New Seat Post not going on...
I all. Continuing my Trek 660 project.
Bought an Origin 8 seat post @ 27.2 mm ... the Compe-Lite model. Won't slide down. I can get it to start, but that's all. Did I buy the wrong size?
My bar mic doesn't do metric very well, but the old post measure 1.063-1.064" at the bottom....more like 1.069" at the top. The new post is 1.069".
Thanks.
Thanks.
Quoted: 800 Post(s)
Liked 753 Times
We need pictures of the seat binder bolt area, from behind.
Also, if you're really bored you could just sand down your new seat post to the right size.
Likes For Piff:
Bikes: 1973 Colnago Super, Litespeed Classic , Automoto , Pinarello Gavia TSX,Eddy Merckx Corsa Extra,Eddy Merckx EMX-5 , 1982 Moser SL, Concorde TSX, Vitus 979 KAS. Diamant SLX,60's Meteor
Quoted: 235 Post(s)
Liked 947 Times
I made this video a few weeks ago, It might help you out if you have a dity seat tube.
Likes For Manny66:
Quoted: 800 Post(s)
Liked 753 Times
We just need to see if the slit in the frame back there is damaged or not. Sounds like it's probably fine, but pictures are needed for a clearer diagnosis.
I guess one with the seatpost in shot directly from behind, and one directly from above the seat tube without the post.
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
I'll second making sure the inside of the seat post is clean. A few years ago I got a '84 Trek 760. The grease in the seat tube was like fossilized concrete and and initially made removal and reinsertion of the seat post pretty hard. It was a pain in the (_!_) to clean out. Based on the minty state of the bike, I suspect it was the original grease.
By the way...I'm just getting back into this...is Phil Wood still the "go-to" grease?
Thanks again.
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 159 Post(s)
Liked 133 Times
Mr Obvious here:
What size was the old post?
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,925 Times
Did you take a 27.2 post out? Are you sure it is the correct size? I never put much stock in measuring a seat tube with a caliper.
This is the only way to measure a seat post.
Sugar "Kane" Kowalczyk
Bikes: 2001 LeMond Nevada City, ‘92 Merlin Titanium, '84 Torpado Super Strada, ‘84 Schwinn Tempo, '81 Bianchi Limites, '73 Raleigh Supercourse
Quoted: 161 Post(s)
Liked 69 Times
Sounds like you got the wrong size post. 1.063 is 27.0 according to converting calculator.
I don’t know for sure, but according to THIS (at least for that year) it came with a Sugino SP-KC seatpost. In a quick search I was only able to find mention of 26.8 and 27.0.
Doea the old seat post have the measurement stamped on it somewhere?
Thanks.
Thanks.
Measuring the interior of a seat tube is pretty much useless. You need either a gauge like bianchigirl posted, or a collection of seatposts in different sizes.
Judging by how rough the interior is, a 27.2 post may fit if the seat tube was properly milled with a seat tube reamer. Manufacturers sometimes use undersize seatposts to avoid this step.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,485 Times
Deanodize and polish the post. Try it again. If it doesn't fit, polish it some more until it does.
By the way...did a little bit of re-checking and my bike is the '89 model with the True Temper tube set/ Ultegra group.
Quoted: 4806 Post(s)
Liked 3,928 Times
I am a little amused, It took a dozen posts for someone to do the simple math of converting inches to millimeters. (25.4 mm = 1 in)
That was the first thing I did when I read the opening post. The old post was 27.02 mm. No wonder a 27,2 wouldn't fit.
I'd put the old post back in and snug the seatpin up, then look at the slot in back and check to make sure it is still open. If so, I'd just get a 27.0 post. (Now, if the slot closes up, then you probably have a mis-shapened lug that started as a 27.2. Having it reamed to a round 27,2 with matching post would then be "right".)
Not lost wanderer.
Quoted: 885 Post(s)
Liked 994 Times
Get a small cylinder home, clean up the inside of the seat tube.
Likes For bwilli88:
Quoted: 1627 Post(s)
Liked 630 Times
If you're messing about with old bikes, this is essential advice. A brake cylinder hone should cost less than $20 at your neighborhood auto parts store and be usable for cleaning out the rusty old seat tubes of many bikes.
(On the right, attached to the drill)
But... you still have to have the correct diameter seat post.
Likes For Lascauxcaveman:
Quoted: 4512 Post(s)
Liked 6,382 Times
