So, what's with this?
Bikes: 1938 Raleigh Record Ace (2), 1938 Schwinn Paramount, 1961 Torpado, 1964? Frejus, 1980 Raleigh 753 Team Pro, Moulton, other stuff...
Quoted: 26 Post(s)
Liked 11 Times
I ordered some replacement gum rubber hoods and black cloth tape for Geraldine. The gum rubber hoods fit quite nicely. I taped the right bar, over one layer of existing tape, and I didn't use any on the brake-lever band. Had quite a bit of surplus left; a surprise. The left brake-lever band needed some tape, so I used some of the surplus from the right side for the left. I then proceeded to tape up the left side, ran out of tape about 2.5" from the end of the first layer...
I took the tape off, rolling it back on the spool as it been originally. I compared the diameter of the rerolled tape to the unused rolls. It was a wee bit smaller. I used one of the unused (and slightly larger in dia) rolls to redo the left side and, voila, perfecto mundo, with a bit of surplus as before.
The vendor's comment, "I guess they let acouple of rolls go a bit longer."
Needless to say I'll think twice about ordering from them in the future.
Quoted: 26 Post(s)
Liked 11 Times
Yes, that is correct.
Quoted: 26 Post(s)
Liked 11 Times
Yes, one might think that, but it appears one would be wrong. I guess when three out of four rolls "are a bit longer", it's not considered to be an issue, after all they "had seen a roll or two be longer then others over the years."
Fair warning.
Bikes: Yes
Quoted: 460 Post(s)
Liked 54 Times
I would think the sizes are not cut by hand nowadays and should be equal and sufficient. And would think they would offer to replace if you took the time to call as it must be an issue.
Tape is cheap so not a huge ordeal, but yea maybe that would not be a place I would frequent.
