Couple mistakes recently (brakes and stem)
Old 09-15-19, 02:51 PM
sirjag
Bikes: Giant Contend SL 1 Disc
Quoted: 128 Post(s)
Liked 64 Times in 44 Posts
Couple things I have learned recently, wanted to share here for some additional learning, and perhaps someone can learn from my mistakes....
1 - had my bike in stand, was replacing my stock 110mm stem with a 120mm stem (trying to get a little more reach) and I had no idea the bottom of the headset would fall to the ground! spacers and ball bearings went everywhere...how embarrassing. I put everything i could find in a bag and took to LBS to get it all back together. I couldn't find anything online with the order of spacers and bearings so I had to take it in unfortunately...They didnt charge me anything, and allowed me to watch and learn when they put it back together! So I can do this work on my own from here on out.
2 - I use some of that silicone based bike cleaner/spray to wipe down the bike each 100miles or so. I always spray on micro fiber rag then wipe the bike down taking care to not get on the brakes (my giant has disc). Well i didnt take as much care as i thought and now my bike sounds like a freight train when stopping and the power is way way reduced. I have taken the pads and calipers off the bike and cleaned with 90% IPA, no effect. Then i soaked in dawn kitchen soap, no effect....What can i try next? Do really need to replace the pads? Can I bake them out in oven? And at what temp should i use??
thanks for reading and any help that yall can offer!
JAG
sirjag is offline
Old 09-15-19, 04:35 PM
Bigbus
Bigbus's Avatar
Bikes: Giant Road Bike & Giant MTB $ Fuji Road Bike
Quoted: 255 Post(s)
Liked 165 Times in 122 Posts
JAG
Some people will suggest a light sanding with 400 grit but I would just throw in a couple of new pads. Preferably organic resin type.
Bigbus is offline
Old 09-15-19, 04:43 PM
delbiker1
Mother Nature's Son
delbiker1's Avatar
Quoted: 433 Post(s)
Liked 410 Times in 250 Posts
Kool stop salmon, orange, brake pads. I started using them last year and will not go back to regular, black, Shimano or other brand name pads. They brake very well, noiselessly.
delbiker1 is offline
Likes For delbiker1:
Old 09-15-19, 04:46 PM
andrewclaus
Bikes: 2016 Fuji Tread
Quoted: 380 Post(s)
Liked 132 Times in 101 Posts
That works for rim brakes, but the OP has disk.
Try the sandpaper, but the pads may be chemically changed and may need to be replaced.
andrewclaus is offline
Old 09-15-19, 04:48 PM
Miele Man
Quoted: 1160 Post(s)
Liked 722 Times in 506 Posts
JAG
2. Try sanding the brake pads a bit.
Clean the rims really well too.
Cheers
Miele Man is offline
Old 09-15-19, 04:49 PM
delbiker1
Mother Nature's Son
delbiker1's Avatar
Quoted: 433 Post(s)
Sorry, and thanks for correcting me. I somehow missed the disc brakes in the parenthesis.
Old 09-15-19, 05:16 PM
sirjag
Quoted: 128 Post(s)
Hey thanks everybody! Ill try the sand paper, then ill get new pads....how can i ensure i have cleaned the rotors adequately?
JAG
sirjag is offline
Old 09-15-19, 05:31 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1197 Post(s)
Liked 380 Times in 290 Posts
Silicone? I'd toss them.
I'd run the rotor through the dishwasher.
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 09-15-19, 05:38 PM
cpach
Bikes: Too many. Cannondale SuperSix, Trek Remedy 8, Trek Crossrip+ get the most ride time.
Quoted: 394 Post(s)
Liked 163 Times in 131 Posts
You can nearly always get rotors clean again. I like to lightly sand them with some fine sandpaper and then wipe down with isopropinol and a CLEAN cloth (preferably a disposable shop cloth). Pads can be cleaned if they're very lightly contaminated--generally sanding is the best course of action. You can try drenching them in alcohol and blasting them with a propane torch also. But they're porous and if they're really contaminated they really just need to be replaced.
cpach is offline
Old 09-15-19, 06:02 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1236 Post(s)
Liked 662 Times in 468 Posts
Silicone is really tough to get rid of, when I worked in an auto paint shop we'd curse the owners who used silicone products because it was so hard to remove, even with sanding. I'd toss the pads then try auto brake cleaner like CRC Brakleen on the rotors, followed by very hot water with Dawn liquid and a hot water rinse.
Edit: We used Prep-Sol prior to painting, it claims to remove silicone (kinda does) but is costly: https://www.merrittsupply.com/produc...3919s-solvent/
dsbrantjr is offline
Likes For dsbrantjr:
Old 09-16-19, 03:35 AM
billyymc
Quoted: 272 Post(s)
Liked 117 Times in 55 Posts
Yep - do this. But caveat that auto brake cleaner should be used with care. I had to do this with a rotor that I accidentally got mineral oil on when changing it in my brakes. I tried cleaning the rotor with all kinds of cleaner, even alcohol as suggested further above. Nothing got it completely clean. So I took the rotor off the wheel, took it outside and put it on some clean cardboard, and used the Brakleen. I didn't want to get it on anything else.
billyymc is offline
Old 09-16-19, 04:20 AM
Newspaper_Nick
Newspaper_Nick's Avatar
Quoted: 130 Post(s)
Liked 74 Times in 45 Posts
Use cotton and brake cleaner fluid or alcohol on rotors. "Cotton" is important. No other material can do what it can do. In order to get rid of the oil on the brake pads, just climb to a hill and exercise the brakes while going down. As the brakes heat up, the heat will burn all the oil at some point. It could take time though.
