Got a (JP) Routens
Quoted: 1136 Post(s)
Liked 650 Times
Got a (JP) Routens
I received this fillet-brazed Jean Paul Routens a couple days ago and spent some time tonight disassembling and cleaning the frame.
It definitely looks like an early or mid 1980s model, so built by JPR and not his father Jo. The tubing transfer says 531ST, which was introduced in around 1980, and the brakes that came with the bike are the uncommon MAFAC GT with the quick release lever, which were also introduced around that time period. Father and son Routens used a variety of styles of decal over the years - this blocky gold one I have seen on bikes from the 70s and 80s.
This one is built for light touring, with 3 sets of rear mounts and mid-fork eyelets. Some nice features are the brazed-on centerpull mounts, the threaded mounting hole under the fork crown for a fender, and internal routing for the rear brake cable and for dynamo light wiring. Unfortunately the original custom racks and decaleur are gone. I will clean up some of the other components and post more pictures as I rebuild it, and I'll also build new racks for it. I've been talking to @gugie's favorite bagmaker Waxwing about making some bags for it down the line.
Likes For TenGrainBread:
Liked 650 Times
As far as what the original racks would have looked like - I found this picture of a very similar bike JPR made from the same time period. I love the rear rack - it keeps the bags low to the ground and away from the heels, and also serves as the fender mounting point. Notice the taillight mounted to it as well.
Quoted: 964 Post(s)
Liked 1,451 Times
That is a very nice thing!! I'm excited to see the rack build.
How does the dynamo wire go? Exits at the BB for an under-BB style generator?
Quoted: 834 Post(s)
Liked 2,125 Times
That's fantastic! I'm smitten. Looking forward to seeing what you do with it. Do you have the matching rear MAFAC GT caliper? Will this require a seat binder mounted hanger for the rear brake?
Quoted: 2588 Post(s)
Liked 4,824 Times
This is the kind of French stuff that lights my fire
Awesome pick up - and you're right, the lowrider rear racks look cool and complement the front well. I wonder if a certain somebody on this forum could duplicate them for you - or do you mean you'll build them yourself?
This will be a build to watch.
DD
DD
Likes For Drillium Dude:
Liked 650 Times
@gaucho777 Yes it came with the rear GT caliper. It was fully built as received but I'll be changing the cockpit.
@Drillium Dude I'll be building the racks myself from stainless tubing. I'm a welder by trade.
Randomhead
Liked 3,696 Times
I'm curious what went to the upper bosses on the seat stays and the lower bosses on the forks.
I'm curious if you have any ideas for the BB dynamo control lever boss. My Koga Miyata Randonneur has one too, and I'm definitely not using the old BB dynamo.
I've considered modifying a shifter to use for switching hub dynamo powered lights on and off.
Liked 650 Times
One idea that I had if you're not using a BB dynamo is getting a top pull mountain bike derailleur from the early 90s (Deore XT or XTR) and shifting it using that lever boss. Could be a cool experiment!
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
subscribing!
Dave’s fantastic to work with. You’ll love his bags.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
Whoa.
Sweet.
Sweet.
Commence to jigglin’ huh?!?!
Can't wait to see this. Nice that you have a model for the racks. That is an incredible example of a French camping bike from a period not often seen.
BB generators were the thing then. Theoretically, it's still the best. No drag when you don't need it, and they work with light tires, even sew ups.
aged to perfection
Quoted: 837 Post(s)
Liked 1,256 Times
that's a very special bike !
Corey Thompson can probably build you racks from the picture. He'd probably want the bike for a week or so for final fitting.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,391 Times
Liked 650 Times
Simplex controls.
I polished up the 26.6 JPR seatpost. It's a one bolt post unlike the more iconic 2 bolt JPR posts. Unfortunately it's going to be slightly too short for me so I will sell it.
Liked 4,391 Times
