Do I need to buy new levers?
Bikes: Peugeot CFX-10
Hi, I apologise if this is not the right place to post but I've recently purchased a Peugeot CFX-10 in well, working order. It has Dia Compe 'Red Dot' brake levers on the drops as of current, they work perfectly but have no hood covers which makes them quite uncomfortable. I recently purchased some NOS Dia Compe hood covers and upon going to install them realised they won't fit due to the "Red Dot" screw end sticking out way out of the brake cover. From what I can find online (With my limited knowledge of bikes, vintage or not) it would seem that these are used for another set of top brake levers to screw into.
Do I need to buy new levers altogether? Can I find a replacement screw that's shorter or will I have to simply modify the hood covers to accommodate for this screw (the route I really don't want to take as the screws are uncomfortable to rest hands on)? I've attached some pictures of said levers,
Thanks!
Thanks!
Quoted: 4802 Post(s)
Liked 3,922 Times
We used to just hacksaw off that end of the pivot. Quick and dirty is to just use the lever body side as a guide though you will end up with hacksaw scratches on the body. Well hidden by the hoods so only you will know. Or you could scribe the protruding bolt with a knife, disassemble the lever and do a clean cut and filing of the pin and have it looking like it was made that way. (You may have press fits for the pin that may or may not take well to disassembly. The Q & D approach means not messing with them.)
Ben
Ben
Quoted: 659 Post(s)
Liked 595 Times
Remnants of turkey wings. Be off with them.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
Thanks!
Thanks!
Congratulations! I hope you get it all put together and enjoying the ride soon!
Commence to jigglin’ huh?!?!
Thanks for the responses folks! I didn't even think sawing it off would be a viable option so that helps a lot and saves me money!
Quoted: 1639 Post(s)
Liked 828 Times
IIRC, the CFX was sold as Peugeot's 80's genuinely racing frameset, with it's high quality full Reynolds 531 double butted tubeset, so it's not surprising to see such components that might have just been conveniently on had installed on it. Saying that, I would have just replaced the levers with something better that matches up with the caliber of the frame as those DiaCompes were pretty much bottom end market items that had been adapted to the race frame. If you want to stay with DiaCompes, you can still buy better ones at very reasonable prices like the non-aero versions of their RGC (Royal Grand Comp) model levers vor very reasonable prices, even at NOS condition. Otherwise, you could also consider European made levers and brakesets (Mafac, Spidel, CLB........), but those will most likely cost quite a bit more than Japanese period components. Swiss/German levers from Weinmann will mostly be cheaper than thaose French brands, but will be at home on that Peugeot frame, as Peugeot had Weinmann brakesets on a lot of the bikes in the 70's and 80's.
Here's a photo of the bike with a carbo tourmalet behind:
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Yeah I recognised the frame and acted pretty swiftly on purchasing it. It's got Campy hubs, a Weinmann stem and Sakae bars, the Shamano derailleur lets it down a bit, are Wienmann a much better lever over the Dia then? I'm trying to find parts without breaking the bank as I'm not really interested in restoring it to original period or parts.
Quoted: 3464 Post(s)
Liked 2,828 Times
Some levers had a red button on the front that acted as a lever stop. Push it in and the lever would travel farther into the body, opening up the caliper for easier wheel removal. The next application of the brake would expose the red button and the lever would stop at the dot once more.
Old bikes, Older guy
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 250 Post(s)
Liked 165 Times
Hi,
If you have a co-op in your area, you might be able to pick up some nice drilled levers, either Weinmann or Dia Compe. At the Portland Co-op I got a nice pair of drilled Weinmanns with decent hoods for $10.
Good luck
Good luck
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
It's been ages but IIRC the LBS I worked at in the early 80s had a drawer of replacement pivots for people that took off their turkey wings. Personally I would just saw them off if gum hoods are going over them anyway.
Dia Compe brakes were Weinmanns built under license. Generally exactly the same. I know there's people that feel one or the other was better but IMO not really. Gran Compe were an upgrade though, for sure.
Oh, like this. No guarantees or affiliation though. Or ask at an older bike shop.
Old fart
Quoted: 3587 Post(s)
Liked 3,398 Times
Quoted: 1324 Post(s)
Liked 927 Times
Yesterday I rode out of town to a guy I know who fixes bikes but doesn't like dropbar bikes because there's not much demad for them out there. I was hoping to get aa lever with that exact pivot on it so I could do a step by step of how I use that protruding bit to mounf dropbar shifters as shown on one of my dropbar MTB conversions.
Can i use your image as a "Before" image?
Cheers
Cheers
