Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Track Tire Questions
Old 08-31-18, 06:38 AM
  #326
topflightpro
topflightpro's Avatar
Quoted: 1851 Post(s)
Liked 678 Times in 429 Posts
Originally Posted by rensho3
LOL-I can't figure out how to multiquote, so this for Baby Puke too.
There are three buttons in the lower right corner. The middle one with what looks like two sheets of paper and a plus sign is the multi-quote option. Click it in the first posts you want to quote, then click Quote in the last post you want to quote. All the quotes should be there.
topflightpro is offline
Old 08-31-18, 03:57 PM
  #327
gl98115
Quoted: 141 Post(s)
Originally Posted by Morelock
Shade. That's what the kids are throwing these days.
I had to look that one up:
https://www.merriam-webster.com/words-at-play/shade
gl98115 is offline
Old 09-01-18, 06:58 AM
  #328
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Liked 50 Times in 37 Posts
see, I'm hip.
Morelock is offline
Old 09-02-18, 02:11 AM
  #329
Dalai
Quoted: 89 Post(s)
Liked 8 Times in 6 Posts
see, I'm hip.
Unfortunately immediately revoked for using the word hip...
Dalai is offline
Old 09-02-18, 05:34 PM
  #330
Baby Puke
Bikes: Marin Stelvio, Pogliaghi SL, Panasonic NJS, Dolan DF4, Intense Pro24 BMX
Quoted: 365 Post(s)
Liked 87 Times in 58 Posts
A Mavic iO (old version) has fallen into my lap, basically. I've heard these prefer a 19mm tire, but I have a 22mm on hand. How important is the 19mm?
Baby Puke is offline
Old 09-02-18, 06:20 PM
  #331
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
Go with 19. 22mm will mushroom over the sides. The rim bed is made for 19mm.
I did this very thing. When I got my Io, I had a 22mm Conti Steher tire and had it installed. Nope. I then swapped it for 19mm Veloflex Record. Was perfect.
That tire also lasted until I sold the wheel a couple of years later. Big fan of Veloflex Record.
carleton is offline
Old 09-02-18, 07:40 PM
  #332
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
^ +1
The old rims like the iO and trispoke's aerodynamics are VERY dependent on the tyre and how it mates with the rim. Running a wider tyre on them is very, very bad aerodynamically.
Morelock is offline
Old 09-02-18, 08:41 PM
  #333
Baby Puke
Quoted: 365 Post(s)
Thanks guys. Dang it. Spouse won't be thrilled to spend MORE money on this "sweet deal" haha...
Old 09-03-18, 03:13 AM
  #334
Baby Puke
Quoted: 365 Post(s)
Tangentially related to track tire questions:
This iO wheel just showed up (it's very sexy) and the (dead) tire was affixed with tubular tape. I know some people use this, but I've never seen it close up before.
PUBLIC SERVICE ANNOUNCEMENT: Please do not use tape to mount your tires. The previous owner used two layers of tape, which were stuck to each other pretty darn well. Unfortunately, the tape was not stuck well at all to either the base tape or the rim bed. It was frighteningly easy to remove this tire. The tire in question was Vittoria Pista EVO and I have never successfully removed one of these from my own wheels (I use Mastik 1) without destroying the base tape. The base tape on this tire looked factory fresh. Scary.
Old 09-03-18, 05:05 PM
  #335
tobukog
Quoted: 117 Post(s)
Liked 23 Times in 14 Posts
1) Time to renegotiate with the wife for your monthly (okozukai) allowance. Araya disc + Mavic Io in exchange for not staggering home from a hostess bar on a nightly basis.
2) In all seriousness, it's pretty crazy that people use tubular tape, even if they use the "Belgian method". Mastik 1 yay!
3) A 22mm tubular isn't bad aerodynamically if you use it on the back wheel -- the 105% rule doesn't really apply when it's sheltered by the seat tube -- so it'll be useful at some point.
tobukog is offline
Old 09-03-18, 05:37 PM
  #336
carleton
Elitist
carleton's Avatar
The older fat spoke Io looks best. The newer thin spokes look like Aerospoke wheels.
