Your opinion wheels comfort
Bikes: Vintage Camille Dardenne
Quoted: 19 Post(s)
Ok i have to make up my mind on a set of new (used) wheelset and I need your opinion
What is more comfortable between a 1.) Aluminum low profile clincher like ksyrium sl / dura ace c24 l
2.) Carbon deep 50mm tubular ( full carbon) zipp/ corima like
Note: this is a ride comfort only topic
All being equal (pressure, tire width etc etc)
road : mostly flat, rough, mixed weather, no sidewind
Thanks in advance for you input
Quoted: 1096 Post(s)
I imagine it depends on what sort of "comfort" you expect wheels to provide. Rim properties will make a difference in rim brake performance, weight and and aerodynamics (with which you may be more or less comfortable) but except as they relate to the tires they hold, I don't think they make a difference when it comes to notions of comfort such as vibration damping or ride smoothness. I may be wrong about that; however, tires are another matter, and many prefer tubulars for ride feel, but many others are more 'comfortable' knowing that it's easier to repair a flat with clinchers.
Quoted: 19 Post(s)
Thanks for the replies the reason i ask is to know if the comfort that tubulars provide over clinchers is cancelled by deep rim carbon profiles or not. And yes by comfort i mean vibration dampening and ride smoothness.
Bikes: Trek Emonda SL6 .... Miyata One Thousand
Quoted: 63 Post(s)
Liked 29 Times
if you are looking at getting new wheels, look for tubless ready rims .... get decent tubeless tyres and you can run them softer than tubed .... and it is a lot more comfortable for longer distance (I had a wheelset built by my LBS .... best upgrade that I have ever done)
Mostly harmless
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
+1 ....
Quoted: 344 Post(s)
Liked 20 Times
Quoted: 19 Post(s)
I have so many wheelsets that I've lost count. I detect no difference in the 'comfort' between any of the wheels. Tires and tire inflation pressure are all that matters.
Tubulars: I own multiple wheels in carbon and alu with different rim profiles. Unlike clinchers, tubulars won't pinch flat at low inflation pressures. And the tubular rim is isolated from inflation pressure/stresses, so you can inflate tubular tires to very high pressures - if you so choose.
Ride comfort: I regularly ride 22mm tubulars inflated to 80psi over long stretches of packed gravel. You cannot do this with clinchers, due to the risk of pinch flats.
This is where tubulars may feel more comfortable. Otherwise, I cannot tell a difference between clincher and tubular tires of equivalent construction.
Jet Jockey
Between two PROPERLY tensioned and built wheelsets, the differences in vertical deflection/compliance between any given wheels is approximately the thickness of a single sheet of paper. Any more, and the wheel risks spoke failure.
Any comfort differences are either due to tires, or merely perception based on acoustic feedback from the wheelset.
Quoted: 63 Post(s)
Liked 29 Times
I doubt that I will ever go back to clinchers .... I ride lots of miles on crappy roads .... in the past 3 months I've had 3 punctures, and the liquid latex has always done the magic .... all punctures self sealed ... no need to stop in the very rain and change a tube
plus ..... there are some very fast durable tubeless tyres on the market at present and more new tubeless tyres are being developed (thats why many new top end bikes are now being sold with tubeless ready rims (check the new Giant bikes) ... the fastest tyre (tested by bicycle rolling resistance website) is a tubeless tyre
you would be a fool to have a wheelset built now that is not tubeless ready (I have HED Belgium Plus rims, laced to Chris King R45 hubs (the ceramic bearing upgrade) and Sapim Cx Ray spokes .... I can use both tubeless tyres aswell as clinchers
and BTW, my gut feel says tubulars are on the way out now ...
Also, I think tubeless are pretty much "out" already - haven't been typical, even for "advanced enthusiast" level equipment for a long time.
Mostly harmless
Liked 216 Times
and still have to stop everytime you get a puncture and still have to carry spare inner tubes on rides?
I prefer changing a tube (and patching it), then messing with sealant.
Quoted: 63 Post(s)
Liked 29 Times
tubeless is only just starting now .... even Schwalbe have said that tubeless is the way forward ... plus, as I mentioned, I can also use clinchers if I change my mind
My wheelbuilder is regarded as one of the best in the UK .... he strongly suggested Cx Ray spokes and so far I have cycled 2,367.3km (much of it on crappy roads, and my wheels as as true as the day I got them)
I'd never get tubs though .... in 3 years time tubeless will have taken over ... (it's like in the old days when you dad had tubes in his old Ford tyres .... now, tubeless is the norm for all car tyres)
Quoted: 344 Post(s)
Liked 20 Times
So, I'm a fool, Schwalbe sells tubless and there fore promotes them, and, your faster than most. You use the top wheel builder in the UK. Your words are golden
Quoted: 19 Post(s)
Thank you all for the replies. I must admit that my own (limited) expirience differs somehow with the general opinion about wider tires low PSI is all what matters:
I.) Bad rows demand lower pressure in order to improve comfort and what studies showed even rolling resitance. but bad roads + low pressure = pinch flats
the issue I find with wider rim clinchers (17mm vs 15mm internal) is that in fact a 25mm tyre will measure up to ~27mm you will get better cornering gripp less of a "bulb" shape, maybe better aerodynamics (not that I could feel that) but the total tire area remains the same so what you gain in width you loose in tire height which means that the distancee between tire and rims is narrower and thus more prone to pinch flats, in fact the theory "get wider rims and lower the pressure" did not work for me, I had still to keep the pressure up and so no benefit over my 15mm (internal) wide clincher rims
it seems that going wider 17mm vs 15mm in rim witdh increases air volume by only ~2-3% see here :THE RIGHT TYRE WIDTH ON THE RIGHT RIM WIDTH - Engineerstalk : Engineerstalk going wider tires 28mm from 25mm, which will make a difference indeed, is not an option due to frame tolerance
So tubulars or tubless(never tried those) are winners here IMHO
II.)Second I belive rim depth has something to do with comfort despite the general opinion that tire pressure does it all
in fact my vintage mavic GP4 shallow tubular wheels are much more comfortable (to me) even on 22mm butyl conti sprinter tubs at 115psi than fulcrum quattro LG (17mm internal width) 35mm deep rim with continental grand prix clinchers at 90PSI (I have even tired open tubulars like veloflex for a matter of fact and they do seem better but tubulars are still significantly better IMHO). but my question is: are they more comfortable because of tubulars or because of the shallow profile or both and if so what matters most?
in this articleDebunking Wheel Stiffness - Slowtwitch.com it is stated that radial stifness is very much impacted by rim depth. I think that radial stifness accounts for much of the comfort on bad roads (not stiff radially does not mean not stiff lateraly which matters most I think)
III.) And now the third aspect after tubular/clincher wide rim deep rim aspect is wheel material: I have read that carbon absorbs shocks metter than aluminium on bike frames but does this apply to wheels as well? If yes how much difference does it make?
Quoted: 6556 Post(s)
Liked 58 Times
Studies show that you don't lose tire height when you gain width with a wider rim.
Also I doubt the tire height has much affect on susceptibility to pinch flats over the range we are talking about. It is about tire pressure. You are talking about 150-300 pounds compressing the tire on a sharp curb or similar. If you don't have enough pressure, another mm height isn't going to protect you.
Mostly harmless
Liked 216 Times
