Do different bike companies use different size frames?
I'm 5'8.75" or 5'9" and figured out that I'd probably need ~55cm frame.
The bike I'm looking at on bikesdirect shows this:
XSmall -- 43cm -- 4' 11 up to 5' 2"
Small -- 46.5cm -- 5' 3" up to 5' 6"
Medium -- 50cm -- 5' 7" up to 5' 9"
MedLarge -- 53.5cm -- 5' 10" up to 5' 11"
Large -- 55.5cm -- 6' up to 6' 2"
XLarge -- 58.5cm -- 6' 3" up to 6' 7"
"These size just like Trek and Fuji road bikes - center of bb to top of seat tube"
Quoted: 550 Post(s)
Liked 325 Times
1. Top tube length matters most, perhaps followed by head-tube length with minor adjustments based on the angles involved. You can always get a longer seat post with more or less set back, although there are limits to stem length and height.
2. There's too much variation in people to make predictions based on height. I'm 5'10", my wife is 5'4", and used to appropriate my pants without them dragging on the ground.
5'10, 55cm seat tube, 55.5cm top tube, 120mm -17 degree stem. I could not buy a long enough stem to make two sizes smaller fit, and one size smaller would be marginal.
Looking at some of the on-line fit calculators would be a fine idea.
Quoted: 550 Post(s)
Liked 325 Times
I looked at a ton of online sizing and things that people have said. This chart that they give says I should be 6'2"ish w/ the frame I need. To go w/ my real size, I'd need a frame size of 50? I've never seen anyone anywhere get one that small for this height. Is the chart off or something. Which size would you recommend? 53.5cm?
https://www.competitivecyclist.com/za...LCULATOR_INTRO
and see how things will work with the specific frame geometry.
Bikes: are better than yours.
Frame size is a fiction. And the competitive cyclist fit calculator is nearly worthless. Find someone competent locally to help you. OTOH, you can take a crap shoot with various on-line guesses and you might get lucky.
Telemachus has, indeed, sneezed.
Bikes: Mikkelsen custom steel, Santa Cruz Chameleon SS, old trek trainer bike
Quoted: 70 Post(s)
Liked 6 Times
I'm just under 5'10" and my custom frame has a 53mm top tube, and my Lynskey R230 is a size medium. Both fit me like a glove. Had a "54" Spec Tarmac and it always felt a smidge big.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
Originally Posted by That70sShowDude;14648189
"[COLOR=#000000
"[COLOR=#000000
These size just like Trek and Fuji road bikes - center of bb to top of seat tube"[/COLOR]
pan y agua
Quoted: 1457 Post(s)
Liked 734 Times
For example, I ride a M/l (medium large) in a giant, but an XL in a Wilier.
You could get lost and die.
You could hit a tree and die.
