Bike Computer Accuracy
Quoted: 180 Post(s)
Liked 85 Times
For rides, I use a bike computer (magnet in the spokes) and Ride With GPS on an iPhone. For distance, both provide similar results (20 miles vs. 19.9 miles). But for speed, the difference is bothersome (14 mph vs. 13.5 mps). Is this typical?
I ride along the road (with some trails) in the suburbs..
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
Bike Computer set with Roll OUT Measurements is most accurate..
Fred "The Real Fred"
Likes For 10 Wheels:
Quoted: 645 Post(s)
Liked 797 Times
Likes For aplcr0331:
The speed and distance on the computer are only as accurate as the value used for the tire circumference. Standard values listed for each tire size are close, but I measure the length of 3 revolutions, several times, then convert my inches measurement to millimeters. Having your weight on the bike will further improve accuracy. The tire will squish and the effective radius will be smaller.
Likes For DaveSSS:
Likes For berner:
Quoted: 823 Post(s)
Liked 1,961 Times
My simple Cateye with a magnetic sensor matches usually within .10 of a mile with the ridewithgps route planner app on 50+ mile rides.
I stopped using Garmin because it grossly inflated elevation gains. It is more accurate to just use the ridewithgps mapping function to figure out elevation gain.
Likes For CAT7RDR:
Liked 1,245 Times
A Roll Out is Necessary as it relates to Tire PSA and Weight of the Rider.
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
The correction for distance Strava uses if you're on pretty well known roads and routes is pretty accurate. However, you "instantaneous" speed shown on the GPS is most accurate if using a wheel speed sensor with accurate info inserted in for that sensor (rollout, tire size, etc...).
One thing I've seen is that if you're a runner, I have the slowest runs by far on curvy greenway/MUP runs where the curves are so small that the GPS mesh coords are much larger than the curves. Thus, you lose a solid amount of distance that it can't really correct for.
I could assume MTB folks also suffer from this and rollout may work better for distance the curvier your route is.
My most accurate distance/times for running pace are on arrow straight streets and roads with really steady curves to them when they do turn.
Either way, I train on rides to time spent in zones combined with overall TSS. I don't really bother looking at the speed or distance as it is irrelevant sometimes. I only went 18mi yesterday in an hour on a 30/30 vo2 workout but went uphill almost 1900ft. I was chasing X sets of 30/30 and an overall TSS score for the workout. I hit my sets, then free-rode at Z2 and tempo till I hit my TSS score. Then went home.
It doesn't really bother me ever unless doing my super nerd time trial equipment testing. Then I care about the details a bit more.
Likes For burnthesheep:
Sr Member on Sr bikes
Just wondering if this a look at actual current speed sometime mid-ride. Or, if it’s the average speed you see after the ride has finished? Just asking because I think the two would likely be different while looking at them mid-ride due to the frequency of how often the speed is determined.
Dan
Dan
Quoted: 3242 Post(s)
Liked 2,090 Times
In my experience, GPS devices are inaccurate as to speed at that moment. There’s always a few seconds of lag in the display. Is why I use speed sensors.
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
I think the OP is saying that speed is pretty accurate between both.. So if the problem is the Avg Speed/Hr, then the problem lays in the difference in how the 2 devices are measuring time (moving, stopped, overall, etc etc.. lots of possible differences).
Likes For Sy Reene:
Quoted: 768 Post(s)
Liked 1,747 Times
^^ This... I wrote a database app many moons ago that I stored all my ride info in and I noticed that my avg time and speed were always off slightly. Came down to rounding from the computer and my db. I carried out digits 3 places for some off reason and the computer app only carried it out to 1. I changed my coding to only show a single digit east of the decimal and boom.....match.
Quoted: 4560 Post(s)
Liked 2,802 Times
Auto pause/resume with most apps and *some* bike computers will also influence readings for speed, distance and time. Some auto-pause/resume settings are adjustable, some aren't.
