What Gearing Are You Running?
paul, are you planning a trip or just asking the question?
If so, where, and how much weight will you carry, ie total bike weight
and how much do you weigh?
Quoted: 3455 Post(s)
Liked 1,454 Times
My two derailleur touring bikes have the same gearing but different wheel sizes (700c and 26 inch). The front is 46/42/24 (triple with half step + granny) and 11/32 Sram eight speed cassette, depending on which bike and which tires are in use, the lowest gear ranges from 19.2 to 20.7 gear inches.
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 310 Times
Either 46/34/20 11-34 or 46/34/20 11-36 on 700C wheels. That gives me a range of either 113" gear to 16" gear or a 113" gear to a 15" gear. To be honest the 11-34 works a bit better.
How come?
With 14, 15, 16, maybe pushing 17% between shifts, the "difference" between shifts is ok and not a pain in the keester----when you get 20% diff between shifts, its a pain in the arse sometimes of being "a bit too low, or a bit too high", in terms of cadence
when I started being serious about riding and got into touring, I had a 6 speed, no recollection of what its gearing was, but my next bike was a 7 speed, and with a 12-30, I had percentage shifts of
15.4%, 13, 15, 17.6, 13.3, 15.4---the 17.6 was a bit annoying at times
go to the 9 speed era and my 11-34 has percentage shifts of:
13.3, 15.4, 13, 15, 17.6, 13.3, 15.4, 18.2---very similar, and liveable with that middle 17.6% jump shift
I ride a commuter with a 7 speed 11-28, and it has a 20% jump shift between the 15t and the 18t cog--which every day I find a bit of a nuisance, and Im not even fully loaded, add a full load and a 20%jump is a pain.
back in the day, with 5 and 6 speeds, bigger percentages were going to be inevitable, so the half step was thought of, to bring the jumps down in terms of percentages.
but today, with 10 speed being commonplace, (and 11 available, or even 12 speeds), you can have a nice 10 speed cassette of 11-36, with very nice percentage jumps of
12.5, 14.3, 16.7, 14.3, 10.5, 11.8, 13.3, 15.4, 18.2
a really nice bunch of slightly closer shifts than a 9 speed 11-32 or 11-34 that used to be the norm,
As someone who has ridden a lot of diff bikes, the modern drivetrains with more speeds, and at least with up to 10 speeds, similar lifespan of chains etc as 9 speed, its pretty cool that you can get your cake and eat it too----nice range of cassettes and reasonabley nice jumps between shifts.
Heck, if you used a mtn triple and a 10 speed system, you could have a tighter cassette, so even closer shifts, and still have a pretty darn good low gear.
phew, long winded response to "what happened to half step gearing", but in the end, more speeds just made the half step redundant, as we can have a larger range of gearing AND lower percentage jumps between shifts.
just another gosling
Quoted: 3885 Post(s)
Liked 1,938 Times
On our tandem, 53-39-26 in front, 12-34 in back. We tend to tour light, maybe 45 lbs. of total load counting everything. Works up to ~17%. Our team age is 142.
Results matter
Results matter
I don't think I've said this before, but I love this. Kudos to you and all of the oldes riders on this forum. It's such a wonderful sport that if we take care of our bodies, we are able to participate through various ages.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1233 Post(s)
Liked 318 Times
I am in the mountains NOW on my 120 lb rhinocerous, LOL. With a 46/16 ROHOFF14, 36T is LAUGHABLE. Since noon May 18, I have done 630 miles, thru Calgary, Banff, Golden, Revelstoke, Sicamous. 2 rest/ laundry days. Sunday I had to do the whole 94 mile Rogers Pass with 4600 ft climbs, that is like 3x Hai Van passes Da Nang to Lang Co, that I did in 2014. The lodge/ cafe in the middle is permanently closed. I got hot and tired as hell, so I walked a couple miles rather than uselessly slog at 4 mph. IMO using derailleur is a HUGE mistake. I haven't even bothered to lube my covered chain yet. I am also 64. I also did 88 miles to SW Calgary the fourth day. My Rohloff now has 12,180 EASY trouble free miles. My SMP tires now have 8,000+ miles. I also have a XL SA Dyno DRUM brake on the front with 20,000 miles, NOTHING is better. MY rear brake is IRRELEVANT.
