Where do I find replacement chainrings for this bike?
Bikes: Riv Atlantis, Specialized Hardrock, old lugged bikes
I have a Novara Randonee 2006
and need new chainrings but am not sure where to find ones that work. The REI page says that this bike has Shimano Deore 26/36/48, the crank says Hollowtech and "Mega9".
Here is the crank and chainrings. I feel like I can replace these if I can just locate ones that will work, but my google-fu is only coming up with complete cranksets (I did have the bb replaced a while back so I don't think I need a new one).
Thanks for any help finding these parts!
Cheers
Dukester
Cheers
Dukester
I have a two ring setup on my Specialized Crosstrail Hybrid and it was a long road to finding the chain rings that could be used to replace them. The small chain ring turned out not to bad and I found one with the correct teeth and BCD from SRAM. BCD is a part of your quest and here is a link on that:
https://www.wolftoothcomponents.com/...e-diameter-bcd
And you have to decide on a steel ring or aluminum. I had a steel small ring and aluminum large ring. I was only able to find an aluminum small ring.
For the large chain ring, it was very tough to find one that maintained my chain line. Another factor in all of this when you put the chain rings back on. The large chain ring also had a set of ramps and pins for shifting and I wanted to have that also. Many large chain rings did not have that. In the end I found one from Shimano, but I had ordered two that did not work out. I even enlisted my local LBS that sold me the bicycle and there reply was replace the whole crank. They even recommended changing the bottom bracket from a taper to something newer. Now that I have done it, I probably should have replaced the crank and bottom bracket like the LDS recommended. Currently it all shifts fine, but the chain line is slightly off and when I turn the crank backwards on the smallest cog in the rear, the chain shifts up and jams the derailleur. Or when I installed the crank I over tighten the crank bolt and moved the chain line in slightly. A taper bottom bracket is finicky in my opinion. I also emailed Specialized to see if they could point me to a supplier and they responded, we do not do that. Chain rings are one of the mysteries of bicycle maintenance that has no standard or reason. Every other part on a bicycle is usually easy to find.
Likes For themp:
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Hollowtech and Mega are Shimano trademarks. There is a Mega-9 drive train. There is also a Mega-9 Lite. I think that they're different. Yours looks like a "Lite". If so other Mega-9 Lite components should work. If you can't get chainrings for that crank, you should be able to find a very similar hollowtech crank.
Try: https://bike.shimano.com/en-EU/produ.../FC-M4050.html
Likes For WizardOfBoz:
Liked 341 Times
Also check out: https://www.amazon.com/SHIMANO-FC-M5...-goods&sr=1-26
Quoted: 1438 Post(s)
Liked 1,092 Times
Quoted: 714 Post(s)
Liked 800 Times
I agree that its more economical to source a new crankset, but if you want new chainrings, they should be 64/104 BCD 4 arm chainrings. The small chainring will be a 64mm BCD(bolt circle diameter) and the large and middle rings will be 104mm BCD. In theory, any 4 arm 64/104 chainrings should work(as long as they are all from the same Mfg.), but this link is to some Shimano ones. https://www.universalcycles.com/shop...8&category=648
