WTB: 48-50cm touring/sports touring bike
Quoted: 1136 Post(s)
Liked 650 Times
A friend wants me to build a bike up for her. 48-50cm seat tube, mounts for racks/fenders, 700C preferred. Outside of that, we are very open. Willing to do complete or frameset.
Show me what you got.
Quoted: 1372 Post(s)
Liked 1,751 Times
Just got this Cannondale a short while ago. Full Shimano 600. Looking for a new home right now - $150.00...
I have a 48cm c-t Nishiki Cresta GT frame and fork with pretty much everything but the wheels included, does have a ding in the TT.......$100
Also a 49cm c-t Schwinn Tempo complete as found and in pretty nice shape.....$150
I'm about an hour SW of Chicago and would prefer not to ship
Todd
Todd
Be where your feet are.......Lisa Bluder
Liked 650 Times
Todd
Todd
Couple things.............pretty sure the Nishiki is 27" wheels
Forgot about the 50cm c-t Bianchi Volpe...........as shown $150
Quoted: 964 Post(s)
Liked 1,451 Times
FYI I did a 700c conversion on a Nishiki Cresta GT in that exact color scheme with those exact components (so likely same year) and it was all fine. Have used original DiaCompe shorties, but later upgraded to Shimano SLR MT62 brakes in front and Suntour Scott Pedersen SE brakes in back, with good success. A319 rims were used in the conversion. Good fender clearance for up to 700x42 rear (Compass Snoqualmie Pass), front has 700x38 (Compass Barlow Pass) and is a little bit tight but manageable, with VO aluminum fenders.
Liked 650 Times
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 428 Times
GUNNAR Crosshairs 51cm
https://www.bikeforums.net/sale/1177...eset-51cm.html
....if you aint found nothin' else yet.
thanks.
thanks.
Quoted: 964 Post(s)
Liked 1,451 Times
Forgot to mention, the fenders I used are VO Zeppelins. They do require some crimping to get through the fork crown and chainstays, but there's about 2mm on each side of the front tire and 3mm on each side of the back tire at the tightest spot when inflated to maximum pressure (more clearance when inflated sensibly to some lower pressure so the bike doesn't bounce around like a basketball). Another nice thing is that some of the braze-ons are for 6mm bolts and there are braze-ons on the brake bridge facing downward and chainstay bridge facing backward for direct-mounting the fender. You do have to deflate the huge rear tire to get it out of the horizontal dropouts, however. The fork crown has the hole drilled in it high enough that you can use a daruma bolt and then a recessed nut (like for modern sidepull brakes) to hold the fender on, gaining you even more clearance up top. Head angle is 73 degrees near as I can tell using my cell phone inclinometer app. The tubing is pretty stiff, not a flexy or particularly "lively" bike by any means, but it is butted. Tubing thickness is corroborated by the seat post size, which I think was 26.8 if I recall correctly. Some guy had jammed the wrong post in there so I had to deal with that using my reamers and I'm still not quite sure.
Liked 650 Times
thanks.
thanks.
Liked 1,751 Times
Almost forgot (kids and grand kids all over the place). The wheels on that small Cannondale are 27". Sorry, I really had not taken time to look at first.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
All very nice well priced and my size...but I am out of space
GLWTS, Ben
GLWTS, Ben
Voltaire
Voltaire