I've run a dedicated bike computer and two phones with apps (Wahoo Fitness on one, Strava on the other) and they all differ slightly. Not enough to worry about. I was never close enough to a KOM for a 0.5 mph or 1 minute difference to matter over over my favorite routes. It might affect a top 10 position, but as younger, stronger and faster riders use those same routes I'll never be anywhere near a top 10, let alone a KOM. So my best times/speeds will be jockeying for middle of the pack honors, along with almost every other MAMIL.
If I was serious I'd try a wired bike computer calibrated to my wheel/tire diameter, etc., as described above.
Likes For canklecat:
Quoted: 258 Post(s)
Liked 291 Times
On my Novara, I have a Sigma with mag sensor. It's set pretty accurately - it matches every mile marker around the river trails here and on the GAP even over long distances.
Quoted: 2604 Post(s)
Liked 1,933 Times
When I'm feeling obsessive-compulsive over distance and/or speed, the wired (or wireless) cyclocomputer with a wheel sensor is my go-to measurement device. I've got a nice downhill ridge near home I can coast down, and compare the computer's measured distance with the mile markers. If I'm within 1%, it's fine; more than 2%, time to adjust the calibration. I've gotten it within 0.5% some months, and then the tire gets worn and/or replaced, and the next time it's up to 1% match.
A few key features of the above. First, I'm coasting downhill, so there's minimal side-to-side pedal tracking to affect the distance measured. Second, because it's a U.S. highway, I trust the mile markers to be accurate. (Don't try this in Kansas or Missouri -- I think they sell mile markers at Walmart in those states, and farmers pick out a pretty green sign to put up near their farms without regards to location or numbers) Finally, curves are pretty wide, even on the ridge.
GPS devices sometimes match the cyclocomputer pretty closely, as long as the comparison is on a straight, treeless road with no large buildings nearby. On my more typical rides (curvy, trees, hillsides blocking some satellite signals), the GPS distance is off. It's still good if I need help mapping or navigating, but I don't trust the distance the GPS measures. Ergo, I figure the instantaneous speed measurement is in the ballpark, but it's more for entertainment than precise measuring.
Quoted: 347 Post(s)
Liked 418 Times
I use RWGPS post ride to fix the speed and elevation numbers.
Those complaining about a 0.6% difference is kind of insane in my book. That’s 15.00mph vs. 15.09mph, or for most practical purposes ‘the same’ number. The speedometer in your car is often has no better accuracy wise than this.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
Bikes: 1995 Specialized Rockhopper,1989 Specialized Rock Combo, 2013 Specialized Tarmac Elite
Quoted: 213 Post(s)
Liked 588 Times
Meh. My Garmin Edge 25 is close enough for me, although it's a bit off from my riding partner's computer of unknown make. I ain't settin' any speed or distance records.
Quoted: 440 Post(s)
Liked 264 Times
Bikes: nothing to brag about
Quoted: 130 Post(s)
Liked 206 Times
You can't ride an hour (or a half, or fifteen minutes) and see how far you've come, calculate your average speed, and know which one is right????
Quoted: 896 Post(s)
Liked 2,065 Times
If the sensor and magnet are correctly installed, the wired computer will be virtually100% accurate at counting wheel revolutions. Converting wheel revolutions to distance, measuring time, calculating speed from time & distance, then displaying speed on the screen, are matters of calibration, software, and hardware. There may be calculation inaccuracies and delays updating the display. Generally I think most cyclocomputers are pretty good, but they are not all equal.
Theoretically, if well calibrated, this should be far more precise than a GPS at both instantaneous speed and speed and distance over a long ride.
Likes For downtube42:
The difference in measured distance between my cycle computer and Strava is pretty substantial, around 2%. Since I have a wired computer from a brand I have had only good experience with (Sigma), and I measured the tire circumference carefully when setting it up, I'm inclined to trust the computer instead of GPS. I mean, 2% of the measured 2220mm circumference (which also corresponds to the figures cited online for this tire size within a few mm) is 44mm - it's virtually impossible to be off by that much. The accuracy of speed measurements aren't that important to me, but such a difference in distance would translate to almost a whole century over my yearly mileage.
