77 Centurion Super Elite Original wheel size?
Old 07-18-18, 10:30 AM
J.S.
I have a frame in need of rims and would like to confirm if the originals would have been 27". I found a reference for 1978 Centurions that would suggest original rims were likely Araya 27" alloys with sunshine hubs and a 5 speed cassette (Suntour) with gears somewhere between 13 and 30 using Suntour Cyclone Derailleurs'. I'm thinking about trying to put it back to original specs but I am open to any suggestions/opinions. I really don't know what I'm doing I just took a notion to get an old road bike that would actually fit me and came across this frame. I have a few old road bikes I've picked up over the years all of which are to tall for me and I still have what's left of my old volkscycle (basket case)from back in the 80's. I am wanting to get back into riding again and am hoping this Centurion will do the trick. Thanks for any help your willing to give.
J.S. is offline
Old 07-18-18, 11:14 AM
Aubergine
Bad example
Quoted: 825 Post(s)
Liked 209 Times in 96 Posts
Yes, the rims would have been 27” Arayas.
What parts do do you need to finish the bike? Do you want to restore it to an original state or are you open to “restomodding” it with more modern bits? If so, consider whether you can change to the modern 700c rim size. It is a smidge smaller (4mm less radius) but you would have a much wider choice of rims and tires than you will with 27” rims.
Aubergine is offline
Old 07-18-18, 11:06 PM
J.S.
Hi Aubergine and thanks. The bike needs a wheelset, pedals, and chain. It's all there otherwise but could stand being taken down and cleaned and reassembled. I would like to put it back to original specs and restore it to as good a condition as I'm able. I am however not entirely against the idea of making changes if it would make sense and improve the bike and get it back on the road sooner. I've read that 700c conversions are popular but that the brake calipers sometimes must be changed to accommodate the smaller rim. It currently has Dia-comp-G sidepull calipers and I think their probably original. I don't know if their good calipers and worth keeping on the bike though. would I need to find and use a Suntour gear cassette to use the Suntour deraileur's and would I need to find a specific hub width or are they standardized?.....Thanks again.
J.S. is offline
Old 07-19-18, 09:44 AM
Bad Lag
Bikes: 1974 Bob Jackson - Nuovo Record, Brooks Pro, Clips & Straps
Quoted: 1104 Post(s)
Liked 794 Times in 452 Posts
If your brakes allow you to lower the pads down that extra little bit, get 700C wheels
If your brakes do not allow you to lower the pads that extra little bit, get 700C wheels and some new calipers.
Bad Lag is offline
Old 07-19-18, 11:22 AM
Aubergine
Bad example
Quoted: 825 Post(s)
I have used the G model sidepulls and they are adequate but far from great. Replacing those with a better, more modern brake would be a good idea *and* would make it easy for you to switch to modern 700c rims.
As for the “cassette”, your bike would have used a freewheel. The difference is that a freewheel screws on to the rear hub, and the mechanism that allows the rear cogs to spin freely is in the freewheel itself. In the newer design, the freewheeling mechanism is in the hub (called a freehub) and the cogs (the cassette) slide on to splines on the hub. Lots of things to learn, eh? :-) As for brands, you do not need to get an old Suntour freewheel. There are plenty of modern replacements available.
As for the hub width, the standards have changed over the years. The old standard used to be 120 mm, which was enough space for a five-speed freewheel. Then came 126 mm, which accepted six or seven speeds. Then 130 (7-8-9-10 cassettes, not freewheels) and 135. Your bike may have either a 120 or 126 spacing. You should measure the distance between the rear dropouts to determine which it is.
Another option to consider. If the distance between your dropouts is only 120mm, you can widen the rear triangle to 126 so you can get an extra gear or two in there. If you live in a hilly area, a wider spread of gears can be a big help.
Old 07-19-18, 11:48 AM
DiegoFrogs
DiegoFrogs's Avatar
Bikes: '77 Centurion "Pro Tour"; '67 Carlton "The Flyer"; 1984 Ross MTB (stored at parents' house)
Quoted: 169 Post(s)
Liked 93 Times in 61 Posts
I love Centurions of this era. I have a 1977 Pro Tour that I have changed a bit in the 8 years that I have owned it.
I wouldn't go out of my way to get 27" wheels. There's nothing wrong with them if you have them already, but if you're getting new wheels, there's no solid mechanical reason to go with 27" and a lot of practical advantages to 700c these days. I'd be very surprised if the Dia Compe brakes didn't reach easily down to the rims on 700c wheels. I've done this on several other bikes for various reasons, keeping the original brakes, and it's never been a problem. The most difficult cases involve ones where there are cantilever brakes on older bikes, but you don't have that problem.
In the short term, you can use whatever pedals you would like. My Pro Tour came with 'Mikashima Unique Road' pedals, which responded well to some intense cleaning. Today, the brand still exists, and goes by 'MKS'. I do many of my miles on MKS pedals that I bought 14 years ago with a couple cleanings that are a bit nicer for riding with soft sneakers with clips and straps, and a surprising number of miles on a couple sets of modern $10 Wellgo BMX platform pedals.
An affordable KMC or SRAM 8-speed chain will work well with everything.
Keep in mind that if you go with old wheel technology, the technical term for the rear sprocket assembly is 'freewheel', which is incompatible with the more modern 'cassette' style. They have to mate properly with the style of hub, which use the same nomenclature. Yours would have used a freewheel, probably a 5-speed, Your bike is likely spaced at 120 mm on the inside of the dropouts. Normally the over-locknut-dimension (OLD) of the wheel should match this number, but people sometimes slip in a wider wheel. Standards advanced as the number of rear cogs increased, to 126, 130 and 135 mm. 130 and 135 are common nowadays. It's possible to 'cold set' the rear of the frame to accept wider wheels, but maybe start with the easy stuff first. I cold set my rear from 120 to 135 mm on my Centurion.
Your shifting is friction, so you aren't married to any particular brand, which can be nice. Suntour is fine, but I actually recommend a modern freewheel (or cassette, if you go that direction). The Shimano and similar stuff usually shifts really nice. I've been using Sunrace cassettes now for some time and I'm happy with them, so maybe a 6 or 7 speed freewheel from them could work for you.
DiegoFrogs is offline
Old 07-19-18, 12:19 PM
fleslider
fleslider's Avatar
Quoted: 477 Post(s)
Liked 179 Times in 91 Posts
I agree, i would do a modern take on the frame , except for trying to find all of the original parts. the Super Elite is a nice bike but not rare, so i wouldnt worry about making catalog correct, i would make it a rider.
I am currently working on doing that right now with a 1977 Pro Tour.
fleslider is offline
Old 07-21-18, 09:33 PM
Lascauxcaveman
Lascauxcaveman's Avatar
Quoted: 1627 Post(s)
Liked 630 Times in 356 Posts
Conversely, @J.S., if you find a nice pair of 27" wheels for free or cheap, that works pretty well, too. No new calipers needed. (And again, your old brakes may well work with 700c, too. If any of your old road bikes have 700c, swap them in for a test fit)
It's true there are a lot more tire choices with 700c, but there are plenty of good ones with 27", too.
Lascauxcaveman is offline
mmcc73
Classic & Vintage
26
07-16-19 06:46 PM
diekaiser
Classic & Vintage
16
02-13-15 08:04 PM
Bob_OB
7
07-24-12 07:13 AM
rbpanaligan
Classic & Vintage
12
03-15-11 10:15 AM
Elduchey
Classic & Vintage
15
02-01-10 09:13 PM
