Chain getting longer? Directional chains?
Just call me Carrie
So yesterday I was at my LBS and ended up talking with the owner for a really long time. He was thrilled that I was interested in his vintage collection. (He head a beautiful Panasonic and I wanted to steal, to be honest.) But one thing he said struck me as odd.
He said that if you clean a chain, it gets longer. Something about grease between the links keeping them at the correct distance and cleaning removing the grease. So if you degrease a chain, it will no longer fit to the cassette and crank and will actually wear out the gears quicker.
So he said not the degrease a chain but if it's crusty, just replace vs. cleaning. Granted, the shop sells parts...Then he said you can put a chain on backwards because it's directional. Am I really clueless or are these things I just didn't know? I'll admit that either might be the case. But neither of these things struck me as true.
Just call me Carrie
EXACTLY!
Is this, "hey, this woman is here and I can tell her anything!"
Because in the past I was told I needed a car part replaced to the tune of $350...and it turned out that a 1984 Mercury Lynx didn't even have that damn part in the first place. *glares*
Likes For P!N20:
Just call me Carrie
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,376 Times
I always tell the guys at Jiffy Lube that my wife changes the air and cabin filters on my car (true). That usually puts an end to the upselling.
Likes For thinktubes:
Just call me Carrie
Probably like why I negotiate all the car loans. I was burned once. And in 2001, I negotiated my husband's (then fiance's) car deal. A month later, I went in to buy another car for me and the manager just waved his hand and said, "Just give her what she wants."
But still, every time we go to buy a car, the salesman talks it up to my husband and ignores me. My husband is not the one they need to impress.
Likes For TriBiker19:
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
I once removed a chain and then immediately reinstalled and it wouldn't shift right at all. Since All I did was remove chain, I flipped it then reinstalled it and presto worked exactly as before with no problems. So it either got worn in a certain direction or it was directional.
Likes For texaspandj:
Quoted: 985 Post(s)
Liked 2,376 Times
I nodded my head and thought, "I'm gonna ask the guys about this one."
She replied: No thanks, this is a "transitional vehicle". I could see the wrench going into the gears inside the poor guys head. His ego wouldn't let him ask what she meant, so after about 20 seconds he replied "OK". Totally stopped him in his tracks.
Just call me Carrie
Yeah, I watched my wife totally own a sales manager after buying a Honda. He was trying to sell her an extended warranty.
When I was in Seattle and didn't want to upgrade to leather seats, I'd tell the salesperson I was vegan and then act offended.
Just call me Carrie
Meanwhile, he admitted that he only had one mechanic between the three stores that would be able to work on a pre-2000 bike.
Quoted: 18352 Post(s)
Liked 4,502 Times
Is this the C&V Subforum?
Perhaps you guys should be excused.
https://si.shimano.com/pdfs/dm/DM-CN0001-05-ENG.pdf
Likes For CliffordK:
The area where the pins roll is where chain "lengthen" with use, but it's because the pins wear, not because lubricant gets forced out.
I mostly don't recommend degreasing chains, but that's because chains with dry lubricants don't get very dirty, and wet lubricants generally do a pretty good job of cleaning themselves (not perfect, but good enough that it won't matter much after ten minutes into the next ride). Stripping a chain on a routine basis just isn't very useful.
You jest, but modern chain designs often are directional. Getting a chain backwards on an 11-speed drivetrain can significantly affect shift quality.
Likes For HTupolev:
Just call me Carrie
I almost would have preferred to be "well actually"ed.
Just call me Carrie
And directional after using the chain for a while makes sense, too, but not that a new chain would be impactfully directional. I would guess that after a while, wear would lead to similar performance in a normal or backwards chain.
Ride, Wrench, Swap, Race
Quoted: 1562 Post(s)
Liked 1,287 Times
The directional thing on certain models of Shimano chain started with 10-speed and has continued to 11 speed.
I have had a bike or two come in with shifting issues that was caused by the 10-speed chain being on backwards.
