A few millimeters makes for a bad day . . .
Hi All, I'm currently building up a lovely 1986 Team Fuji frame with a pair of Pro-Am hubs (as recommended by Sheldon Brown) laced on to H+Son 700c rims, with superb Vittoria Corsa "Control" tyres. But the dropout for the rear wheel of the frame is 126 mm, whereas the OLD of the hub is 120 mm. I propose to add a couple of washers to take up the 6 mm and not spring the frame. But the axle isn't long enough at about 132 mm - the ends barely locate into the dropouts. For it to be completely engaged in the lugs I would need about 140 mm.
Amazon has a "Wheel Master" axle that would appear to fit, but certainly isn't the CroMoly the seller says it is, instead it looks like a product of an Eastern European coal mine. Also reviewers say it's a bit fragile. Any one have any thoughts as to where I can buy a quality part? All I need is the QR axle with the little machined groove to take the tab on the plain washers at each end , everything else can be swapped over.
Any thoughts would be gratefully received, I really want to get past this roadblock . . .
What I have, a few mm too short . . .
What Amazon sells . . .
Wheel Master HUB AXLE Set RR WM 10x1x135x146QR8sCRMO
A bike is the closest I can get to a magic carpet . . .
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 175 Times
Why not just cold-set the frame down to 120mm? Easy peasy.
Likes For arex:
Quoted: 3811 Post(s)
Liked 6,717 Times
Likes For nlerner:
Quoted: 4806 Post(s)
Liked 3,933 Times
That axle will work just fine. All you need is enough axle sticking past the dropout to locate the hub. Once you tighten the QR, nothing is going anywhere. (You are using a steel skewered QR with a single cam and asymmetrical lever I trust. If not, get a decent one. Any modern Shimano and a bunch of others. (I believe the late Sheldon Brown blesses this use of too-short axles as perfectly safe with proper QRs and QR adjustment).
Can be done. I did that to my warranty replacement Fuji Pro in 1978 so I could race my 120 OLD wheels as is. But - it is not 1978. Not even 1986. Coldsetting to 120 OLD means coldsetting it back to 126 or 130 if anyone wants to rejoin the world we live in later.
I would leave the frame alone. Don't try to bend it. Just get the right spacers for the axle to make it fit.
Likes For ramzilla:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
What thread pitch is on your present bearings? I'm thinking a used Campagnolo (Nuovo-era) Record rear axle should be perfect for you, easy enough to search on eBay, and cheap enough if you find a seller not trying to gouge on a good used piece.
Heck, someone here in the ISO thread may have one.
-Kurt
-Kurt
Passista
Quoted: 868 Post(s)
Liked 721 Times
You can use an axle without grooves and replace the keyed washers with standard ones. Makes no difference.
Likes For Reynolds:
Likes For due ruote:
