Shimano M416 Squeaking
Bikes: Nishiki Bushwhacker
Hi, i accidentally lubricated disc brakes because i wanted to remove rust from bolts on brake caliper and brakes started to squeak.
Then i tried to clean rotor and pads with alcohol, i cleaned it and emeried pads with emery sponge. Brakes still were squeaking
Today i bought Motul Brake Cleaner and used it on everything: rotor, pads, caliper. At the beggining i heard no squeaking, but after minute of riding it started again even worse.
What i should do now? I am tired and nervous, spend money and nothing helps.
Quoted: 453 Post(s)
Liked 104 Times
Sounds like you have contaminated your pads. The rotors should be ok if you have used the cleaner on them, for the pads, it's normally cheaper to replace rather than attempt to revive them.
Thanks, i will buy new pads from ebay i think because in Lithuania they are more expensive
Quoted: 453 Post(s)
Liked 104 Times
If you need cheap pads, look here https://superstar.tibolts.co.uk/shipping.php no connection, just a happy user
Too expensive. I found cheaper long life, KW brand from Australia but i can wait https://www.ebay.com/itm/SINTERED-DIS...item4aae75b661 . I converted the price to litai and from your recommended shop it costs 38Lt , from ebay 31Lt. How long they are shipping?