There was an older version of Shimano 10s chain that was not directional.
If what that shop owner said about not degreasing your chain was true, then there would no doubt be problems from using any of the many chain lubes which contain high concentrations of solvent. But of course no such problems occur!
Liked 4,502 Times
With the new Shimano 11 speed chains, the inner and outer plates are slightly different, and thus not as much directional as inside vs outside (see above).
I haven't thought much about unidirectional wear patterns. Perhaps there would be some slight differences as a chain beds in. Perhaps with respect to the direction of wrap around the sprockets. But, then that would beg the question whether there would be a benefit of wrapping around the sprockets in the opposite direction periodically.
Personally, I like to pin my chains, and install once, ride, then remove when beyond spec.
I have experimented a bit with Wippermann chains that come with a removable quick link (which also has a top/bottom so it only wraps around the sprockets one way).
Quoted: 457 Post(s)
Liked 462 Times
Many years ago a friend with may years of bike wrenching experience told me he removed a nasty old chain from a bike, and cleaned it in degreaser, reinstalled it, and the bike never shifted properly again and it skipped under load. It had a campy groupo on it and the rings and freewheel were worn, to the chain, but now the chain was a different length than it was, and to replace the rings and freewheel with new parts and a new chain was way more money than was going to be spent on this bike, so, cleaning the chain totalled the bike essentially.
I go the other direction, I clean my chains thoroughly and regularly in lacquer thinner from day 1 and they last and last and last as do the rings and cassettes...
Maybe. I'm not sure what all contributes to the directional differences. The visually-obvious directionality on Shimano 11-speed chains is the beveling on the plates, and that won't wear in appreciably with use.
Quoted: 4559 Post(s)
Liked 2,802 Times
Shimano confuses the issue for their 11 speed chains by labeling the inner and outer plates as "front" and "reverse." The chain can be reversed in lengthwise direction and still be correctly oriented with the outer plate facing outward. It would just present a fresh set of unworn rollers contacting the gear teeth. If flopped regularly, say once a month for cleaning and oiling, it should wear evenly.
With KMC chains 8-speed and below I never pay any attention to chain orientation after cleaning and lubing. Never noticed any problems.
Lube between friction/bearing surfaces would be measurable but probably insignificant for a bike. I've ridden chains that were noticeably "stretched" from bearing surface wear and still worked fine. I usually get at least a year and usually more, several thousand miles, before replacing them even though the chains still ran and shifted okay.
My waxed chains seem to last longer, presumably because it doesn't develop an abrasive paste like oil. But wax is more labor intensive and usually needs to be redone every week or two. I still use Park CL-1 oil on one of my hybrids and it'll go as long as a year on a single treatment -- CL-1 is water resistant, while wax tends to need to be redone after a wet weather ride.
Liked 1,287 Times
Shimano confuses the issue for their 11 speed chains by labeling the inner and outer plates as "front" and "reverse." The chain can be reversed in lengthwise direction and still be correctly oriented with the outer plate facing outward. It would just present a fresh set of unworn rollers contacting the gear teeth...
I'm thinking that since the rollers rotate, there won't be any worn vs. un-worn surfaces.
And, as the front and rear sprockets each force the rollers in roughly opposite directions, reversing the direction of the chain might have next to no effect.
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 977 Post(s)
Liked 626 Times
Interesting, but maybe the manufacturers should stamp the side plates with directional arrows. You know, like some plumbing parts and furnace filters.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 4722 Post(s)
Liked 3,036 Times
Also, while the rollers can rotate, leading to more even wear, the other wear surfaces are the bushes/flanges on the inner plates and these only pivot though a limited range as the chain wraps around a cog. This, in conjunction with the higher loads at the rear, results in bush/flange wear that is predominantly on one side. Once the flanges wear enough, the pin will start to wear, again predominantly on one side. Attached are pictures showing (extreme) bush/flange and pin wear and how it occurs predominantly on one side. Consequently, periodic reversal of chain direction can extend chain life.
