Need help programming Bafang displays
Old 11-21-20, 10:59 AM
andychrist
Devil's Advocate
andychrist's Avatar
Bikes: Fuji Del Rey, Bacchetta Giro 20, RANS Stratus XP XL, RANS Stratus XP XXL, RANS Stratus LE XL
Quoted: 77 Post(s)
Liked 50 Times in 38 Posts
Just completed build of dual drive 48V 500W Bafang hub motors and 52V DireWolf batteries, but can’t program the 500C and P850C displays for compatibility. Following the video instructions, try to use the + and - buttons to change values for km/mi, brightness, etc but they only advance/reverse modes and leave the default settings intact. Would like to be able to limit max speed to 12mph/20kph and set nominal voltage to 52, as Luna claims is possible with the C500 (and should be with the P850C as well) so as not to fry anything. Then again, both displays do indicate the current battery voltage (which when the DireWolves are full is around 58) so perhaps that info is used by the controller and no need to enter manually?
Any help much appreciated!
andychrist is offline
Old 11-21-20, 01:11 PM
andychrist
Devil's Advocate
andychrist's Avatar
Quoted: 77 Post(s)
Never mind, figured it out.
Interestingly, there is an option on both displays to select 52V without having to manually enter the digits, even though Bafang’s own Display Comparison chart only lists 24/36/48/60(V).
Other weird thing, on the 500C display, after having chosen Imperial over Metric, selecting Max Speed still showed values in km rather than mi. So simply entered 20, which should translate to 12mph. P850C OTOH displayed max speed in mph.
Whew!
Out later for the first test ride. If I fail to update this thread, you all can imagine what happened.
