Mechanical Disk Brake Pad Life
Very Senior Member
I have a new E-Bike with 350 miles of rolling hills so far. I never had mechanical disk brakes before so don't know much about them. How long can I expect the pads to last? When should I pull them to check?
It's better to cycle through life than to drive by it.
Quoted: 883 Post(s)
Liked 823 Times
You don't need to "pull them" to check. FME just look at the thickness of the pad material. Some are so easy to remove the pads that you can just pull them and check. Others (BB-7) not so much.
Gone Biking!
Bikes: Orbea Gain, Lynskey, Redline Conquest Disc, Bike Friday, Cannnondale T2 Tandem.
Quoted: 42 Post(s)
Liked 50 Times
I have a set of BB7 pads that have over 13,000 miles on them and still stop just fine. Keep them clean and you will use them for a long time. They are on a "road" bike that has been used as a commuter and touring bike over various terrain .
Quoted: 668 Post(s)
Liked 529 Times
I get pretty good life out of my pads. Where I ride I don't brake much though.
The brakes on my ebike definitely work harder. That might reduce the life a bit, but like said above on all my bikes I can see the pad material without having to remove them.
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,993 Times
For an e-bike probably a lot lower they can eat up pads. I wouldn't buy an e-bike with cable brakes though that is probably a good sign that other components aren't up to snuff. If it is a super lower power e-bike maybe cable brakes might be ok but a lot of the cheaper single piston brakes with tiny pads don't work well.
Quoted: 668 Post(s)
Liked 529 Times
cyclotourist
Quoted: 443 Post(s)
Liked 205 Times
I have mechanical disk brakes on my off pavement touring bike. I find the pads don't last, although the metal oxide pads last longer than the resin pads. Its pretty easy to check if they need replacing if you can see them clearly. I have an ebrake on my ebike, so brake pads dont get much wear.
I have a fat bike and ride very few hills, the pads are still good after about 1,000km
I have a full suspension Ebike I use in the mountains and the pads (resin) last around 10,000 meters of descent
Very Senior Member
Thanks everyone, for your advice.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
It depends a lot on weight, terrain, dirt/grunge, etc. I'd check them at least every year, although after one year you should get an idea of how fast they are wearing. Typically your front brake is going to wear a lot faster, and keep in mind that one of the two pads may be wearing faster than the other, so look at both inner and outer. you should be able to eyeball this without touching anything.
Liked 415 Times
I would hypothesize that it works because
- you don't have cheap or worn out brakes
- while these guys are using rotors less than 200 mm, your rotors are probably closer to 600 mm (give or take)
