Long spokes
Old 05-23-10, 01:48 PM
neil
Long spokes
I'm just working on my first wheel build, and it appears that I completely messed up the spoke calculator when I ordered the parts. It looks like be the time I tension everything up, the spokes will be sticking several mm past their nipples on the inside.
Now, it's a double walled rim, so everything is recessed...I'm thinking that once I put in the rim tape, nothing will be in contact with these overlong spokes. Is this a reasonable assumption? Can I keep building the wheel, or should I pull all the spokes out and order shorter ones?
I don't really want to take it apart, but it's for my winter bike, so I've lost of time to get it finished if I really have to.
neil is offline
Old 05-23-10, 01:57 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1262 Post(s)
Liked 113 Times in 78 Posts
I'd take the wheel apart and get the right length spokes. While there's a possibility that you might get it to work, since you're talking about "several millimeters" almost surely the nipples are going to run out of threads and bottom out and you won't be able to get the wheel tensioned and trued.
As a general rule when you discover a screw up, the sooner you turn around the better.
Retro Grouch is offline
Old 05-23-10, 02:02 PM
Al1943
I agree.
But before you order new spokes make sure the spokes are laced correctly with the correct number of crossings. If 3 cross the first crossing is really close to the hub.
Al1943 is offline
Old 05-23-10, 02:06 PM
neil
Thanks. Not what I wanted to hear, but probably the right approach.
The lacing is definitely correct. I've done enough spoke replacements to be familiar with the crossing pattern for a typical 3-cross, and that's what I've built. Plus I was being really anal about getting the lacing right.
neil is offline
Old 05-23-10, 03:46 PM
wmodavis
Bill
Bikes: Specialized Globe Sport, Specialized Stumpjumper FSR Pro
Priorities are in order when being anal. Before becoming anal over lacing, you should be anal over getting the spoke length correct for the rim and hub your using. I believe the best way to do that is an anal do-it-yourself measuring of the pertinent hub and rim. Then anally repeat the exercise and check the results in several spoke calculators including comparing your hub and rim measurements with multiple databases. Once you believe your chosen spoke length is appropriate proceed to the next most appropriate anal focus.
wmodavis is offline
AEO
AEO's Avatar
Bikes: Bianchi, Miyata, Dahon, Rossin
you can twist the spokes into each other to effectively shorten the length.
PITA to replace broken spokes, but wheels with spokes bent around each other are stronger than conventional wheels.
something like this
http://www.instructables.com/id/Twis...ng---flowers!/
if the wheel allows it, you can also go to a 4 cross. But these would be on 36h or 40h 700c wheels.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
http://sanfrancisco.ibtimes.com/arti...ger-photos.htm
AEO is offline
Old 05-23-10, 04:31 PM
mrrabbit
mrrabbit's Avatar
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 72 Post(s)
Liked 5 Times in 4 Posts
Maybe you'll like adding my executable and spreadsheet calc tools to your calculation checklist:
http://www.mrrabbit.net/wheelsbyflemingapplications.php
=8-)
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
mrrabbit is offline
Old 05-23-10, 05:04 PM
DannoXYZ
DannoXYZ's Avatar
Quoted: 105 Post(s)
That's what I always do as well. There are A LOT of measurement errors in the various hub & wheel databases out there. Even with the major manufacturers like DT & Wheelsmith. Best way is to measure all the dimensions yourself and plug actual values into the spoke-calculators rather than relying on their built-in tables.
DannoXYZ is offline
Old 05-23-10, 05:47 PM
nymtber
Bikes: See Signature...
Quoted: 9 Post(s)
You can get a cheap digital or dial caliper for around $20 and you could have taken correct measurements, and had the right #'s from the get go.
Although...I have the calipers because of Cartridge reloading, they sure come in handy for wheel building, too!
Get the right spokes, and try again. It will be worth it in the end!
nymtber is offline
Old 05-23-10, 05:54 PM
reptilezs
Quoted: 9 Post(s)
see if you can lace it 4x
reptilezs is offline
Old 05-23-10, 06:04 PM
FBinNY
Quoted: 4355 Post(s)
Liked 6 Times in 6 Posts
I can't answer because I don't know how far off you are, not how far the spokes can stick up before running out of thread. Before you throw up your hands in disgust and take it apart, thread one nipple down a spoke and find out how far your spokes can potrude, and compare it to your expected build. I'd say you want a safety margin of at least 1mm, but if it looks close, you have a decision to make, whether to gamble your time in completing the wheel, or start fresh.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FBinNY is offline
Old 05-23-10, 06:11 PM
DannoXYZ
DannoXYZ's Avatar
Quoted: 105 Post(s)
No way, the difference in spoke-length between 3x and 4x is usually about 11-12mm. And his hub-flange might be too big to support 4x.
DannoXYZ is offline
blaksh33p57
Bicycle Mechanics
32
12-03-13 09:59 AM
hybridbkrdr
Bicycle Mechanics
1
05-04-13 03:50 PM
Andy_K
Bicycle Mechanics
11
11-29-10 09:15 AM
rousseau
Bicycle Mechanics
22
10-08-10 07:17 PM
lechatmort
Bicycle Mechanics
23
06-23-10 09:48 AM