Newspaper_Nick is offline
Old 09-16-19, 05:22 AM
hokiefyd
hokiefyd's Avatar
Bikes: '18 Redline Zander MTB, '14 Surly Pugsley, '97 Trek MultiTrack 750, '70 Peugeot UO-18 Mixte
Quoted: 1106 Post(s)
Liked 340 Times in 261 Posts
For what it's worth, Kool-Stop do actually sell disc pads. They're not the same "salmon" compound used on rim brake pads, but I'm sure they're high quality disc pads nonetheless.
Kool Stop International - High Performance Bicycle Brake Pads Since 1977
hokiefyd is offline
Old 09-16-19, 06:05 AM
sirjag
Quoted: 128 Post(s)
Thanks again everyone for the info. Much appreciated! -JAG
sirjag is offline
Old 09-16-19, 08:57 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 3821 Post(s)
Liked 1,243 Times in 764 Posts
Just to be a bit pedantic, the pads haven’t changed “chemically”. They haven’t made a new material or compound. They have changed physically. The pad is somewhat porous and any oils that get into the pad are difficult to remove. Efforts to remove the material with a solvent will just push it further into the pad.
But, yes, the pad needs to be replaced and any lubricants need to be kept far, far, far away from the pads (moving them to Pluto might be far enough away)
Stuart Black
cyccommute is online now
Old 09-16-19, 08:59 AM
leob1
Quoted: 267 Post(s)
Liked 58 Times in 37 Posts
New pads, clean the rotors with brake cleaner(do both sides), if your worried about getting brake cleaner on other parts of your bike, remove the wheels and\or rotors.
Chill and drink the IPA.
leob1 is offline
Old 09-16-19, 09:12 AM
cyccommute
cyccommute's Avatar
Again, to be chemically pedantic, drink an IPA if so inclined but not the IPA sirjag is talking about. Both will make you sick if taken in large enough amounts but one is a lot less enjoyable than the other.
Stuart Black
Old 09-16-19, 02:57 PM
ljsense
ljsense's Avatar
Quoted: 213 Post(s)
Liked 90 Times in 50 Posts
Rotors have a bit of the pad material smeared across their surface. That's the only thing that will really hold on to the lubricant. Otherwise, rotors come clean come clean pretty easy -- smooth stainless steel doesn't hold on to much. I'd sand them with fine sandpaper (200-600 range) and then just wipe them off with rubbing alcohol. That will physically remove the silicone from the rotors. Brake cleaner works, but that's pretty aggressive stuff.
If your pads are metallic, you could try heating them. Here you are looking for a chemical change. But silicone resists heat pretty well. Any normal oven won't get hot enough, which is why you can use a silicone mitt to take out your roast chicken. You've got to go over 500 degrees F, with a blowtorch, to break off the organic chain of the compound and leave behind SiO2.
Easier just to replace the pads, like most everyone else said. Then be sure to re-bed your disc brakes by slowing yourself, one brake at a time, from 15 mph to 5 mph or so, about 10 times each wheel.
ljsense is offline
Old 09-16-19, 08:57 PM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 1045 Post(s)
Liked 248 Times in 185 Posts
Car factories have bans on silicon products, and aircraft painting companies won't even let a plane that has silicon on it into the hanger. The stuff is pernicious.
Any porous material coming into contact with silicon materials are done for, unless you want to use extreme measures (2700°F in a pure oxygen atmosphere for for 24 hours followed by a quench of the ashes in supercooled helium - then you throw out the ashes, condemn the furnace, and go buy new pads.)
WizardOfBoz is offline
Old 09-19-19, 06:46 AM
conspiratemus1
Used to be Conspiratemus
Quoted: 268 Post(s)
Liked 218 Times in 145 Posts
Like 'em a lot. I just bend the spoke-side tab so they look more like the Avid OEM pads (and easier to grab to remove, too.)
conspiratemus1 is offline
Old 09-21-19, 02:33 PM
Ronsonic
Quoted: 88 Post(s)
Liked 21 Times in 17 Posts
For rotors I use acetone and green scotchbrite scrubbing pads.
Ronsonic is offline
Old 09-23-19, 10:44 AM
sirjag
Quoted: 128 Post(s)
Wanted to update status of my brake issues everybody!
So they work again! After the IPA and dawn soap cleaning and soak the brakes still made a horrible screeching sound while slowing, and the slowing power was greatly reduced.
As a last effort prior to replacement I found the longest downhill I could find (hit about 33-35mph max for about 1mile) and hit it twice while holding one brake for 5-10 second increments. About ¾’s of the way down the hill the brake I was using (rear first) suddenly just grabbed!
I repeated for the front brake and had same results.
Lesson learned; don’t get oil/silicone/contaminates on the pads or rotors fellas!!
JAG
sirjag is offline
Awaqa909
Bicycle Mechanics
21
12-21-18 03:21 PM
Marx
Bicycle Mechanics
13
02-27-12 09:16 PM
Buggington
Bicycle Mechanics
15
02-03-11 01:05 PM
TimeTravel_0
Bicycle Mechanics
2
06-26-10 01:27 PM
WorldIRC
Bicycle Mechanics
3
04-26-10 04:18 PM