I honestly believe that there is absolutely no functional difference between the two. Companies do this from time to time to mix it up and have people buy new stuff. For example, how much faster can the modern LOOK 496 be when compared to the original 496 “Athenes” which are still being ridden today.
BT was cool about sticking with designs that worked for years and not changing to increase sales.
The rim bed of the mating Comete is much wider and designed for 22/23mm tires.
You are also right about the seat tube. Of all the aero equipment options, it’s either the rear wheel or the frame that is at the bottom of the list of gains.
carleton is offline
Old 09-04-18, 05:01 AM
  #337
Baby Puke
Quoted: 365 Post(s)
I keep telling her this. It's not working.
Old 09-04-18, 07:03 AM
  #338
topflightpro
My wife rides and races. And early in her life, she was a bit more of a profligate spender. As a result, she never questions any of my cycling purchases, and often encourages them - which is not good. I don't need encouragement - our budget can't handle it.
Old 09-04-18, 08:07 AM
  #339
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
I think the main purpose of the iO RIO was to allow the use of wider tyres without the aero penalty. It would gain you some nonzero bit of crr as well. That said... the old "narrow is aero" matters with the leading tyre... so it's possibly a wash between the two (as the 19mm Vitt is a fast tyre to begin with) especially in the low yaw scenario you'd expect the velodrome to be. Still, wider tyre has a few other benefits when you're looking for every last thousandth of a second.
Fwiw, Josh Poertner found the 5 spokes to be slower than 808's... but, basically they didn't look as cool and so riders didn't like (or ride) them.
Morelock is offline
Old 09-04-18, 12:27 PM
  #340
carleton
Elitist
carleton's Avatar
Having owned the older IO (like Baby Puke) and 2 sets of 808 track (early model and Firecrest), my anecdotal testing revealed no measurable difference between the two...except in my bank account
carleton is offline
Old 09-04-18, 12:34 PM
  #341
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
@carleton
Even more reason to look cool
Morelock is offline
Old 09-04-18, 04:38 PM
  #342
Baby Puke
Quoted: 365 Post(s)
This thing was a screaming deal, much less than you'd expect to pay even for a used 808. I couldn't say no!
Old 09-04-18, 07:32 PM
  #343
Baby Puke
Quoted: 365 Post(s)
I haven't seen one of the new iO's in person, but I'm guessing that in addition to the wider rim they must have gone to a U-shaped rim profile (ala Zipp), and would guess that the thinner spokes are to reduce the pulse turbulence that testers have found with carbon spoked wheels. The Mavic materials claim a 20 watt improvement over the old wheel, but that's a bit vague without the context of the test.
But I agree, the older wheel is better looking.
Old 09-04-18, 10:42 PM
  #344
carleton
Elitist
carleton's Avatar
But I agree, the older wheel is better looking.[/left]
I'm glad you got a smoking deal. I paid A LOT for my Io/Comete set.
Mavic won't publish the test results.
This has got to be their singular most expensive wheel at $4,000 USD (front wheel only). Also note that they don't make a version of this wheel available for road TT use. They only offer a 64mm wheel (front or front+rear combo). The wheelSET is $2,100USD.
I've seen and handled a new Io in person. The fit and finish are nice as expected...still reminded me of an Aerospoke
carleton is offline
Old 09-04-18, 10:52 PM
  #345
Baby Puke
Quoted: 365 Post(s)
Ouch.
Old 09-05-18, 03:56 AM
  #346
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
In a dystopian future, hipsters will do skids on Mavic iO Rio's.
Morelock is offline
Old 09-05-18, 03:07 PM
  #347
carleton
Elitist
carleton's Avatar
We are already there.
It gets worse...much worse...
carleton is offline
Old 09-05-18, 05:08 PM
  #348
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
interesting
Morelock is offline
Old 09-05-18, 09:23 PM
  #349
Baby Puke
Quoted: 365 Post(s)
Trust fund, obviously.
Old 09-06-18, 08:30 AM
  #350
Kaben
Kaben's Avatar
Quoted: 62 Post(s)
That image just makes me weep.
Instagram profile says he is an ex track pro, so i guess theres at least some reason for him to have that equipment.
Kaben is offline
