one has to be careful and buff it up afterwards again which is a pain.
Well, there went my "Plan B".
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,793 Times
I once sent in a frame to be powder coated, and taped off the fork with high temp tape to show where I wanted it to be masked off, assuming the powder coater would mask off the rest of the chrome. He didn't, so I had a small strip of chrome. I searched online and found that automative gasket remover will remove powder coat (and if it can remove powder coat, paint should be a snap!).
It worked for me. Just coat it on, wait, then use a plastic scraper. I had to use 2-3 coats of gasket remove to do the job, but I got it all off. I used Permatex gasket remover, but others may work as well.
Liked 2,180 Times
T 1964,
Wood is good, I wonder if the stripper that you are using has lost a little of its strength, try reapplying your stripper to the part (perhaps wrapping it with PT). If you have lacquer thinner try a wrap with that and don't let it dry out, then use those high-tech $ store wooden tools to scrape with.
Best, Ben
Best, Ben
Voltaire
Voltaire
Quoted: 981 Post(s)
Liked 631 Times
Well, another application and this time using a wooden spoon, cut as I mentioned to make one concave side; much more scraped off this time! Still not right, so...
Wood is NOT good, in one way. Looking at the can of stripper, it took the spray-bombed paint job off my old Gitane two years ago, no problem -- but I looked at the can and it's Klean Strip brand and intended to remove paint from wood (well OK, I do want to refinish the bedroom furniture I inherited from my grandmother). So, I checked online and there's an Auto Zone perhaps 1/2-mile away (ironically next door to the dollar store where I just bought the wooden implements ) and, according to the website, in stock! So, another walk, and I got a can (only had it in gallons for $52.99) and I just put a coat on. Lesson of the day: RTFL (read the flippin' label).
What I am starting to believe, between the paint stripping, degreasing parts and polishing, that I need a metric ton of rags.
T 1964,
Best, Ben
Best, Ben
Liked 2,180 Times
Best, Ben
Voltaire
Voltaire
I would personally talk to your local sandblasting or electroplating shop and ask an industry pro their advice. Blasting is likely to be too rough but there are some soft blasting media out there (made of plastic) that may well do the job, not sure. If they don't have any good advice you've established contacts who can strip and re-plate your fork!
I had a similar problem trying to preserve the chrome under a frame I was repainting last year but eventually decided it wasn't worth the headache.
Quoted: 1372 Post(s)
Liked 1,751 Times
Though I hate using chemicals in my hobby, I used a twenty or thirty year old can of paint stripper, "PolyStrip" as I recall. I saved the original decals by working close to them with the chemical then carefully scraping off close to the decal with an alloy scraper. Worked out pretty good...
Likes For randyjawa:
Quoted: 981 Post(s)
Liked 631 Times
I would personally talk to your local sandblasting or electroplating shop and ask an industry pro their advice. Blasting is likely to be too rough but there are some soft blasting media out there (made of plastic) that may well do the job, not sure. If they don't have any good advice you've established contacts who can strip and re-plate your fork! I had a similar problem trying to preserve the chrome under a frame I was repainting last year but eventually decided it wasn't worth the headache.
Doh! And I have a good selection of wood shim stock, a little trimming on the end would have worked.
(a) 1st attempt with the aircraft paint stripper wasn't that much better than the wood stripper... OK, somewhat better. But I see 2-3 more coats to get everything out of the corners, like where the fork blades enter the crown. It's 55F in the unheated basement, and maybe it would work better if I brought the project into the heated part of the house. I recall stripping the car, the stuff did not work for beans in the cold of a neighbor's unheated garage; a few warm days and the paint all came off.
(b) I have enough off the blades now that I can see the underlying chrome. Dull. I tried the electric buffer and it did not brighten up. So, a lot of work to get to bare metal -- and it is still going to the chrome shop. Sigh.
The dropped
Liked 1,014 Times
I know; should have added a "wink". Hmm, what is "PT"?
On a different part, I had already contacted the chrome shop I use and do have blasting facilities - but I did not ask what media.
If my results were like that, I'd be pleased. That said,
Strong Walker
That right there tells you all you need to know. You're going to have it blasted, right? So save the chemicals and time and get started on figuring out the costs of blasting and chroming. I know locally (Columbus, OH) there are a handful of outfits that will blast with dry ice, soda, on up to the heavier blasting media, depending on the goal and substrate.
The dropped
Liked 1,014 Times
Read it again carefully, and the main thought should be, "you'll want it blasted to remove every trace of paint anyway, so continuing to strip the paint off with chemicals is likely wasting time."
Quoted: 981 Post(s)
Liked 631 Times
i am surprised there is anybody still plating, especially right here outside Washington DC; one would think the technology would be regulated out of existence. That said, I do like shiny chrome.
Quoted: 1303 Post(s)
Liked 1,908 Times
Tiger,
I use a product called Strypeze from Savogram products. It is a gel type of stripper and removes almost everything I have used it on. The other option for you is to just send it to a shop and have it hot tanked in an alkaline solution that will remove all paint. I just sent a Fuji team in for that treatment to clean the chrome under the paint. Cost will be about $10 for an overnight dip. Smiles, MH
