3x drivetrain on road bike
Quoted: 2700 Post(s)
Liked 486 Times
Do any of you rock a 3x on your road bike? I just fixed my road bike today and had forgotten that it has a tripple up front, but it came it big handy on my way home where I just wanted to chill climbing a steep hill. Why did these fall out of fashion? Are people just not slow enough for the granny gear or something?
Quoted: 3956 Post(s)
Liked 7,307 Times
Liked 7,307 Times
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
Humans have devolved. Or at least I have. I got a bike in 1987 that had a 53/48 T double up front and some sort of corn-cob in the back where all the cogs were about 14 ± 2 T. Now I have a 52/42/30T crankset on the front, and an 11-30T cassette on the back. But it is Campy, and therefore beyond reproach.
Most touring bikes had (and many still have) triples with far smaller granny gears.
BTW, I try not to rock when I pedal. If you are doing that, it indicates the saddle is too high.
Likes For Polaris OBark:
Sunshine
Quoted: 10965 Post(s)
Liked 7,493 Times
How do you forget the number of chainrings on your road bike?
Likes For mstateglfr:
Quoted: 427 Post(s)
Liked 700 Times
Because it's cheaper to put less chainrings on a bike and still charge an inflated price for it. It tries to be justified as being simpler, tuning doesn't have to be as "perfect" as with a triplle, and generally works better. My ancient (98) mtn.bike and my road bike ('06) both have triples and both shift just fine and have never given me any trouble. My bikes are well maintained, and while I'm not an expert mechanic, I do OK. I am a senior, so maybe I just don't appreciate new "advances". My trouble free triples are staying on my bikes-and the triple gets full use on the road bike, while no so much on the mtn.bike.
Quoted: 3242 Post(s)
Liked 2,088 Times
With the move to 11 and 12 speed cassettes, these allowed a great deal of range of gearing. You can get the same range with a 2x or 1x as you do with a triple. Thus it was decided that 3x was no longer needed. Of course you don't get the same gearing as there are sometimes huge gaps between the cogs of those 11 and 12 spd. systems.
Likes For Steve B.:
Quoted: 4416 Post(s)
Liked 4,871 Times
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
as you get older you will learn to use that granny. ain't called a granny for nothing.
Likes For spelger:
Quoted: 18424 Post(s)
Liked 15,579 Times
Quoted: 3241 Post(s)
Liked 2,512 Times
I have them on all of my bikes. The main advantage a triple has over a double with the same range is reduced amount of shifting to go from one end of the range to the other. If you compare the two on a gear calculator, you'll do more physical shifting with the double. Whether that is important or not is up to the individual. Some people don't like shifting the FD either.
Liked 2,512 Times
I usually run 52/40-42/30 triples. There's one climbing ride every year(last weekend) that I change to 52/36/28. The 52 is used very little on that ride. Most of it is on the 36/28 double part of the chainrings.
Liked 486 Times
I also think one advantage of a tripple is downshifting in the front under load. Its easier on the bike than downshifting in the back, so I like having a tripple even if it doesn't give me a larger effective range.
Liked 15,579 Times
Liked 486 Times
I have a bad memory man I guess if pressed I could have remembered that my road bike had a tripple but it took me by surprise for a second when fixing it. Like "ooh yeah this thing has a tripple, huh thats cute... whatever it will come in handy.." was pretty much my thought process. It seems like its dated technology based on the bikes I see around me but maybe they will come back into fashion
Liked 7,307 Times
Likes For Dean V:
bocobiking
6 road bikes, all with triples. I've had numerous road bikes since 1981 and all of them have had triples.
Liked 4,871 Times
Likes For PeteHski:
Liked 15,579 Times
