Stumped by Stems
Stumped by Stems
I’ve had my road bike for 6-7 years. I finally got a fit from my bike guy for it about 3 years ago, due to some knee issues (which were caused by unrelated injury), and I think he changed the saddle position a bit but pretty much said my self-fit was pretty much right on. I’ve always had some upper back/neck discomfort with it though, but have blamed it on my fitness. Lately I’ve been ramping up the mileage and the upper back pain is too much to take, and is limiting me. A few weeks ago did an 70 mile ride, wanted to do 100, had plenty of energy in the legs left, but I was in pain by mile 20 and the pain was intense after 70. I was making efforts to use good form, not put too much weight on the hands, and my hands were not numb, which they tend to get if I lean on them.
So, visited the same bike guy, and asked him to help, just wanted the pain gone.
Looking at it again, he said maybe I could use a little more reach, but I didn’t look too bad, so if I really wanted comfort he could also raise it. So, got an adjustable stem that gave me about 1.1 cm more reach and 4.4 cm more height. (90mm 6deg, to 125mm, about 24deg).
I’ve probably put 50 miles since then, and pain is totally GONE. Very happy about that.
Yet, I don’t love the new setup. My quads are burning and feels like my saddle is too low, though saddle felt PERFECT before and hasn’t moved. Overall the bike just doesn’t feel right, and I’m slower, with less power.
Question 1: Is it normal to have to change seat when making a big stem change like that? I can see where it would change my body’s angles, etc. But doesn’t change the distance from seat to pedals, so I’m not sure… Is it a matter of getting used to it, using different muscles?
But I am also wondering if maybe the change is too much, and I should dial it down to something more reasonable. It’s an adjustable stem, so could dial it down to 15deg, but that would give me over another cm of reach, which is unlikely to be good, but who knows. It’s free. Or, could go down to 15 and get a 110mm stem. Or, go all the way back to 6/7 deg and get a 100mm stem, giving me the extra reach I was missing, and see if that was my main problem.
Question 2: What would you try first in this situation?
For fun, I put dots on a stem chart, below. Red are old and new stems, purple is adjustable stem change, and green and blue are others I could get.
just another gosling
Quoted: 3917 Post(s)
Liked 1,971 Times
More reach is usually good. You should look at the angle between your upper arms and torso when on the hoods and in the drops. Both should give ~90° angle. If you're close to that, you're good. Set up a mirror so you can see yourself, hopefully on the trainer.
What's probably changed is that your new position denies activation to some of the muscles you've trained to use in your old position. New muscles may fill in for them as you train in the new position, or maybe not. It's possible that to use the new muscles effectively, you'll have to move your saddle. Only experimentation can tell you.
Also use the mirror to look at your back. Your pelvis should be rotated forward so that your lower back is as straight as you can get it. This will take the curvature out of your upper back, which will make it easier there and on your neck. https://www.bikeforums.net/road-cycli...discovery.html
Results matter
Results matter
Quoted: 75 Post(s)
I'd give it some time. The more upright you sit, the more the quads are brought into play. That's going to feel different, and it's probably going to take some time to adapt to the new position. You may ultimately not be satisfied with the change, but I think it's too soon to tell if that will be the case.
Thanks for the replies, and the link. I will check things out in the mirror and/or take video, that is a good idea. I may play with the adjustable stem a bit just to compare if a lower angle looks or feels better, it's easy to do.
Otherwise, I can just spend more time trying to get used to it. How long would you give it before making a change?
Quoted: 75 Post(s)
If it were me, I'd give it several more rides and take notice if there is any progression toward feeling like I'm adapting to it. If things aren't improving, I'd start tinkering with my position.
I went down the rabbit hole......Tilted my seat up a bit, Rode 17 miles this morning after reading almost every thread and link from here. Hands extremely numb. Got back lowered my handle bars, and rotated them back to level. went out and rode 5 more miles. Back was flattened out I could feel the stretch, no numbness in the hands, but all of a sudden terrible numbing in my right foot! S%$t!!!!!!!!!!
don't try this at home.
Quoted: 987 Post(s)
Liked 530 Times
I like this Stem Comparison Tool. You can enter two different stems and even have different spacers, and it shows a diagram and the numbers for reach and height.
I'm surprised that your hands went numb. The whole hand, or just the outer or inner half? There's different nerves that affect each half.
Okay, the foot is very odd. Hmmm.
This didn't go how I thought it would go. I did a lot of reading of that thread, videos etc. I set up video to watch myself and didn't like the angles. I think my old setup was pretty relaxed, and the new one was just way too upright. I tried lowering the adjustable stem, and I could get closer to 90deg w the arms by lowering it and stretching out. Ultimately flipped the adjustable stem, probably at about -18 because it's straight forward. I'm about 4cm down from my original, instead of 4cm up. And now about 4cm forward from where I started.
I could have gone lower by dropping the spacers, I tried but that didn't feel good (I wanted to lean on my hands). That lower position actually looked like a 90 deg arm position. But the new one is much closer. I took a 20 mile ride to try it out, upper back felt fine. So maybe what I needed was to stretch out more, not to move up.
Still feels like I'm using different muscles and I have to get used to this position, but the bike didn't feel wrong. I probably need more time to evaluate but I think I'll do it at the lower position, not the higher one.
Quoted: 523 Post(s)
Liked 462 Times
Liked 1,971 Times
Results matter
Results matter
