MTB levers VS BMX levers... which ones?
Old 07-14-19, 12:37 PM
washer62
Bikes: 2012 Diamondback response XE MTB 1983 Ross SS CB Cruiser +some more
Quoted: 12 Post(s)
Hey guys, I am replacing both brake levers on a friends bike. I found some inexpensive levers on ebay. The BMX levers are much cheaper, which is preferred. I have read that BMX levers differ from mountain levers. Some one called it "cable head". What is "cable head" and how can I tell the difference (BMX vs. Mountain)? Can I measure the existing cable end? What dimension is important? Does it even matter?
Thanks in advance.
washer62 is offline
Old 07-14-19, 03:52 PM
mihlbach
mihlbach's Avatar
Quoted: 114 Post(s)
Liked 125 Times in 67 Posts
It matters not that the levers are BMX or mountain levers. What does matter is that the brake lever have the same cable pull ratio as the brake. What kind of brakes are on the bike? That will determine what kind of lever will work properly.
mihlbach is offline
Old 07-14-19, 04:24 PM
washer62
Quoted: 12 Post(s)
Cool, I was hoping someone would say that. The front brake is a "U" shaped caliper and the rear are V brakes. Short pull fronts, long pull rears. Tektro 316AG's have both cable end locations in them. Short pull hole for the fronts and a long pull spot for the rears. Probably gonna go with them. Thanks for the info.
washer62 is offline
Old 07-15-19, 11:00 AM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 649 Post(s)
Liked 292 Times in 215 Posts
Correct. BMX and MTB use the same brake cables, unless you have a freestyle bike with a 'detangler' (gyro) on the rear brake.
Wilfred Laurier is offline
Old 07-17-19, 03:46 PM
washer62
Quoted: 12 Post(s)
So I went to a LBS and the Tech showed me how BMX cables differ from Mountian cables. The cable head is indeed different. Glad I went, almost bought the wrong levers.
washer62 is offline
Old 07-17-19, 04:15 PM
Charliekeet
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times in 142 Posts
So don't leave us in suspense: what’s the difference?
Charliekeet is offline
Likes For Charliekeet:
Old 07-17-19, 06:59 PM
devianb
devianb's Avatar
Bikes: 2008 Dawes Haymaker 20XX Leader LD515 TotoCycling Road Bike
Quoted: 27 Post(s)
Liked 32 Times in 19 Posts
Correct me if I am wrong, but aren't most levers used for BMX short-pull and MTB long-pull for V-Brakes?
devianb is offline
Old 07-18-19, 12:08 AM
Geekage
Quoted: 41 Post(s)
Liked 28 Times in 21 Posts
I'm pretty sure there's nothing preventing your bike from working with the cables that fit BMX levers. Besides cable pull or hydraulics.
I don't know the difference between cable heads myself, but there are "universal" brake cables.
Geekage is offline
Old 07-18-19, 08:52 AM
Wilfred Laurier
Señor Member
Quoted: 649 Post(s)
This does not agree with my experience. There are two main types of brake cables - MTB/BMX and road. MTB and BMX both have the head as a barrel mounted transversely on the end of the cable. Road brake cables have a differently shaped head mounted parallel to the cable. There are other minor differences between some road cables - I think Campy and Shimano use slightly different shapes. There used to be two types of MTB cables - the regular type we use now and an oversized one sold by Shimano for a few years in the early '90s, but since the mid 90s, every MTB and BMX brake lever uses the same transverse mounted head on the brake cable.
Old 07-18-19, 08:58 AM
Wilfred Laurier
Señor Member
Quoted: 649 Post(s)
'Universal' brake cables have a different type of cable end on each end of the cable... the one you don't want is cut off before installation. One end is for road bike 'drop bar' levers, and the other end has the transverse mounted barrel used for both MTB and BMX. I suspect OP has gotten some bad information or misunderstood what the LBS guy said.
michaelm101
Mountain Biking
21
02-24-19 09:48 PM
MrLucky
Bicycle Mechanics
3
09-13-13 07:07 AM
JonathanGennick
BMX
5
05-24-11 04:18 AM
GMM
Bicycle Mechanics
10
03-29-11 09:33 AM
pierce
Bicycle Mechanics
9
07-29-10 10:54 PM