On the TA and my other early tours when I was packing more heavily I used 48/36/26 and 12-32 to start with and swapped out the 26 for a 24. It was adequate.
Since I started packing much lighter I did the ST with 39/26 and 12-28 and it was okay for the Southern Tier. The 39/26 ultra compact double was actually a triple with no outer ring. That was with 14# of UL backpacking gear though so essentially unladen, but I really enjoyed that setup.
My other recent tours were on a mountain bike and a mix of dirt, gravel, and pavement.
If I were to build a bike from scratch now, I think I'd use a 1X10 MTB drive train.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2134 Post(s)
Liked 1,643 Times
Part of the reason that I asked is that I want to build a Lynskey Touring bike for myself for a retirement gift and I want to tour out west. I am 5'11" 175. I have bad knees and live in the flatlands. I will go lightly loaded. Kinda credit card touring. No cooking along the way. I know based on my experiences riding in the mountains that I need the equivalent of 22/34 gearing to comfortably tackle the steep stuff. I want drop bar shifters. Nothing on the flats and nothing on the ends. I have my reasons for that. So as I started trying to mentally assemble my drivetrain, I am finding it doesn't really exist without doing piecemeal work. It looks like most of you are running triples up front and stuff in the 11-34 range in the back, and best I can figure there's not a road group I can buy today that will give me that. I want to buy some good quality stuff.
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
I'm guessing obsoleted by 11 speed cassettes and compact cranks? Although, I know a few around here still enjoy. My Miyata 610 had it, while I could see some uses, it just seemed like a waste of a chainring for what you actually got when you are running more than five gears on the back.
Really good that you are aware and realistic of what gearing you want at the low end. One of my bikes is with 22/34 and I love the low gearing, its a 26in bike so even lower than 700 stuff, 16.7 gear inches with 2in tires on--and works perfectly for its intended use, ie travelling in far off areas with more weight than usual, spare this, spare that, extra water, food, much steeper hills than we tend to have here in N America.
Thats the great thing with nice low low gearing, its there when you want it, and your knees like it, but with any reasonably range of gearing, you can still ride along at 20kph or 30kph with no problems. From all of my touring experience, it is extremely rare to be able to maintain more than 30kph, or 20mph, and my 26in bike with a 9 speed 44/32/22 and 11-34 covers the range of speeds I regularly ride at, whether it be 5 or 6kph on a hard slog steep hill, or 50kph on a downhill.
On this bike, I too didnt want bar ends or topbar stuff, and shied away from sti's, and went with Gevenalle shifters, hood shifters but very simple. Slightly quirky in some aspects, but they are dead simple and work well when set up properly.
Mountain bike triples (rare today) are slightly low geared for unloaded riding, but as you say, first you have to see what is around still, and then you have to deal with the incompatibilities with sti's and mtn stuff rear/front derailleurs etc.
Were you thinking of going 9, 10, 11 speed?
10 seems to be the new standard, and while there are great cranksets like the deore 48/36/26 ten speed, (which you can easily change out the 26 to smaller rings) you still get the issue of mtn bike vs road shifter issues....
With 10 speed, cassettes like 11-36 or larger can help with things a lot, but ulitimately, its the darn sti shifter problems that come back all the time isnt it?
It will be interesting to see wehre this discussion goes, as I cant recall what sti shifter solutions have been figured out so far in the mtn vs road, dyna-sis vs roadie issues that have been around now for a bunch of years, pretty much since 10 speed came in.
If you lived close, I'd let you try my gevenalle bike, but thats not an option.
Do look at their website though, there used to be some vids on it showing them in use, but in any case, they aren't as nice using as sti shifters, which could be a factor for you. When I say, not as nice, meaning, they are slower, shifting is more deliberate, but at least they are on teh hoods, which I like a lot. Ive spent about 3 months or more riding them in Latin America, and like them a lot, but as I have a sti bike, I do notice the diff with sti. Kinda like a sports car manual transmission vs a slow slightly klunky standard, if you get my drift--a slight over exaggeration, but gives an idea.
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,204 Times
The 36 is just outside of the range of the XTR rear derailer I use. It's a bit clattery. And even I'll admit that the 1 gear inch difference isn't enough to notice. 16 gear inches is still way lower than most people use.
Stuart Black
Stuart Black
For The Fun of It
Liked 1,643 Times
I have a thread going up in Bicycle Mechanics about drive train specifics, so we don't need to hash that out here. I just wondered how many tourists were running readily available drive trains. I guess tourists don't make up enough of the market to warrant producing purpose built touring drive trains. I am leaning toward 10 speed as there seems to be more 10 speed stuff available.
At bike shops, and their wholesale sources, there are service & replacement parts, for 8 & 9 speed, available
although the heavily promoted is now 10& 11 & so if you only look at online discounters, that is what you find ..
IMO Gear ratios are more important than "Speeds", a parts count of how many cogs are stacked together on rear hub..
Quoted: 138 Post(s)
Liked 17 Times
50x39x30 generally 50 or 39 depending on how steep the climbs are. 11x27 in the rear. Generally I run 50x39 on the front and 17-19 on the rear. I did a 5400 miles bike including out and back across the Appalachians in 2014 on a single speed 52x19 and 40 pounds of gear. I don't mind standing up for climbs...I do it all the time around home. Currently riding a 50x17 single speed and carrying at least a laptop on me everyday and a couple of times a week carrying groceries adding an extra 6-10 pounds to the bike. I do it all the time, year round so I'm use to it. For someone that rides only a few times a year you needed the granny gears...or someone like me back in 2015 when I didn't realize what I was dealing with(ultra cycling complications that just turned to big boy like me into a woos).
Liked 4,204 Times
And you are correct in assuming that we don't make up that much of the market. Adventure bikes have changed that temporarily but I suspect just that...it's temporary. Some other fad will come along to make shove Adventure bikes off the market.
I would most hardily agree. People have always been more concerned about how many gears they have rather then how the gears work. Even Shimano doesn't seem to know how gearing works which is why we end up with drivetrains with huge gaping holes in them.
Stuart Black
Stuart Black
Liked 1,454 Times
Some Titanium frames do not have clearance for a triple, my Backroad does. You can see in the photo how the chainstay was constructed to have the room for a third chainring. If you decide you want a triple, make sure that the frame you order has room for a triple.
A friend of mine has a Habanero Ti frame bike that he tours on, he is very happy with that bike. I think his was sold as a cyclocross model.
One last point - if you get a Lynskey, there are two small screws that hold each rear dropout in the frame. Remove the screws, put some threadlocker on them and re-install. One of mine vibrated loose and caused me a mess of trouble. I told a gal I met that had a Lynskey about that, she said that it had happened to her too.
For The Fun of It
Liked 1,643 Times
Great post. Thank you. I need an ML in a Lynskey. Are the ones on Ebay also on the Lynskey site?
Liked 1,454 Times
Alan S on this forum has an Lynskey Urbano model that he does very light touring with, he has been pretty happy with his from what I can tell.
One quick comment on a surprise I had when I built mine up. The rack mounts are quite a bit higher above the axle than is the norm. Thus, your rack will sit much higher than typical. So, when you go to install a rack on your new Lynskey, your rack will look a bit odd. You can see in the photo of mine (above) how high that mount is above the axle.
It is not the best photo, but this is what my Lynskey looks like on a tour.
Bicyclerider4life
26" Mountain Bike set up for touring: Seven Speed 14-34 in back. Currently 28/38/42 BioPace in front, but I might go back to a 22/32/38 in the front.
24" Trike:
Seven Speed 14-28 in rear, 28 tooth in front.
24" Trike:
I run 50-34 and 11-34, it is not ideal but is what I have. Will be going to 46-30 when the front chainrings wear out.
Liked 4,204 Times
That is too broad a statement. There is nothing about any titanium frame that should prohibit the use of a triple. The tubing diameter on a titanium bike isn't particularly oversized nor are the chain stays necessarily wide on a titanium bike. I have 3 titanium bikes and they all have triples. Two are mountain bikes with wide chain stays like you'd expect on a mountain bike and one is a fast road bike. It still has a triple on it and even a very large triple at that (52/49/30). There were no issues setting up any of these bikes.
Stuart Black
Stuart Black
Liked 1,454 Times
Maybe you got lucky with your frames.
